DES-3528
מתג מנוהל 24 פורטים +Layer2 במהירות 10/100 + 2 פורטים ג'יגהביט + 2 פורטים Combo SFP
היכן לקנות
תאור
The xStack® DES-3528 by D-Link is a high-performance, managed, stackable Layer 2 switch that provides an ideal solution for workgroups and edge deployments of a network. The D-Link Single IP Management (SIM) allows administrators to cluster up a virtual stack of up to 32 DES-3528 dispersed switches with fewer distance limitations through a single IP address. The clustering environment spans buildings, making it perfect for businesses that require multiple building deployments. The DES-3528 also supports physical stacking of up to 8 units in a stack, so that the entire stack can act as a single logical unit with up to 4Gbps of stacking backplane. The xStack switch also provides comprehensive security for edge access such as Access Control List, DHCP server screening and DoS attack prevention.
Non-Blocking Switching
The DES-3528 provides a non-blocking switching solution for 10/100 Fast Ethernet connections. The DES-3528 supports 24 10/100Mbps ports, with 4 gigabit 10/100/1000BASE-T ports. Two of these gigabit copper ports are disabled when the two 1000BASE-X SFP are used, also known as dual personality or combo ports. The DES-3528 has a non-blocking bandwidth of 12.8Gbps; the xStack switch has a redundant power option for mission critical applications.
Advanced Network Security
For edge network security, the DES-3528 supports DHCP server screening, client filtering, and IP-MAC-Port Binding to prevent security breaches such as rogue DHCP server, man-in-the-middle attacks and IP spoofing. For clients with XP SP3, Vista, or servers with Microsoft’s Server 2008, DES-3528 works in conjunction with Microsoft’s Network Access Protection (NAP) as part of an ecosystem that enforces compliance with network health policies. The xStack switch will grant network host access only if it complies with IT security policies such as up-to-date anti-virus signatures and operating system patches. This prevents a virus-infested client or server from gaining access and further contamination.
The xStack switch also supports loopback detection, which detects a loop in the network even though the end device causing the loop is without spanning tree. When the switch detects a loop is in the connected node, the DES-3528 shuts down the port with the loop so that the entire system will continue to function normally. This feature can also be VLAN based.
The DES-3528 incorporates advanced mechanisms to detect an attack against the switch’s central processing unit and to take corrective action on the attacking interface. When a Denial of Service attack is waged against the xStack switch, the D-Link Safeguard Engine detects the threat and prevents overload of the central processor thus insuring network integrity and helping to maintain open network bandwidth channels.
In addition, the DES-3528 supports 802.1x authentication, which securly allow users to log onto your network. When used in conjunction with a RADIUS server, 802.1x requires each user workstation attached to the xStack switches to provide a username and password before gaining access to the network. Web-based authentication option is available for those clients who may not have the 802.1x supplicant, while MAC-based authentication can make the authentication process automatically, authenticated by the 802.1x server based on the client’s MAC address. Other security features include access control list, which an administrator can restrict the access of a network through a variety of means including MAC address, IP, UDP/TCP, and even VLAN ID.
IP Clustering Stackable
The xStack DES-3528 provides D-Link Single IP Management Technology (SIM), allowing a set of switches to be managed by a single IP, regardless of geographical locations. Traffic running among units in this virtual stack is through the full-duplex Gigabit interfaces and your usual network wires, doing away with the costly and cumbersome stacking cables. Without any stacking cable, cable distance barrier and physical stacking limitations, your stack can comprise units that are located anywhere on the network, minimizing the impact of any single point of failure. Furthermore, multiple xStack switches can be configured, monitored and maintained from any workstation running a web browser through one unique IP address. The stack is managed as a single object, with all units identified by a single IP address. With Tree View, you can obtain and overview of the members of the stack and a network topology showing the locations of the units and their link information. This provides simple yet powerful web-based management without expensive SNMP network management software. You can add up to 32 switches per stack not limited to any specific D-Link models. With embedded SIM, you can expand your Ethernet stack to include L3 core Gigabit and chassis based switches to accommodate your network growth.
