DGS-1024D/F1EOL EOS
תאור
Think Green
D-Link’s DGS-1016D 16-Port Gigabit Switch and DGS-1024D 24-Port Gigabit Switch are part of a new series of SOHO/SMB devices that make use of D-Link’s 2nd generation Green Ethernet technology, providing more energy savings and a longer product life without sacrificing operational performance or functionality. Recyclable packaging and minimized use of harmful substances (RoHS compliant) make this switch truly environmentally friendly.
Conserves Energy
By building on the foundation of D-Link’s 1st generation of Green Ethernet technology, the 16/24-Port Gigabit Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance.
Environmentally Friendly
The 16/24-Port Gigabit Switch was designed with the environment in mind, and was built to follow RoHS standards to minimize use of hazardous materials. It uses recyclable packaging that helps reduce waste, and complies with the WEEE directive.
מאפיינים כללים
Main functions
• Innovative Technology 2nd Generation D-Link Green
• Inexpensive Gigabit solution for home and small office
• Quiet design with auto MDI / MDI-X on all ports
• Switching Method Store and Forward (store-and-forward)
• Full / half duplex for 10/100 Mbit / c
• IEEE 802.3x Flow Control
• Supports Jumbo Frames (9600 byte)
• Supports IEEE 802.1p QoS (4 queues, strict priority)
• Diagnosis of cable
• Compatibility with the directive ROHS
• Quick and Easy Installation (Plug-and-play)
Number of Ports
• 24 Gigabit ports
Switch fabric
• 48 Gb / s
Standards
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• IEEE 802.3ab 1000BASE-T Gigabit
• Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto-negotiation and speed of operation
• IEEE 802.1p QoS (4 queues, strict priority)
Protocol
• CSMA / CD
Data transfer rate
Ethernet:
• 10 Mbit / s (half duplex)
• 20 Mbit / s (full duplex)
Fast Ethernet:
• 100 Mbit / s (half duplex)
• 200 Mbit / s (full duplex)
Gigabit Ethernet:
• 2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
UTP category 3, 4, 5/5e (100 m)
EIA/TIA-586 100-ohm STP (100 m)
• 100BASE-TX, 1000BASE-T:
UTP Category 5/5e (100 m)
EIA/TIA-568 100-ohm STP (100 m)
Data exchange interface
• Auto-detect MDI / MDI-X on all ports
Indicators
• Port: Link / activity / Speed
• Per device: Power
Switching Method
• Store-and-forward
MAC-address table
• 8K entries, Automatic Updates
Filtration rate / packet (half duplex)
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 packets per second per port
• Gigabit Ethernet: 1,488,000 packets per second per port
Volume of buffer memory
• 512 Kb on your device
