DES-1005A/E2EOL EOS
תאור
The switch DES-1005A 5-port 10/100 Mbit / s to quickly create high-speed, reliable and efficient wired network at home or in the office. Unmanaged Switch DES-1005A is designed to increase the productivity of small work groups, while at the same time a high level of flexibility. This device allows users to simply plug any port to a 10/100 Mb / s to increase bandwidth, improve performance and quality of work with a lot of traffic. Connect the DES-1005A to multiple computers to share the files and folders, or connect it to a router to share an Internet connection.
High Speed Networking
The switch DES-1005A is equipped with easily accessible ports 10/100 Mbit / s auto-sensing and indicators for each port, allowing to quickly determine the status and activity of the compound. These ports determine the speed of the network and perform auto-negotiation between 10BASE-T and 100BASE-TX, as well as between modes of half-and full-duplex to provide each network device to the highest possible speed for viewing Web-pages, streaming video and online gaming. DES-1005A also supports auto polarity MDI / MDIX, allowing you to connect directly to each port on a server, hub, router, or switch using standard Ethernet-cable straight-through twisted-pair.
Easy installation with Plug and Play
DES-1005A supports Plug-and-Play, which does not require adjustment, easy installation, through which you can immediately connect multiple computers to share files, music and videos throughout your home or small office, or even to create the conditions for multiplayer games. 802.3x flow control on each port minimizes packet loss at the input port buffer overflow, which provides a reliable connection for all connected devices.
Environmentally friendly
The switch DES-1005A uses D-Link Green, which allows to significantly reduce energy consumption. If the computer is not connected to the port, or the connected computer is off, the port automatically goes into sleep mode, significantly reducing the energy consumed by the port, without interrupting the network. Furthermore, the switch automatically determine the length of Ethernet-connected cables and appropriately adjust their power consumption, while not affecting performance. This significantly reduces the overall power consumption, thereby reducing energy costs and reduce environmental impact.
Compact and quiet operation
DES-1005A is an elegant and compact design, so the switch can be placed in any easily accessible place so that it does not interfere with the user. Located on the rear panel of the device ports and power connector can remove the cables connected to a prominent place. DES-1005A does not use a fan, so that the switch operates quietly, but effectively, allowing you to watch streaming videos without delays or view Web-page.
מאפיינים כללים
Standards
• Auto-negotiation of ANSI / IEEE 802.3 NWay
• IEEE 802.3x Flow Control
• Energy savings IEEE 802.3az EEE
Switching matrix
• 1 Gbit / s
Topology
• Star
Protocol
• CSMA / CD
Data rate
• Ethernet
Half: 10 Mbit / s
Full-duplex 20 Mb / s
• Fast Ethernet
Half: 100 Mbit / s
Full-duplex 200 Mbit / s
Interfaces transmission medium
• Automatic detection of MDI / MDIX on all ports
Network cables
• 10BASE-T:
UTP Cat. 3/4/5/5e (100m max.)
EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX:
UTP Cat. 5/5e (100m max.)
EIA/TIA-568 100-ohm STP (100m max.)
Indicators
• Per port: Link / Activity
• On the device: Power
Switching method
• Store-and-forward
MAC-addresses table
• 2K entries per device
Study of MAC-addresses
• Automatic updates
Speed Packet Filtering / Forwarding
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
Buffer RAM
• 96 KB per unit
