DGS-1008A/B1EOL EOS
מתג שולחני עם 8 פורטים 10/100/1000 עם חסכון בחשמל (מארז פלסטיק)
היכן לקנות
תאור
The implementation of technology D-Link Green
8-Port Gigabit Switch DGS-1008A is part of a new series of devices for SOHO from company D-Link, which use a technology called D-Link Green, which provides energy conservation, lower heat and longer product life without sacrificing performance or functionality. Energy-saving power adapter (certified standard Energy Star Level V), to minimize the use of hazardous substances (compliance directive RoHS) and recyclable packaging provides environmental friendliness of this switch.
Conservation of energy
8-Port Gigabit Switch DGS-1008A provides automatic saving of electricity in several ways. With the automatic power off when there is no connection ports are saving a significant amount of energy on the inactive port or ports that are connected to the computer is off.
Protecting the environment
8-Port Gigabit Switch DGS-1008A is designed taking into account the factor of protection of the environment and complies with Energy Star Level V, as well as compulsory regulations CEC and MEPS, which prescribe the use of energy-efficient power adapters. Also, the switch is designed in accordance with RoHS standards to minimize the use of hazardous materials and uses recycled packaging to help reduce waste by following the requirements of the directive WEEE.
מאפיינים כללים
Main functions
• Built-in D-Link Green
• Gigabit great solution for home networking and SOHO Networks
• 8-port 10/100/1000 Mbit / s Gigabit
• Switching matrix 16 Gbit / s
• Auto MDI / MDIX on all ports
• Switching method: store-and-forward
• Modes of semi-and full-duplex speeds for Ethernet / Fast Ethernet
• 802.3x Flow Control
• Support for Jumbo-Frames 9216 bytes
• Compliance with the RoHS Directive
• Installation of Plug-and-play
Standards
• IEEE 802.3 10BASE-T Ethernet (copper twisted pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper twisted pair)
• Auto-negotiation of ANSI / IEEE 802.3 NWay
Protocol
• CSMA / CD
Data transfer rate
• Ethernet
  - 10 Mbit / s (half duplex)
  - 20 Mbit / s (full duplex)
• Fast Ethernet
  - 100 Mbit / s (half duplex)
  - 200 Mbit / s (full duplex)
• Gigabit Ethernet
  - 2000 Mb / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
  - UTP Cat. 3, 4, 5/5e (100 m max.)
  - EIA/TIA-586 100-ohm STP (100 meters max.)
• 100BASE-TX, 1000BASE-T:
  - UTP Cat. 5/5e (100 m max.)
  - EIA/TIA-568 100-ohm STP (100 meters max.)
Media Interface Exchange
• Automatic identification of MDI / MDIX on all ports
Indicators
• The Port: Link / Activity / Speed
• Per device: Power
Switching Method
• Store-and-forward
MAC-address table
• 8K entries per device
MAC-addresses study
• Automatic update
Filtration rate / packet
• Ethernet: 14,880 packets per second. to port
• Fast Ethernet: 148,800 packets per second. to port
• Gigabit Ethernet: 1488000 packets per second. to port
RAM buffer
• 128K on device
נתונים פיזיים
Input power
• Power Adapter Level "V" 5 V / 1 A
Power consumption
• Input Power: 3.9 Tues AC, 3.06 V DC
MTBF
• 412 933 h
Operating temperature
• From 0 to 40 ° C
Storage temperature
• From -10 To 70 C
Operating humidity
• From 10% to 90% noncondensing
Storage humidity
• 5% to 90% noncondensing
Dimensions
• 128 x 68,5 x 25,4 mm
Certificates
• CE Class B
• FCC Class B
• ICES-003 Class B
• VCCI Class B
• C-Tick
• Anatel
• CCC
• LVD
• cUL / UL
תקנים
הורדות
איורים
DGS-1008A/B1/B
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
