DXS-3600-32Sמיועד לפרויקטים
מתג מנוהל 24 פורטים SFP+, עם מודול הרחבה, עם ספק כח ושלושה מאווררים
היכן לקנות
תאור
A series of 10-Gigabit Switch Layer 2/3 D-Link DXS-3600 includes the new compact, high performance switches that support wire-speed 10-Gigabit switching Ethernet, routing, and very low latency. The height of 1U and the ability to choose the direction of ventilation on the back of the front or vice versa make a series of DXS-3600 is very suitable for use in data centers, enterprises and campuses at the level of aggregation. Switch DXS-3600 has 24 fixed-port 10GbE SFP + and can use more ports by adding expansion modules. Expansion not only provide additional ports 10G SFP +, but also increase the flexibility of 120-Gigabit stacking, 40-gigabit links, or reduce the cost of connections mezhstoechnyh 10G Base-T for different applications.
Switch DXS-3600 provides high-performance 10-Gigabit data transmission switch fabric up to 960 Gbit / s and a maximum speed of advance packages 595,2 Mpps. Switches are equipped with power supplies, hot swappable fans, and that evidence of a highly developed architecture of these devices. The modular power supply circuit to select the network with a constant or alternating current, depending on the installation location. If you install two power supply modules, they distribute the load and help extend the life of another module. DXS-3600 Series also includes a modular scheme of fans. Three fan may overlap, providing N +1 redundancy for the system. If one fan fails, the remaining fans increase their speed, automatically determining the temperature of the system. And the power supply modules and fan modules are hot swappable, which reduces downtime.
The functions of the data center
Data Center Bridging (DCB) is a mandatory install extensions for Ethernet networking in the data center. Switch DXS-3600 supports several major components of the DCB, such as IEEE 802.1Qbb1, IEEE 802.1Qaz1 and IEEE 802.1Qau1. IEEE 802.1Qbb (flow control based on priorities) provides flow control for the leveling of data loss during network congestion. IEEE 802.1Qaz (enhanced transmission selection) controls the allocation of bandwidth among different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion control for data flows within the network domain in order to prevent overloading. Switch DXS-3600 also supports unbuffered packet switching, which reduces the time delay in data transmission on the network.
Energy-saving
DXS-3600 switches allow users to adjust the air flow, using different settings of the power modules and fans. Ability to select the direction of ventilation on the back of the front or vice versa for maximum air conditioning for more efficient cooling systems, all mounted in a rack in data centers that use switches. The switches also feature built-in smart fans, internal temperature sensors that control the temperature change and react accordingly to the use of various fan speeds at different temperatures. At low temperatures, fans will run slower, which reduces the energy consumption of the switch and reduce the noise level.
1 These functions will be implemented in future firmware upgrade
מאפיינים כללים
Interface
• 24 fixed 10 Gigabit Ethernet ports with one expansion module
Console port
• RJ-45 to control the out-of-band
Port management
• 10/100/1000 Base-T with RJ-45 connector for remote control of out-of-band
Slot for SD-Card
• 1
Performance
• Switching Matrix: 960 Gbit / s
• Max. packet rate: 595.2 Mpps
• Size of the packet buffer size: 9 MB
• MAC-address table: 128K
Software
Stacking
• Virtual Stacking / up to 32 devices in steke2
  - Support for D-Link Single IP Management
L2 functions
• MAC-address table
  - 128K records
• Flow Control
  - 802.3x Flow Control in full duplex mode
