חיפוש מהיר
תכונות המוצר:
מתג שולחני 16 פורטים 10/100/1000 עם ספק כח מובנה (מארז מתכת)
EOL EOS
מאפיינים כללים:
Key Features
• Technology D-Link Green
  - Define the connection status and cable length
• Inexpensive Gigabit solution for home networks and SOHO / SMB
• passive cooling system ensures quiet operation
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-frames are 9600 bytes
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Cable Diagnostics
• Support EEE +
• Compliance with the RoHS Directive
• Plug-and-play
Number of Ports
• 16 ports of Gigabit
Switching matrix
• 32 Gbit / s
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto speed and mode
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS (4 queues, strict mode)
• IEEE802.3az EEE
Protocol
• CSMA / CD
Data transfer rate
• Ethernet:
  10 Mbit / s (half duplex)
  20 Mbit / s (full duplex)
• Fast Ethernet:
  100 Mbit / s (half duplex)
  200 Mbit / s (full duplex)
• Gigabit Ethernet:
  2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
  UTP Cat. 3,4,5,5 s (100m max.)
  EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  UTP Cat. 5/5e (100m max.)
Media Interface Exchange
• Automatic detection of MDI / MDIX on all ports
Indicators
• Port: Link / Activity / Speed
• On the device: Power
Switching method
• Store-and-forward
MAC-address table
• 8K entries per device
Study of MAC-addresses
• Automatic update
Filtration rate / packet (half duplex)
• Ethernet: 14,880 packets per second. to port
• Fast Ethernet: 148,800 packets per second. to port
• Gigabit Ethernet: 1488000 packets per second. to port
Buffer RAM
• 512 Kbytes to the device
נתונים פיזיים
Power consumption
• Standby mode: 3.8 W
• Max.: 11.0 Tues
Heat release
• Standby: 12,958 BTU / h
• Max.: 37,51 BTU / h
Noise level
• 0 dB
MTBF
• 1087450 h
Operating temperature
• From 0 º to 40 º C
Storage temperature
• From -10 ˚ to 70 ˚ C
Humidity
• 5% to 90%, non-condensing
Measurements
• 280 x 180 x 44 mm
Weight
• 1.59 kg
Certificates
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• cUL
• CB
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
