Kiirotsing
Toote omadused:
Juhtmevaba N-standardiga gigabit ruuter, 4G/3G/2G
Kirjeldus:
USB Port
The router is equipped with a USB port for connecting a USB modem,which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DIR-825device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous  activity  of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of  the standards  802.11a, 802.11b, 802.11g, and 802.11n (at  the  rate up to 600Mbps*).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Airgain Built-in Antennas
The router is equipped with Airgain built-in omnidirectional antennas. In spite of their compact size, such antennas can compete and even exceed performance of traditional  whip antennas. Airgain antennas provide high gain (4dBi for 2.4GHz band and 6dBi for 5GHz  band) and circular pattern in both horizontal and vertical plane; due to this, Airgain antennas show excellent performance in any direction, increase wireless network range and minimize occurrence of blind spots.
Security
The  wireless  router  DIR-825 includes  a  built-in firewall.  The  advanced  security  functions  minimize threats  of  hacker  attacks  and  prevent  unwanted intrusions to your network.
Configuration and Management
You  can  configure  and  manage  the  settings  of  thewireless  router  DIR-825 via  the  user-friendly  webbased  interface  (the  interface  is  available  in  several languages).
* Up to 300Mbps for 2.4GHz and up to 300Mbps for 5GHz.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
