DES-1210-10/MEEOL EOS
מתג מנוהל WebSmart עם 8 פורטים 10/100Mbps ו 2 יציאות משולבות ג'יגהביט/אופטי (SFP)
היכן לקנות
תאור
Gigabit connection for home
The D-Link DGS-1008P 8-port Gigabit Ethernet switch enables home and office users to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless access points (APs), IP cameras, and IP phones. It also provides the opportunity to add additional Ethernet devices like computers, printers, and Network Attached Storage (NAS) onto a network. This compact PoE switch operates quietly, making it ideal for use in virtually any room or office.
Power over ethernet (PoE)
The first four ports of the DGS-1008P support the IEEE 802.3af PoE protocol. Each of these four ports can supply up to 15.4 watts, for a total PoE budget of 52 watts, allowing users to attach an IEEE 802.3af-compliant device to the DGS-1008P that requires no additional power. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables.
Auto MDI/MDIX crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Conserves energy
The DGS-1008P 8-Port Gigabit Switch makes use of D-Link Green™ eco-friendly technology, providing energy savings, reduced power consumption, and a longer product life without sacrificing operational performance or functionality. This switch helps to conserve energy through methods such as Link Status and Cable Length Detection. The Link Status feature automatically powers down ports that have no link, allowing the switch to save substantial amounts of energy
by cutting power for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjust power usage accordingly, helping you save energy without affecting networking performance. In addition, the fan-less design extends the product’s life and also reduces noise.
מאפיינים כללים
Interface
• 8-port 10/100BASE-TX
• 2 combo ports 10/100/1000BASE-T/SFP
Performance
• Switching matrix: 5.6 Gb/s
• 64-byte packets rate: 4.17 Mpps
• Size of the MAC Address Table: 8K
• SDRAM for CPU: 64 MB
• Packets buffer: 512 KB
• Flash-Memory: 16 MB
Diagnostic Lights
• Power (per device)
• Console (per device)
• Link/Activity (per port)
• Rate indicator (per port)
Layer 2 features
• MAC Address Table: 8K
• IGMP Snooping:
  IGMP v1/v2 Snooping
  Supports up to 64 groups
  IGMP Snooping Fast Leave on a port-based
• Spanning Tree:
  802.1D-2004 Edition STP
  802.1w RSTP
  802.1s MSTP
  Root Restriction (Restriction of roots)
• The Loopback Detection (LBD)
• Link aggregation 802.3ad:
  Max. number of groups - 8, 8 ports per group
• Port mirroring:
  Supports mirroring modes One-to-One, Many-to-One, Flow based
• Flow control:
  802.3x Flow Control
  Prevent HOL block
VLAN
• 802.1Q Tagged VLAN
• Group VLAN:
  Max. 4K VLAN
• VLAN-based port
• GVRP:
  Max. 255 Dynamic VLAN
• Asymmetric VLAN
• ISM VLAN
Quality of Service (QoS)
• Bandwidth management:
  Port based (inbound/outbound, in increments of up to 62.5 kbit / s)
  Flow based (incoming, in increments of up to 62.5 kbit / s)
• 4 queues per port
• 802.1p
• Processing of queues:
  Strict
  Weighted Round Robin (WRR)
• CoS based on:
  Switch Port
  VLAN ID
  802.1p Priority Queues
  MAC address
  IP-address
  DSCP
  Type of protocol
  TCP / UDP port
Access Control Lists (ACL)
• Up to 240 Access Rules
• ACL based on:
  802.1p priority
  VLAN ID
  MAC address
  Ether Type
  IP-address
  DSCP
  Type of protocol
  Non TCP / UDP port
• CPU Interface Filtering
Security
• SSH v2
• Port Security
  Up to 16 MAC addresses per port
• Management of broadcast / multicast / unicast storm
• Segmentation of Traffic
• IP-MAC-Port Binding (IMPB):
  ARP packets check
  IP packets check
  Supports up to 500 entries per device address
• The D-Link Safeguard Engine
• Microsoft ® NAP
  Support for 802.1X NAP
  Support for DHCP NAP
AAA
• 802.1X:
  Access control based on port
  Access control based on hostname
  Dynamic VLAN Assignment
• Guest VLAN
• Maintaining RADIUS accounting
• RADIUS authentication and TACACS + for switch access
Management
• Web-interface
• Command line interface (CLI)
• The server / Telnet client
• TFTP-client
• X-modem
• Z-modem
• SNMP v1/v2c/v3
• SNMP Traps
• RMON v1:
  Support for Groups 1, 2, 3, 9
• BootP / DHCP-client
• DHCP Autoconfiguration
• DHCP Relay
• DHCP Relay Option 82
• System Log
• Support for two versions of the software
• Monitor the CPU
• SNTP
• LLDP
• Debug commands
• Diagnosis of cable
Standards of MIB / IETF
• RFC2866 Maintaining RADIUS accounting
• RFC2138 RFC2139 RADIUS authentication for access control
• RFC1492 TACACS + Authentication for access control
• RFC2068 HTTP
• RFC768 UDP
• RFC783 TFTP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC854 Telnet
• RFC783 TFTP
• RFC1157, 1901, 1908, 2570, 2575 SNMP
• RFC2819 RMON v1
• RFC951, 1542 BootP / DHCP-client
• RFC3046 DHCP relay
• RFC3164, 3195 System Log
• RFC1213 MIB II
• RFC1493 Bridge
• RFC1907 SNMP v2 MIB
• RFC1757, 2819 RMON
• RFC2021 RMON v2
• RFC1643, 2358, 2665 Ether-like MIB
• RFC2674 802.1p
• RFC2233, 2863 IF MIB
• RFC2618 RADIUS Authentication Client
• RFC2620 MIB RADIUS client account
• RFC2925 Ping and TRACEROUTE
• Private MIB
נתונים פיזיים
Dimensions
• Width for 19 "standard rack, the height of a
MTBF (Hours)
• 517 990 h
Heat release
• 64,1 BTU/hr
Power input
• 100-240 VAC, 50-60 Hz internal universal power supply
Power consumption
• Standby: 5.5 Watt
• Max.: 11.5 Watt
Dimensions
• 441X207X44 mm
Fans DC
The passive cooling system
Operating temperature
• 0˚ to 40˚ C
Storage temperature
• From -40˚ to 70˚ C
Operating Humidity
• 5% to 95% noncondensing
EMI
• FCC Class A, CE, C-Tick, VCCI Class A
Safety certifications
• cUL, LVD
תקנים
הורדות
איורים
DES-1210-10/ME
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
