DGS-1008D/H2EOL EOS
תאור
Gigabit speed network communications
Gigabit Switch with 8 ports D-Link DGS-1008D provides data and work online gaming at up to 2000 Mbit / s. Ethernet-ports are located on the front panel of the switch, which facilitates access to them, and the two color LEDs for each port to help you easily determine the status of the connection. DGS-1008D supports QoS, ensuring prioritization of delay-sensitive traffic and important for efficient transmission of multimedia data in real-time, high quality VoIP calls and online gaming. The switch is equipped with a slot for a Kensington lock on the rear panel that allows you to attach a device, such as a table.
Implementation of technology D-Link Green
Switch DGS-1008D support function to plug-and-play is a device which uses D-Link Green, providing energy savings, reduced heat emission and a longer product life without sacrificing performance or functionality. The switch supports IEEE 802.3az Energy-Efficient Ethernet (EEE), which is determined by when the connected computer is turned off or when there is no Ethernet-traffic, and power is turned off on inactive ports, thus saving a considerable amount of energy. The switch is able to regulate power consumption, determining the length of the cable is connected to the port. Both of these features work together to automatically save energy.
Protecting the environment
Switch DGS-1008D is designed with consideration of the environment and complies with Energy Star Level V, as well as compulsory regulations CEC and MEPS, which mandate the use of energy efficient power adapters. Also, the switch is designed in accordance with RoHS standards to minimize the use of hazardous materials and recycle used packaging
מאפיינים כללים
Main functions
• Built-in D-Link Green
• Inexpensive Gigabit solution for home networks and SOHO
• 8 x 10/100/1000 Mbit / s Gigabit
• Switch fabric 10/16 Gbit / s
• Auto MDI / MDIX on all ports
• The method of switching: store-and-forward
• the half-and full-duplex speeds for Ethernet / Fast Ethernet
• 802.3x Flow Control
• Support for Jumbo-frames 9000 bytes
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Cable Diagnostics
• Compliance with the RoHS Directive
• Installation of Plug-and-play
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• Auto-negotiation of ANSI / IEEE 802.3 NWay
• IEEE 802.3x Flow Control
• IEEE 802.1p QoS
Protocol
• CSMA / CD
Data transfer rate
• Ethernet
- 10 Mbit / s (half duplex)
- 20 Mbit / s (full duplex)
• Fast Ethernet
- 100 Mb / s (half duplex)
- 200 Mbit / s (full duplex)
• Gigabit Ethernet
- 2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
- UTP Cat. 3, 4, 5/5e (100m max.)
- EIA/TIA-586 100-ohm STP (100 meters max.)
• 100BASE-TX, 1000BASE-T:
- UTP Cat. 5/5e (100m max.)
- EIA/TIA-568 100-ohm STP (100 meters max.)
Media Interface Exchange
• Automatic detection of MDI / MDIX on all ports
Indicators
• The port: Link / Activity / Speed
• On the device: Power
Switching Method
• Store-and-forward
MAC-address table
• 8K
Study of MAC-addresses
• Automatic update
Filtration rate / packet
• Ethernet: 14,880 packets per second. to port
• Fast Ethernet: 148,800 packets per second. to port
• Gigabit Ethernet: 1488000 packets per second. to port
Buffer RAM
• 128K on device