  - Method of Back Pressure for half duplex
  - HOL Blocking Prevention
• Spanning Tree
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Root Restriction
• The Loopback Diagnostics2
• 802.1AX Link Aggregation
  - Max. 16 groups per device, 12 ports per group
• ERPS2 (Ethernet Ring Protection Switching)
• Port Mirroring
  - One-to-One, Many-to-One
  - Supports Mirroring for Tx / Rx / Both
  - Up to 4 groups
• Flow Mirroring
  - Rx
   - Up to 4 groups
• Jumbo-size frames
  - Up to 12,000 bytes
Multicast Layer 2
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Supports 4K IGMP groups
  - Supports up to 1K static multicast groups
  - IGMP on a VLAN
• Filtering of multicast
  - Redirect all groups
  - Redirect all non-registered groups
  - Filtering of unregistered groups
• MLD Snooping2
  - MLD v1/v2 Snooping
  - Supports up to 4K groups
  - MLD Snooping Fast Leave on the basis of host
VLAN
• 802.1Q
• 802.1v
• The Double VLAN (Q-in-Q)
  - Q-in-Q port-based
  - Selective Q-in-Q
• VLAN-based port
• VLAN MAC-based address
• VLAN-based subnets
• Private VLAN2
• Group VLAN
  - Max. 4K static VLAN groups
  - Max. 4094 VIDs
• GVRP
  - Up to 4K dynamic VLAN groups
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue management
  - Strict
  - Weighted Round Robin (WRR)
  - Strict + WRR
  - Round Robin (RR)
  - Weighted Elastic Round Robin (WERR)
• CoS-based
  - 802.1p Priority Queues
  - DSCP
  - IP-address
  - MAC-address
  - VLAN
  - IPv6-Class Traffic
  - IPv6 flow labels
  - TCP / UDP port
• Bandwidth Management
  - Based on the port (Outbound / Inbound / min. Step up to the 8 kbit / s)
  - Based on the flow (incoming / outgoing / min. Step up to the 8 kbit / s)
  - The output queue (at least step up to the 8 kbit / s)
• Three Color Marker
  - TrTCM
  - SrTCM
• Congestion Control
  - WRED
• Supported actions with the flow:
  - Tagging 802.1p priority
  - Adding a tag TOS / DSCP
  - Flow Control
  - Committed Information Rate (CIR)
L3 functions
• ARP
  - 512 Static ARP
  - Gratuitous ARP2
• IP-Interface
  - Supports up to 256 interfaces
• Loopback Interface 2
• VRRP
• IPv6 Tunneling2
  - Static
  - ISATAP
  - GRE
  - 6to4
Layer 3 routing
• Default Routing
• Static Routing
  - Max. up to 1K entries for IPv4
  - Max. up to 512 entries to IPv62
  - Support for the distribution of routes
  - Support for the secondary route
  - Support for equal / weighted cost multipath routing
• Supports up to 16K entries for IPv4/IPv6 routing
  - Max. 16K IPv4 records
  - Max. 8K IPv6 records
• Supports 8K L3 shared items sent to IPv4/IPv6
  - Max. 8K IPv4 records
  - Max. 4K IPv6 records
• RIP
  - RIP v1/v2
  - RIPng2
• OSPF
  - OSPF v2
  - OSPF v32
  - OSPF Passive Interface
  - Stub / NSSA Area
  - OSPF Equal Cost Route
• BGPv4
• Redistribution of routes
• IP Directed Broadcast
• Policy-based routing
Multicast Layer 3
• The size of the multicast table: 2K
• IGMP v1, v2, v3
• PIM-SM
• PIM-DM
• PIM-Sparse-Dense Mode
• PIM-SSM
• DVMRP v3
• MLD v1/v2
MPLS2
• LDP
• MPLS LSP trigger filtering
• MPLS label-forwarding
• MPLS QoS
• MPLS ping and traceroute
• L2 protocol tunneling through PW
• VPWS
• VPLS
• PW Redundancy
L3 VPN2
• MPLS / BGP L3 VPN
• VRF-Lite
• MP-BGP
• VRF aware application
Access Control Lists (ACL)
• Max. ACL entries:
  - Up to 1792 incoming access rules
  - Up to 1K outgoing access rules
  - Up to 1K rules VLAN
• ACL-based time
• ACL based on:
  - 802.1p Priority
  - VLAN
  - MAC-address
  - Ether type
  - IP-address
  - DSCP
  - Type of protocol
  - Non TCP / UDP port
  - Class of IPv6 traffic
  - IPv6 flow labels
Security
• Port Security
  - Up to 12K MAC-addresses on the port / system
• Control of Broadcast / много-адресных/одноадресных storms
• D-Link Safeguard Engine2
• DHCP Server Screening2
