DES-1016/A1EOL EOS
מתג שולחני עם 16 פורטים 10/100 עם חסכון בחשמל (מארז פלסטיק)
היכן לקנות
תאור
Think Green Technology
Switch D-Link DES-1016 16-port 10/100 Mbit / s is a new series of devices for networking SOHO. Thanks to Green technology device reduces energy costs and reduces the power consumption of the device without sacrificing performance and functional characteristics. Using a power adapter, compliant EnergyStar Level V and the RoHS Directive on the restriction of the use of hazardous substances, as well as the reuse of packaging protect the environment.
Saving electricity
16-Port Switch DES-1016 provides automatic saving of electricity in several ways. With the automatic power off when there is no connection ports are saving a significant amount of energy on the inactive port or ports that are connected to the computer is off. The switch is able to analyze the length of any cable connected to select the desired level of power consumption, thus providing energy savings without sacrificing performance.
Protecting the environment
DES-1016 is designed in compliance with EnergyStar Level V and regulations and the CEC MEPS, requiring the use of power adapters that reduce energy consumption in order to protect the environment. The switch also complies with RoHS to restrict the use of hazardous substances and recycling of packaging that greatly reduces the amount of waste under the WEEE directive
מאפיינים כללים
Key Features
• Built-in D-Link Green
• Cost-effective Fast Ethernet for home networking and SOHO Networks
• 16-port Fast Ethernet 10/100 Mbit / s
• Switching Matrix 3.2 Gb / s
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Support for Jumbo-Frames up to 9216 Bytes
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Compliance with the RoHS Directive
• The Plug-and-play
Standards
• IEEE 802.3 10BASE-T Ethernet (copper twisted pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• ANSI / IEEE 802.3 NWay auto-negotiation of speed and mode of operation
• Flow Control IEEE 802.3h
Protocol
• CSMA / CD
Data transfer rate
Ethernet:
• 10 Mbit / s (half duplex)
• 20 Mbit / s (full duplex)
Fast Ethernet:
• 100 Mbit / s (half duplex)
• 200 Mbit / s (full duplex)
Topology
• Star
Network Cables
10BASE-T:
• UTP Category 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX:
• UTP Category 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 meters max.)
Media Interface Exchange
• Automatic identification of MDI / MDIX on all ports
Indicators
• The Port: Link / Activity / Speed
• Per device: Power
Switching Method
• Store-and-forward
MAC-address table
• 8K entries per device
MAC-addresses study
• Automatic update
Filtration rate / packet
• Ethernet: 14,880 packets per second. to port
• Fast Ethernet: 148,800 packets per second. to port
RAM buffer
• 256 Kbytes per device
נתונים פיזיים
Input power
• Switching power adapter with a level of performance "V", 5V / 1A
Power consumption
• Power on (standby): 2.36 W at AC and 1.2 W at DC
• Maximum: 2.69 W at AC, 1.6 W at DC
Operating temperature
• From 0 to 40 ˚ C
Storage temperature
• -10 To 70 ˚ C
Operating humidity
• From 10% to 90% (no condensation)
Storage Humidity
• 5% to 90% (no condensation)
Dimensions (W X D X B)
• 155.7 x 122 x 41 mm
Certificates
• CE Class B
• FCC Class B
• CB
• ROHS
• EuP
תקנים
הורדות
איורים
DES-1016/A1
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
