תאור
The DGS-1210-48 is part of D-Link’s 3rd generation of Web Smart Switches that integrates advanced management and security functions for performance and scalability.Featuring an innovative fanless design that ensures quiet operation and a longer life span, the DGS-1210-48 provides a complete and affordable solution for small and medium businesses (SMB).
Seamless Integration
The DGS-1210-48 includes 48 10/100/1000 Mbps ports capable of connecting to existing Cat.5 twisted-pair cables. Additionally, the last four ports of the DGS-1210 Series combine SFP and copper connectivity into one port and therefore provide a flexible solution for server connections via fiber interface. Using the default presets, the administrator can quickly set up the switch without worrying about reconfiguring any settings and providing easy access for the user.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfer. At 2000 Mbps Full Duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. Cable Diagnostics is designed for network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
QoS & bandwidth control
The switch is perfect for deployment in a VoIP environment, as it supports Auto Voice VLAN and Differentiated Services Code Point (DSCP) QoS for VoIP application. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic.With Bandwidth Control, the network administrator can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
Secure your Network
D-Link’s unique Safeguard Engine function protects the switch against traffic flooding caused by virus attacks. The switch also supports 802.1X port-based authentication, allowing the network to be authenticated through an external RADIUS server.In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210-48 includes ARP Spoofing Prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames on a LAN, modify traffic,or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP Spoofing attacks, the switch uses Packet Control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports to prevent unauthorised IP assignment.
Versatile Management
The DGS-1210-48 provides a SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link Web Smart Switches within the same L2 network segment.With this utility, users do not need to change the IP address of their PC and it also provides an easy initial setting of the Smart Switches. Switches within the same L2 network segment that are connected to the user’s PC are displayed on screen for instant access. This allows extensive switch configuration settings and basic configuration of discovered devices such as password changes and firmware upgrades.The DGS-1210 Series also supports D-View 6.0, D-Link’s own Network Management System, and Compact Command Line Interface (CLI) through Telnet. CLI management of the switches is possible via Telnet. This makes the adjustment of basic settings like password changes or firmware and configuration file uploads possible.
D-Link Green
The DGS-1210-48 implements D-Link Green, an innovative concept that provides energy savings whitout sacrificing operational performance or functionality.The switch reacts when devices attached to it are turned off, by placing the corresponding port in a standby mode that requires less power. It also automatically detects the length of connected cables, which allows it to cut power usage on shorter cable connections up to 20 m. D-Link Green certification ensures that the switch complies with the RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives. RoHS restrict the use of specific hazardous materials during the manufacture of electrical and electronic goods, while WEEE applies standards for proper disposal and recyclable packaging to help reduce wastage.
מאפיינים כללים
Standards and function ports
• IEEE 802.3 10BASE-T Ethernet (copper wire twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper wire twisted-pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper wire twisted-pair)
• Auto-negotiation of ANSI / IEEE 802.3
• IEEE 802.3x Flow Control
Number of Ports
• 44-port 10/100/1000 Mbit / s, 4 combo ports 10/100/1000BASE-T/SFP
Network Cables
• UTP category. 5, 5e (max. 100 m)
• EIA/TIA-568 100-ohm STP (maximum 100m)
Full / half duplex
• Full / half duplex for 10/100Mbps speeds
• Full-duplex Gigabit speed for
Advanced Interface
• Auto MDI / MDI-X on all ports for twisted-pair
Switch capacity
• 96 Gb / s
Switching Method
• Store-and-forward
MAC-address table
• 8K entries per device
MAC-address learning
• Up to 256 static MAC-address entries
• Enable / Disable avtoizucheniya MAC-address
Maximum rate of 64 bytes packet
• 71.4 Mpps
RAM Buffer
• 1 MB on the device
Layer 2 features
• Table of MAC-addresses: 8K
• Flow Control
802.3x Flow Control
Prevent block HOL
• IGMP Snooping
IGMP v1/v2 Snooping
Supports up to 256 IGMP-group
Supports up to 64 static multicast groups
IGMP on VLAN
Support for IGMP Snooping Querier
• Spanning Tree Protocol
802.1D STP
802.1w RSTP
• Loopback Detection
• 802.3ad Link Aggregation
DGS-1210-10P: max. number of groups in unit 5 / 8 ports per group
DGS-1210-16/DGS-1210-24/DGS-1210-48: max. number of groups in unit 8 / 8 ports per group
• Port Mirroring
One-to-One
Many-to-One
Support for Mirroring for Tx / Rx / Both
• Diagnostics cable
• Customizable Interface MDI / MDIX
• Multicast filtering
Redirect all unregistered groups
Filtering of unregistered groups
VLAN
• 802.1Q
• Group VLAN
Max. 256 static VLAN groups
Max. VID 4094
• Control VLAN
• Asymmetric VLAN
• Auto Voice VLAN
Max. 10 user defined OUI
Max. 8 by default defined OUI
QoS (Quality of Service)
• 802.1p Quality of Service
• 4 queues per port
• Processing Queue
Strict
Weighted Round Robin (WRR)
• CoS based on
802.1p Priority Queues
DSCP
• Bandwidth Management
Based on the port (inbound / outbound, in increments of up to 64 KB / s)
Access Control Lists (ACL)
• 50 profiles (maximum)
• Max. 240 Access Rules
• ACL on the basis of
MAC-addresses
IPv4-address (ICMP / IGMP / TCP / UDP)
VLAN ID
802.1p priority
DSCP
• ACL Actions
Allow
Deny
Security
• 802.1X
• Port Security
Supports up to 64 MAC-addresses per port
• Office of broadcast / multicast / unicast storm
• Static MAC-address
• D-Link Safeguard Engine
• Function DHCP Server Screening *
• Prevent Attacks ARP Spoofing *
Max. 64 records
• SSL *
Support v1/v2/v3
Support for IPv4
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1 215 Trap Convention MIB
• 2233 Interface Group MIB
• D-Link Private MIB
Compliance with RFC
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 854 Telnet-server
• RFC 855 Telnet-server
• RFC 856 Telnet Binary Transmission
• RFC 858 Telnet Server
• RFC 896 Congestion Control in TCP / IP Network
• RFC 903 Reverse Address Resolution Protocol
• RFC 951 BootP-client
• RFC 1155 MIB
• RFC 1157 SNMP v1
• RFC 1191 Path MTU Discovery
• RFC 1212 Concise MIB Definition
• RFC 1213 MIB II, IF MIB
• RFC 1215 Traps for use with the SNMP
• RFC 1239 Standard MIB
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1519 CIDR
• RFC 1945 HTTP/1.0
• RFC 2131 DHCP
• RFC 2132 DHCP Options and BOOTP Vendor Extensions
• RFC 2138 Authentication Radius
• RFC 2233 Interface MIB
• RFC 2578 Structure of Management Information
• Version 2 (SMIv2)
• RFC 2647 802.1p
• RFC 3416 SNMP
• RFC 3417 SNMP
• RFC 3621 Power Ethernet
Management
• Web-GUI interface
• Compact CLI via Telnet
• Telnet-server
• TFTP-client
• SNMP
Support v1/v2/v3 *
• SNMP Trap
• Trap tool for SmartConsole
• Syslog
Max. 500 entries in the log
Support for IPv4 log server
• BootP / DHCP-client
• Setting time
SNTP
• LLDP, LLDP-MED
