DES-1210-08PEOL EOS
מתג מנוהל WEB עם 8 פורטים 10/100 PoE
היכן לקנות
תאור
D-Link’s DGS-1210 Series is the latest generation of Web Smart Switches featuring D-Link Green Technology. The series integrates advanced management and security functions that provide performance and scalability. Additionally, the DES-1210-10P’s 10/100/1000 Mbps ports are PoE-enabled, offering ease-of-use and green features like timebased PoE, which allows for the power to be shut off at a predetermined time. Compliant with 802.3af and 802.3at Pre-Standard, this switch is capable of feeding power to devices up to 30 Watts. Management options for the switches include SNMP, Web Management, SmartConsole Utility, and Compact Command Lines. The series also supports ACL filtering and D-Link’s Safeguard Engine. The DGS-1210 Series uses Auto Voice VLAN, ensuring higher priority for voice traffic. The DGS-1210-10P comes with a fanless design in a compact 13” desktop enclosure, the DGS-1210-16 and DGS-1210-24 feature a fanless design
in 19” metal cases. The DGS-1210-48 is equipped with two smart fans which are set to low speed by defaultand will automatically switch to high speed once the temperature threshold is reached. A fanless design allows for quieter operation and guarantees an extended lifetime, while smart fans help to save power.
D-Link Green
D-Link is constantly striving to take the lead in developing innovative technology that allows for power-saving without sacrificing operational performance or functionality. The DGS-1210 Series automatically detects the length of connected cables and can adjust power usage by saving energy on shorter cable connections of up to 20 meters. Link status drastically reduces power consumption by automatically toggling ports without a link to sleep mode. The DGS-1210 Series takes the approach to green IT one step further by incorporating a special
chipset with advanced silicon technology.
Seamless Integration
The DGS-1210 Series comes with Ethernet and Gigabit copper ports capable of connecting to existing Cat.5 twisted-pair cables. Additionally, the last 2 or 4 ports of the DGS-1210 Series combine SFP and copper
connectivity into one port and therefore provide a more flexible solution for upstream or downstream server connections via fiber interface. Using the default presets, the administrator can quickly set up the switch without reconfiguring any settings.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows
servers to directly connect to the switch for fast, reliable data transfer. At 2000 Mbps Full Duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostic feature, designed primarily for
adminstrators and customer service representatives, can rapidly discover the type of error and determine the cable quality.
QoS, Bandwidth Control
The switches are perfect for deployment in a VoIP environment, as they support Auto Voice VLAN and
Differentiated Services Code Point (DSCP) QoS for VoIP. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic. With Bandwidth Control, network administrators can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
Secure your Network
D-Link’s innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switches also support 802.1X portbased authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210 Series includes ARP Spoofing Prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP Spoofing
attacks, the switch uses Packet Control ACLs to block invalid packets that contain fake ARP messages. For
added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports
to prevent unauthorized IP assignment.
Versatile Management
The DGS-1210 series provides a SmartConsole utility and a web-based management interface that enables
administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC. It also simplifies the initial setup of the Smart Switches. Switches within the same L2 network segment that are connected to the user’s PC are displayed on screen for instant access. This allows extensive switch configuration and basic setup of discovered devices including password changes and firmware upgrades. The DGS-1210 Series also supports D-View 6.0 and Compact Command Line Interface (CLI) through Telnet. D-View 6.0 is a Network Management System that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security. CLI management of the switches is possible via Telnet. This makes it possible to adjust basic settings, passwords, configuration files, and firmware with ease.