• The IP-MAC-Port Binding2
  - Checking the ARP-packets
  - Verification of IP-packets
  - DHCP Snooping
• Prevent attacks ARP Spoofing2
  - Max. 64 records
• Segmentation of Traffic
• SSL2
  - Support v1/v2/v3
  - Support for access IPv4/v6
• SSH
• Prevent attacks BPDU
• DOS Attack Prevention
AAA
• 802.1X
  - Access control based on port
  - Access control based on the host
  - Dynamic VLAN Assignment
  - Identity-driven Policy (VLAN / ACL / QoS) Assignment
• Access web-based interface (WAC) 2
• Access control based on MAC-address (MAC) 2
• Guest VLAN
Standard MIB and RFC
• RFC1213 MIB II
• RFC1907 SNMP v2 MIB
• RFC5519 IGMP v3 MIB
• RFC1724 RIP v2 MIB
• RFC2021 RMONv2 MIB
• RFC1643, RFC2358, RFC2665 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674 802.1p MIB
• RFC2096 IP Forwarding Table MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 PIM MIB for IPv4
• RFC2925 Trace Out MIB
• RFC2925 Ping MIB
• RFC1850 OSPF MIB
• Private MIB
• RFC1112, RFC2236, RFC3376, RFC4541 IGMP Snooping
• RFC4363 802.1v
• RFC2338 VRRP
• RFC1058, RFC1388, RFC1723, RFC2453, RFC2080 RIP
• RFC1370, RFC1765, RFC2328, RFC2740, RFC3101 makes RFC1587 obsolete, RFC2328 makes RFC1583, RFC2178 OSPF v2, v3
• RFC1771, RFC1997, RFC2439, RFC2796, RFC2842, RFC2918 BGP
• RFC3973 PIM-DM
• RFC5059 PIM-SM
• RFC3569, RFC4601, RFC4608, RFC4607, RFC4604 PIM SSM
• RFC3376 IGMP
• RFC2475 Priority Queue Mapping
• RFC2475, RFC2598 Class of Service (CoS)
• RFC2597, RFC2598 QoS Flow Actions
• RFC2697, RFC2698 Three Color Marker
• RFC2093, RFC2904, RFC2095, RFC2906 AAA
• RFC1321, RFC2144, RFC2313, RFC2420, RFC2841, RFC3394 Encryption
• RFC2289 One-Time
• RFC3580 802.1X
• RFC2866 RADIUS Accounting
• RFC2138, RFC2139, RFC2865, RFC2618 RADIUS Author. for Management Access
• RFC1492 TACACS + Auth. for Management Access
• RFC2068, RFC2616 Web-based GUI
• RFC854 Telnet Server
• RFC783, RFC1350 TFTP Client
• RFC1157, RFC1901, RFC1908, RFC2570, RFC2574, RFC2575, RFC3411-SNMP 17
• RFC3164 System Log
• RFC2819 RMON v1
• RFC951, RFC1542, RFC2131, RFC3046 BootP / DHCP Client
• RFC1769 Time Setting
• RFC2131 DHCP Server
• RFC1191 MTU Setting
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC4188 Bridge MIB
• RFC1157, RFC2571-2576, RFC3411-3415, RFC3418 SNMP MIB
• RFC1901-1908, RFC1442, FC2578 SNMP v2 MIB
• RFC2737 Entity MIB
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2716, RFC3748 EAP
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
Management
• Management of web-based interface
• Command Line Interface CLI
• Telnet Server
• The TFTP client
• FTP Client
• Monitoring of
• SNMP
  - Support v1/v2/v3
• SNMP Trap
• System log
• DHCP - client
• DHCP-server
• DHCP Relay
• Support for multiple versions of software
• Support for multiple versions of configurations
• Flash File System
• DNS Resolver
• CPU Monitoring
• MTU Setting
• Traceroute
• LLDP
• DNS Relay
• SMTP2
• Automatic DHCP2
• SNTP
• RCP2
• RMONv1
• RMONv2
• Trusted host (Trusted Host) 2
• Password Encryption
• Command debug (Debug Command)
נתונים פיזיים
Input Power
• 100-240 VAC, 50/60 Hz
Power consumption
• Max.: 115.3 watts (without expansion module)
• Standby mode: 85.9 Tues
Heat release
• Max.: 393.4 BTU / h
• Stand: 293.1 BTU / h
Dimensions (W x D x H)
• 440 x 506 x 44 mm
Operating temperature
• From 0 to 45 ° C
Storage temperature
• From 40 to 70 ° C
Operating humidity
• From 0% to 95%
Storage humidity
• From 0% to 95%
Diagnostic Lights
• Per device: Power 1, Power 2, Fan 1, Fan 2, Fan 3, Console, MGMT, SD Card, Stacking ID
• The SFP + port: Link / Activity / Speed
Certificates
• Safety: CB, cUL, LVD
• EMI / EMC: FCC, CE, C-Tick, IC, VCCI
2 These functions will be supported in future versions of the software
תקנים
הורדות
איורים
DXS-3600-32S/B
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