Voice and Video Applications
For today’s businesses, having voice, data and video on the same network is common practice. This challenge is met by the DES-3528, which supports 802.1p with 8 queues. The administrator can designate the priority of the traffic based on a variety of means including IP or MAC address, so that voice data is always clear and jitter free. Video traffic can also be assigned with the same priority. In addition, the switch provides IGMP Snooping or MLD snooping, which allows the forwarding of multicast packets such as streaming audio and video, without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations in the multicast group is created. This list then allows the switch to intelligently forward packets to only the appropriate member workstations. In conjunction with the 802.1Q VLANs, Quality of Service and security can be achieved on a network infused with data traffic.
For other multimedia-on-demand applications, such as IPTV deployments, the DES-3528 provides advanced features for easy video streaming management. For example, this xStack family supports per port multicast stream control, which allows a service provider to assign limited multicast addresses per port. This means it can act as a security control that pre-configures channels for each subscriber on a port level to prevent unauthorized multicast join. DES-3528 also supports IGMP multicast VLAN, which eliminates duplicate multicast traffic being sent to clients in different VLANs and thus removing bottlenecks in the uplink port.
Ease of Management
The DES-3528 supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize the productivity of the network. Other standard management features are also supported including RMON and IEEE 802.1d/w/s spanning tree, User interface includes intuitive web-based browser graphic interface or industry-standard CLI, either administration traffic can be protected thru SSL or SSH encryptions.
מאפיינים כללים
Technical Specifications
Device Interface
24 10/100BASE-TX Auto-Negotiating, Auto-MDI/MDIX Ports
2 Dual-Usage 10/100/1000BASE-T Stacking Ports
2 Combo 10/100/1000BASE-T Ports/SFP Slots
RS-232 Console Port
MAC Address Table
16K
Switching Capacity
12.8Gbps
Maximum 64-Byte System Packet Forwarding Rate
9.5 Mpps
Number of VLANs Per Device
Maximum 4,096 Static VLAN Groups
Maximum 255 Dynamic VLAN Groups
Quality of Service (QoS)
8 Independent Hardware Queues (802.1p/Diffserv/ToS)
Stackability
Virtual Stacking with D-Link Single IP Management (SIM) Up to 32 Devices per Virtual Stack
MLD v1/v2
256 Groups Supported, MLD Snooping Fast Leave
Access Control Lists
Up to 768 Access Rules, Time-based ACL, CPU Interface Filtering
Jumbo Frame Support
Up to 9,216K Bytes
IGMP Snooping
Supports 256 Groups, IGMP Fast Leave, Host-based IGMP Fast Leave
Flow Control
802.3x Flow Control, HOL Blocking Prevention
Port Mirroring
Supports one-to-one or many-to-one, Flow-based mirroring
Link Aggregation
Supports up to eight 8-port Groups
Protects CPU from Broadcast/Multicast/Unicast Flooding
Web-based Graphic User Interface (GUI)
Compatible with Internet Explorer®, Netscape®, Mozilla®, Firefox®, Opera®, Safari® browsers
Interface Options
RJ-45
10BASE-T, 100BASE-TX, 1000BASE-T
SFP Expansion Slots
Media Support Dependent On GBIC Tranceiver
Diagnostic LEDs
Per Device: Power, Console, RPS
Per Gigabit Port: Link/Activity, 10/100Mbps or 1000Mbps Speed
Per Ethernet Port: Link/Activity, 10Mbps or 100Mbps Speed
Network Management
In & Out of Band
