DES-1024AEOL EOS
תאור
Auto-sensing 10/100 ports
The DES-1008D uses auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX CrossOver
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
מאפיינים כללים
Key features
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• ANSI / IEEE 802.3 NWay auto-negotiation and speed of operation
• IEEE 802.3x Flow Control
Protocol
• CSMA / CD
Data transfer rate
• Ethernet:
- 10 Mbps (half duplex)
- 20 Mbps (full duplex)
• Fast Ethernet:
- 100 Mbps (half duplex)
- 200 Mbps (full duplex)
Number of Ports
• 24-port 10/100Mbps Fast Ethernet
Topology
• Star
Network Cables
• 10BASE-T:
- UTP Cat. 3/4/5/5e (100m max.)
- EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX:
- UTP Cat. 5/5e (100m max.)
Switching Method
• Store-and-forward
MAC-address table
• 8K on the device
MAC-address learning
• Automatic Update
Packet (half duplex)
• Ethernet: 14,880 packets per second. at port
• Fast Ethernet: 148,800 packets per second. at port
RAM Buffer
• 320 KB (2.5 Mb)
