תאור
D-Link’s DGS-1210-10P is the latest generation of Web Smart Switches featuring D-Link Green Technology. The switch integrates advanced management and security functions that provide performance and scalability. The DES-1210-10P’s 10/100/1000 Mbps ports are PoE-enabled, offering ease-of-use and green features like time based PoE, which allows for the power to be shut off at a predetermined time. Compliant with 802.3af and 802.3at pre-standard, this switch is capable of feeding power to PoE and PoE+ devices. Management options for the switches include SNMP, Web Management, SmartConsole Utility, and Compact Command Line. The switch also supports ACL filtering and D-Link’s Safeguard Engine. The switch uses Auto Voice VLAN, ensuring higher priority for voice traffic. The DGS-1210-10P comes with a fanless design in a compact 13” desktop enclosure, also offering a 19” rack mounting option with included mounting brackets. A fanless design allows for quiet operation and guarantees an extended lifetime.
D-Link Green
D-Link is constantly striving to take the lead in developing innovative technology that allows for power-saving without sacrificing operational performance or functionality. The DGS-1210-10P automatically detects the length of connected cables and can adjust power usage by saving energy on shorter cable connections of up to 20 meters. Link status drastically reduces power consumption by automatically toggling ports without a link to sleep mode. The DGS-1210-10P switch takes the approach to green IT one step further by incorporating a special chipset with this advanced silicon technology.
Seamless Integration
The DGS-1210-10P switch comes with ten Gigabit copper ports capable of connecting to existing Cat.5 (or higher) twisted-pair cables. Additionally, the last 2 ports of the DGS-1210-10P combine SFP and copper connectivity into one port and therefore provide a more flexible solution for upstream or downstream server connections via fibre interface. Using the default presets, the administrator can quickly set up the switch without reconfiguring any settings.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, the DGS-1210-10P includes IGMP Snooping, Port Mirroring, Rapid Spanning Tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfer. At 2000 Mbps Full Duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostic feature, designed primarily for adminstrators and customer service representatives, can rapidly discover the type of error and determine the cable quality.
QoS, Bandwidth Control
The DGS-1210-10P is perfect for deployment in a VoIP environment, as it support Auto Voice VLAN and Differentiated Services Code Point (DSCP) QoS for VoIP. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic. With Bandwidth Control, network administrators can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
Secure your Network
D-Link’s innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switches also support 802.1x port-based authentication, allowing the network users to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210-10P switch includes ARP Spoofing Prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARPmessages to the network. To prevent ARP Spoofing attacks, the switch uses Packet Control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
Versatile Management
The DGS-1210-10P provides a SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC. It also simplifies the initial setup of the WebSmart Switches. Switches within the same L2 network segment that are connected to the user’s PC are displayed on screen for instant access. This allows extensive switch configuration and basic setup of discovered devices including password changes and firmware upgrades. The DGS-1210-10P also supports D-View 6.0 and Compact Command Line Interface (CLI) through Telnet. D-View 6.0 is a Network Management System that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security. CLI management of the switches is possible via Telnet. This makes it possible to adjust basic settings, passwords, configuration files, and firmware with ease.
