DGS-1016D/F1EOL EOS
מתג שולחני 16 פורטים 10/100/1000 עם ספק כח מובנה (מארז מתכת)
היכן לקנות
תאור
Think Green
D-Link’s DGS-1016D 16-Port Gigabit Switch and DGS-1024D 24-Port Gigabit Switch are part of a new series of SOHO/SMB devices that make use of D-Link’s 2nd generation Green Ethernet technology, providing more energy savings and a longer product life without sacrificing operational performance or functionality. Recyclable packaging and minimized use of harmful substances (RoHS compliant) make this switch truly environmentally friendly.
Conserves Energy
By building on the foundation of D-Link’s 1st generation of Green Ethernet technology, the 16/24-Port Gigabit Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance.
Environmentally Friendly
The 16/24-Port Gigabit Switch was designed with the environment in mind, and was built to follow RoHS standards to minimize use of hazardous materials. It uses recyclable packaging that helps reduce waste, and complies with the WEEE directive.
מאפיינים כללים
Key Features
• Technology D-Link Green
  - Define the connection status and cable length
• Inexpensive Gigabit solution for home networks and SOHO / SMB
• passive cooling system ensures quiet operation
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-frames are 9600 bytes
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Cable Diagnostics
• Support EEE +
• Compliance with the RoHS Directive
• Plug-and-play
Number of Ports
• 16 ports of Gigabit
Switching matrix
• 32 Gbit / s
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto speed and mode
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS (4 queues, strict mode)
• IEEE802.3az EEE
Protocol
• CSMA / CD
Data transfer rate
• Ethernet:
  10 Mbit / s (half duplex)
  20 Mbit / s (full duplex)
• Fast Ethernet:
  100 Mbit / s (half duplex)
  200 Mbit / s (full duplex)
• Gigabit Ethernet:
  2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
  UTP Cat. 3,4,5,5 s (100m max.)
  EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  UTP Cat. 5/5e (100m max.)
Media Interface Exchange
• Automatic detection of MDI / MDIX on all ports
Indicators
• Port: Link / Activity / Speed
• On the device: Power
Switching method
• Store-and-forward
MAC-address table
• 8K entries per device
Study of MAC-addresses
• Automatic update
Filtration rate / packet (half duplex)
• Ethernet: 14,880 packets per second. to port
• Fast Ethernet: 148,800 packets per second. to port
• Gigabit Ethernet: 1488000 packets per second. to port
Buffer RAM
• 512 Kbytes to the device
נתונים פיזיים
Power consumption
• Standby mode: 3.8 W
• Max.: 11.0 Tues
Heat release
• Standby: 12,958 BTU / h
• Max.: 37,51 BTU / h
Noise level
• 0 dB
MTBF
• 1087450 h
Operating temperature
• From 0 º to 40 º C
Storage temperature
• From -10 ˚ to 70 ˚ C
Humidity
• 5% to 90%, non-condensing
Measurements
• 280 x 180 x 44 mm
Weight
• 1.59 kg
Certificates
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• cUL
• CB
תקנים
הורדות
איורים
DGS-1016D/F1
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