Web-Based GUI, Single IP Management v1.6, Command Line Interface (CLI), Telnet Server, Zmodem, SNMP v1/v2c/v3, SNMP Traps, System Log, RMON v1, Support 1,2,3,9 Groups, RMON v2, Support ProbeConfigGroup, BootP/DHCP Client, DHCP Auto-configuration, DHCP Relay, DHCP Relay Option82, Dual Image, Dual Configuration, CPU Monitoring, NTP/SNTP
IEEE
802.1q VLAN Tagging, 802.1v VLAN Protocol, GVRP, 802.1ab Double VLAN (Port-based Q-in-Q, Selective Q-in-Q), VLAN Translation, MAC-based VLAN, Asymmetric VLAN, ISM-VLAN, 802.1p Quality of Service, 802.1D Spanning Tree Protocol (IEEE802.1D-2004 Edition), 802.1w Rapid Spanning Tree Protocol (IEEE802.1D-2004 Edition), 802.1s Multiple Spanning Tree Protocol (IEEE802.1Q-2005 Edition), 802.3x Flow Control, 802.3ad Link Aggregation
IETF
RFC 1112/2236/3376 IGMP v1/v2/v3, RFC 1157 SNMP, RFC 2021 RMON v2, RFC 3810 MLD, RFC1213 MIB-II, RFC1493 Bridge MIB, RFC1907 SNMPv2 MIB, RFC1757/2819 RMON MIB, RFC1643/2358/2665 Ether-like MIB, RFC2674 802.1p MIB, RFC2233/2863 IF MIB, RFC2618 RADIUS AuthenticationClient MIB, RFC2620 RADIUS AccountingClient MIB, RFC2925 Ping & TRACEROUTE MIB, Private MIB
Electrical & Emissions Summary
Emissions
FCC, C-Tick, VCCI Class A
Internal Power Supply
AC to DC
Power Input
100 to 240VAC, 1.5A, 50 to 60Hz
Maximum Power Output
12VDC, 5A
Maximum Power Consumption
20.5 watts
Redundant Power Supply
Connector for Optional External DPS-200
Software Features
L2
Loopback Detection, LLDP
Queue Handling
Strict
Weighted Round Robin (WRR)
Strict + WRR
CoS Based on:
Switch Port
VLAN ID
802.1p Priority Queues
MAC Address
IP v4/v6 Address
DSCP
Protocol Type
IP v6 Traffic Class
IP v6 Flow Label
TCP/UDP Port
User Defined Packet Content
Support Flowing Actions for Flows
Remark 802.1p Priority Tag
Remark TOS-DSCP Tag
Bandwidth Control
Committed Information Rate (CIR), min. granularity 64Kbps
SRED Congestion Control
Bandwidth Control
Port Based (Ingress/Egress, Min. Granularity 64Kbps)
Flow Based (Ingress/Egress, Min. Granularity 64Kbps)
Security
SSH v1/v2
SSL v1/v2/v3
Port Security up to 64 MAC Addresses per port
Broadcast/Multicast/Unicast Storm Control
Traffic Segmentation
IP-MAC-Port Binding
Supports 500 Address Binding Entries per Device
Supports ARP/ACL/Auto (DHCP Snooping) Mode
NetBIOS/NetBEUI Filtering
DHCP Server Screening
AAA
802.1X
Port-Based Access Control
Host-Based Access Control
Dynamic VLAN Assignment
Web-Based Access Control (WAC)
MAC-Based Access Control (MAC)
Japan Web-Based Access Control (Host-Based J-WAC)
Guest VLAN
RADIUS Accounting
RADIUS and TACACS+ Authentication for Switch Access
3-Level User Account
Physical & Environmental
Temperature
Operating: 32° to 113°F (0° to 45°C)
Storage: -40° to 158°F (-40° to 70°C)
Humidity
5% ~ 95% Relative, Non-condensing
Dimensions (W x D x H)
17.4in x 8.3in x 1.7in (441mm x 210mm x 44mm)
Weight
5.5 lbs (2.5 kg)
Safety Compliance
CSA International and CB Report
Warranty Information
Warranty
3 years Limited
Ordering Information
Part Number
Description
DES-3528
xStack Managed 24-Port 10/100 Layer 2+ Switch, 4 Gigabit Ports and 2 Combo SFP
DEM-310GT
SFP Transceiver for 1000BASE-LX, Single Mode Fiber, Maximum Distance 10Km
DEM-311GT
SFP Transceiver for 1000BASE-SX, Muti Mode Fiber, Maximum Distance 550m
DPS-200
Redundant Power Supply Unit, 60 Watt RPSU
DPS-800
2-Slot Redundant Power Supply Open Chassis, for DPS-200/DPS-500
DPS-900
8-Slot Redundant Power Supply Open Chassis, for DPS-200/DPS-500
DS-510S
D-View 5.1 SNMP Network Management Program, Standard Version
DS-510P
D-View 5.1 SNMP Network Management Program, Professional Version
DV-600S
D-View 6.0 Network Management Software, Standard Version
DV-600P
D-View 6.0 Network Management Software, Professional Version
נתונים פיזיים
תקנים
הורדות
איורים
DES-3528
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