מאפיינים כללים
Standards and function ports
• IEEE 802.3 10BASE-T Ethernet (copper wire twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper wire twisted-pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper wire twisted-pair)
• Auto-negotiation of ANSI / IEEE 802.3
• IEEE 802.3x Flow Control
Number of Ports
• 8-port 10/100/1000 Mbit / s, 2 combo ports 10/100/1000BASE-T/SFP
Network Cables
• UTP category. 5, 5e (max. 100 m)
• EIA/TIA-568 100-ohm STP (maximum 100m)
Full / half duplex
• Full / half duplex for 10/100Mbps speeds
• Full-duplex Gigabit speed for
Advanced Interface
• Auto-detect MDI / MDI-X on all ports for twisted-pair
Performance
• Switch capacity
20 Gb / s
Switching Method
• Store-and-forward
MAC-address table
• 8K entries per device
MAC-address Learning
• Up to 256 static MAC-address entries
• Enable / Disable MAC-address auto-sync
The maximum rate of advance of packet size 64 bytes
• 14.88 Mpps
RAM Buffer
• 512 Kb on your device
PoE
• Standard PoE
802.3af & Pre-standard 802.3at
PoE ports
• Ports 1 to 8: 15.4 W or 30 W
• Max. 30 W for 2 ports of 10/100/1000 Mbit / s
• Max. 15.4 W for 4 ports, 10/100/1000 Mbit / s
• Max. 7.5 W into 8 ports 10/100/1000 Mb / s
PoE power
• Max. Tues 78
Layer 2 features
• Table of MAC-addresses: 8K
• Flow Control
802.3x Flow Control
Prevent block HOL
• IGMP Snooping
IGMP v1/v2 Snooping
Supports up to 256 IGMP-group
Supports up to 64 static multicast groups
IGMP on VLAN
Support for IGMP Snooping Querier
• Spanning Tree Protocol
802.1D STP
802.1w RSTP
• Loopback Detection
802.3ad Link Aggregation
DGS-1210-10P: max. number of groups in unit 5 / 8 ports per group
DGS-1210-16/DGS-1210-24/DGS-1210-48: max. number of groups in unit 8 / 8 ports per group
• Port Mirroring
One-to-One
Many-to-One
Support for Mirroring for Tx / Rx / Both
Cable diagnostic
Customizable Interface MDI / MDIX
• Multicast filtering
Redirect all unregistered groups
Filtering of unregistered groups
VLAN
• 802.1Q
• Group VLAN
Max. 256 static VLAN groups
Max. VID 4094
• Control VLAN
• Asymmetric VLAN
• Auto Voice VLAN
Max. 10 user defined OUI
Max. 8 by default defined OUI
QoS (Quality of Service)
• 802.1p Quality of Service
• 4 queues per port
• Processing Queue
Strict
Weighted Round Robin (WRR)
• CoS based on
802.1p Priority Queues
DSCP
• Bandwidth Management
Based on the port (inbound / outbound, in increments of up to 64 KB / s)
Access Control Lists (ACL)
• 50 profiles (maximum)
• Max. 240 Access Rules
• ACL on the basis of
MAC-addresses
IPv4-address (ICMP / IGMP / TCP / UDP)
VLAN ID
802.1p priority
DSCP
• ACL + Actions
Allow
Deny
Security
• 802.1X
• Port Security
Supports up to 64 MAC-addresses per port
• Office of broadcast / multicast / unicast storm
• Static MAC-address
• D-Link Safeguard Engine
• Function DHCP Server Screening *
• Prevent Attacks ARP Spoofing *
Max. 64 records
• SSL *
Support v1/v2/v3
Support for IPv4
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1 215 Trap Convention MIB
• 2233 + Interface Group MIB
• D-Link Private MIB
Compliance with RFC
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 854 Telnet-server
• RFC 855 Telnet-server
• RFC 856 Telnet Binary Transmission
• RFC 858 Telnet Server
• RFC 896 Congestion Control in TCP / IP Network
• RFC 903 Reverse Address Resolution Protocol
• RFC 951 BootP-client
• RFC 1155 MIB
• RFC 1157 SNMP v1
• RFC 1191 Path MTU Discovery
• RFC 1212 Concise MIB Definition
• RFC 1213 MIB II, IF MIB
• RFC 1215 Traps for use with the SNMP
• RFC 1239 Standard MIB
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1519 CIDR
• RFC 1945 HTTP/1.0
• RFC 2131 DHCP
• RFC 2132 DHCP Options and BOOTP Vendor Extensions
• RFC 2138 Authentication Radius
• RFC 2233 Interface MIB
• RFC 2578 Structure of Management Information
• Version 2 (SMIv2)
• RFC 2647 802.1p
• RFC 3416 SNMP
• RFC 3417 SNMP
• RFC 3621 Power Ethernet
Management
• Web-GUI interface
• Compact CLI via Telnet
• Telnet-server
• TFTP-client
• SNMP
Support v1/v2/v3 *
• SNMP Trap
• Trap tool for SmartConsole
• Syslog
Max. 500 entries in the log
Support for IPv4 log server
• BootP / DHCP-client
• Setting time
SNTP
• LLDP, LLDP-MED
• Time-based PoE