מאפיינים כללים
Interfaces
• 8-port 10/100BASE-TX PoE
Ports
• IEEE 802.3 10BASE-T Ethernet (copper wire twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper wire twisted-pair)
• Auto-negotiation ANSI/IEEE 802.3
• IEEE 802.3x Flow Control
Performance
• The capacity of the switch: 1.6 GB
• Maximum speed packet processor 64 bytes: 1.19 Mpps
• MAC-address table: 8K entries per device
• Buffer RAM: 384 KB
• SDRAM for CPU: 64 MB
• Flash-Memory: 16 MB
• Switching Method: Store-and-forward
Power over Ethernet (PoE)
• Standard PoE: 802.3af
• Functions of PoE ports
  Ports 1-8 up to 15.4 Watt per port
• Power PoE: 72 Watt
Diagnostic Lights
• Power (per device)
• Link/Activity/Speed ​​(per port)
Layer 2 features
• MAC Address Table: 8K
• Flow Control
  802.3x Flow Control
  HOL blocking prevention
• IGMP Snooping
  IGMP v1/v2 Snooping
  Supports up to 256 IGMP-group
  Supports up to 64 static multicast groups
  IGMP Snooping on the VLAN
  Supports IGMP Querier
• Multicast filtering
  Unregistered groups redirect
  Unregistered groups filtering
• Spanning Tree Protocol
  802.1D STP
  802.1w RSTP
• Loopback detection
• Link aggregation 802.3ad
  Max. number of groups per device - 8, 8 ports per group
• Port mirroring
  One-to-One
  Many-to-One
  Flow based
• Cable diagnostics
• Customizable MDI/MDIX interface
VLAN
• 802.1Q tagged VLAN
• VLAN group
  Max. 256 static VLAN
  Max. 4094 VIDs
• Management VLAN
• Asymmetric VLAN
• Auto Voice VLAN
  Max. 10 user defined OUI
  Max. 8 by default defined OUI
• Auto Surveillance VLAN
Quality of service (QoS)
• 802.1p
• 4 queue
• Processing Queue
  Strict
  Weighted Round Robin (WRR)
• CoS-based
  802.1p Priority Queues
  DSCP
• Bandwidth Management
  Based on the port (inbound/outbound, step up to 64 kbit/s for 10/100 Mbit/s and a step 1850 kbit/s to 1000 Mb/s)
Access Control Lists (ACL)
• Max. 50 member profiles
• Up to 240 incoming access rules
• ACL-based
  MAC-address
  IPv4-address
  ICMP/IGMP/TCP/UDP
Security
• 802.1X
  Access control based on port
• Port Security
  Support for up to 64 MAC-addresses per port
• Control of Broadcast/Multicast/Unicast storm
• Static MAC-address
• D-Link Safeguard Engine
• DHCP Server Screening
• Preventing ARP Spoofing Attacks
  Max. 64 records
• SSL
• Support v1/v2/v3
Management
• Web-GUI interface
• Compact CLI via Telnet
• Telnet-server
• Utility SmartConsole
• TFTP-client
• SNMP
  Support v1/v2/v3
• SNMP Trap
• Trap for SmartConsole Utility
• Syslog
• Max. 500 entries in the log
• Supports IPv4 log serve
• BootP/DHCP-client
• Setting the time
  SNTP
• LLDP1
• LLDP-MED2
• Time based PoE
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1215 Trap Convention MIB
• 2233 Interface Group MIB
• D-Link Private MIB
• Power Ethernet-MIB1
• LLDP-MIB1
Compliance with RFC
• RFC 768 UDP
• RFC 783 TFTP-client
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 854, 855, 856, 858 Telnet-server
• RFC 896 Congestion Control in TCP / IP Network
• RFC 903 Reverse Address Resolution Protocol
• RFC 951 BootP-client
• RFC 1155 MIB
• RFC 1157 SNMP v1
• RFC 1191 Path MTU Discovery
• RFC 1212 Concise MIB Definition
• RFC 1213 MIB II, IF MIB
• RFC 1215 Traps for use with the SNMP
• RFC 1239 Standard MIB
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1519 CIDR
• RFC 1942 BootP / DHCP client
• RFC 1901, 1907, 1908 SNMP
• RFC 1945 HTTP/1.0
• RFC 2131, 1232 DHCP
• RFC 2138 RADIUS Authentication
• RFC 2233 Interface MIB
• RFC 2570, SNMP 2575
• RFC 2578 Structure of Management Information Version 2 (SMIv2)
• RFC 2647 802.1p
• RFC 3416, SNMP 3417
• RFC 3621 Power Ethernet (only model PoE)
נתונים פיזיים
Dimensions
• Metal housing, 7.5''
MTBF (hours)
• 350,704 hours
Acoustics
• 0 dB
Heat release
• 305.03 BTU / hour
Power input
• External universal power supply from 100 to 240 VAC, 50/60 Hz
The maximum power consumption
• 89.4 Watt (PoE enabled)
• 9.7 Watt (PoE disabled)
Dimensions (W x D x H)
• 190 x 120 x 38 mm
Operating temperature
• From 0° to 40° C
Storage temperature
• -10° To 70° C
Operating humidity
• 5 to 95% (no condensation)
Electromagnetic compatibility
• FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Security
• cUL, CE LVD
תקנים
הורדות
איורים
DES-1210-08P/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
