DGS-1008P/B1EOL EOS
מתג שולחני עם 8 פורטים במהירות ג'יגהבי, תמיכה ב PoE ותכונת חיסכון בחשמל (מארז מתכת)
היכן לקנות
תאור
Think Green Technology
8-Port Switch D-Link DGS-1008P Gigabit Ethernet allows home and office users to easily connect and supply power to Power over Ethernet (PoE) to devices such as wireless access points (APs), IP-cameras and IP-telephony and also be connected to other Ethernet-network devices (computers, printers, NAS). Designed specifically for home users and small businesses, this compact PoE switch operates quietly, allowing you to place it in virtually any room or office.
Power Over Ethernet (PoE)
4-port Switch DGS-1008P support the IEEE 802.3af standard PoE. For each PoE port is powered up to 15.4W, eventually switch can apply the general power to 52 watts, which enables users to connect to the DGS-1008P compatible devices with standard 802.3af. It also allows you to place the connected devices in remote places, regardless of the location of electrical outlets and minimize cabling.
Auto detect polarity MDI / MDI-X
Support auto polarity MDI / MDI-X on all ports eliminates the need for crossover cables or ports uplink. Each port can be connected directly to the server, hub, router, or switch using "direct» Ethernet-twisted-pair.
Reduced power consumption
8-Port Switch DGS-1008P support JavaScript D-Link GreenTM, providing lower power consumption and extends the life of the device without compromising with the performance and functionality of the device. Switch reduces power consumption depending on the status of connections and cable length. With the automatic power off when there is no connection port is saved a significant amount of energy on the inactive port or ports that are connected to the computer shuts down. The use of the passive cooling system ensures quiet operation and extends the life of the product.
מאפיינים כללים
Basic functions
• 8-port 10/100/1000 Mbit / s
• Auto MDI / MDIX on all ports
• Transmission Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• The Plug-and-play
• Built-in D-Link Green
• RoHS compliant
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Diagnosis cable
• Jumbo-frames 9720 KB
Switching matrix
• 16 Gb / s
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-TX Gigabit Ethernet
• ANSI / IEEE 802.3 NWay auto-negotiation and mode of operation
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS
PoE function
• IEEE 802.3af
• The power supply to the unit: up to 15.4 watts
• The maximum power budget: 52W
• Number of ports PoE / PoE power per port: 4 (Port 1-4) / 13 W
Data rate
• Ethernet:
  - 10 Mbit / s (half duplex)
  - 20 Mbit / s (full duplex)
• Fast Ethernet:
  - 100 Mbit / s (half duplex)
  - 200 Mbit / s (full duplex)
• Gigabit Ethernet:
  - 2000 Mbit / s (full duplex)
Topology
• Star
Interfaces transmission medium
• Automatic detection of MDI / MDIX on all ports
Network Cables
• 10BASE-T:
  - UTP Cat. 3/4/5 / 5e (100 m max.)
  - EIA / TIA-586 100 ohm STP (max 100 m).
• 100BASE-TX, 1000BASE-T:
  - UTP Cat. 5 / 5e (100 m max.)
Indicators
• At the port:
  - Link / Activity / Speed ​​/ PoE Status
• On the device:
  - Power / PoE Max
Transmission Method
• Store-and-forward
MAC-address table
• 4K recording device
Study of MAC-addresses
• Auto update
Filtration rate / packet
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
• Gigabit Ethernet: 1488000 packets per second. the port
Buffer RAM
• 192 Kbytes per device
נתונים פיזיים
Power consumption
• Power on. (Standby) / Max. (PoE off.): The input power: 2.0 W (AC)
• Max. (PoE incl.): The input power: 63.2 W (AC)
Power adapter
• Power Input: 100 ~ 240V AC, 50 / 60Hz
• Power Output: 48 V DC, 1.25 A (60 W)
Operating Temperature
• Device: 0º to 50ºC
• External power adapter: 0º to 40ºC
Storage temperature
• From -40˚ to 70˚C
Working Humidity
• From 0% to 95%, non-condensing
Humidity Storage
Dimensions
• 190 x 120 x 38 mm
Weight
• 0.73 kg
Certifications
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• LVD
תקנים
הורדות
איורים
DGS-1008P/B1/C
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
