חיפוש מהיר
תכונות המוצר:
מתג שולחני עם 8 פורטים במהירות 10/100Mbps (מארז מתכת)
EOL EOS
מאפיינים כללים:
Main function
• Cost-effective Fast Ethernet for home networks and SOHO
• 5/8 Port 10/100 Mbit / s Fast Ethernet
• Auto MDI / MDIX on all ports
• Switching Method : store-and-forward
• Modes of half-and full -duplex speeds for Ethernet / Fast Ethernet
• IEEE 802.3x Flow Control
• Jumbo Frames: 1536 bytes
• Supports 802.1p QoS: 2 queues , WRR Mode
• Compliance with the RoHS Directive
• Installing Plug-and-play
Switching matrix
• 1.6 Gbit / s
Standards
• IEEE 802.3 10BASE-T Ethernet ( twisted-pair copper )
• IEEE 802.3u 100BASE-TX Fast Ethernet ( twisted-pair copper )
• Auto-negotiation of ANSI / IEEE 802.3 NWay
Protocol
• CSMA / CD
Data rate
• Ethernet
  - 10 Mbit / s (half duplex)
  - 20 Mbit / s (full duplex)
• Fast Ethernet
  - 100 Mbit / s (half duplex)
  - 200 Mb / s (full duplex)
Topology
• star
Interfaces transmission medium
• Automatic detection of MDI / MDIX on all ports
Network cables
• 10BASE-T:
  - UTP Cat. 3/4/5/5e ( 100m max . )
  - EIA/TIA-586 100-ohm STP ( 100m max . )
• 100BASE-TX:
  - UTP Cat. 5/5e ( 100m max . )
  - EIA/TIA-568 100-ohm STP ( 100m max . )
Indicators
• Per port : Link / Activity
• On the device : Power
Switching method
• Store-and-forward
Table MAC- addresses
• 1K
MAC- addresses study
• Automatic updates
Speed ​​Packet Filtering / Forwarding
• Ethernet: 14,880 packets per second . the port
• Fast Ethernet: 148,800 packets per second . the port
RAM Buffer
• 768 KB per unit
נתונים פיזיים
Power input
• External power supply , 5 V / 1 A
Power consumption
• Power on . (standby) :
  - Input Power : 0.63 W DC 0.7 W AC
• Maximum:
  - Input Power : 2.1 W DC 2.7 W AC
Heat release
  - Power Input (AC ): 2,3884 BTU / h
• Maximum:
  - Power Input (AC ): 7,1652 BTU / h
operating temperature
0 to 50 C
Storage temperature
• From -10 to 70 C
Operating humidity
• From 10% to 90 % non-condensing
Humidity
• From 5% to 90 % non-condensing
Measurements
• 162 x 102 x 28 mm
Certifications
• FCC Class B
• ICES- 003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• CB
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
