DGS-1510-52EOL EOS
תאור
DGS- 1510 Series includes SmartPro Switch with 10G ports and is ideal for deployment in networks of small and medium-sized businesses (SME / SMB). DGS- 1510 Series provides a reliable connection and allows you to easily scale your existing network. Switches in this series are equipped with 16, 24 or 48 ports of 10/100/1000 Mbit / s and 2 Gigabit SFP ports and two 10G SFP +. The series includes DGS- 1510 switch PoE with 24 port 10/100/1000 Mbit / s . With support for this switch PoE simplifies installation VoIP- phones and network cameras .
PoE switches are ideal for corporate customers in the networks that use VoIP- services , wireless access points and network cameras . Switch DGS- 1510 -28P 24-port PoE support standard 802.3at ( up to 30 W output power per port) and provides power to various devices with PoE , allowing you to expand the existing network as your business grows and put to use the latest technology without excessive costs.
2-port 10G SFP +, used for stacking or uplink-Connection
Depending on the topology implemented stacking ( linear or circular ) to create a physical stack users may use one or two ports 10 -Gigabit SFP +. Using additional cables can be stacked up to 6 devices (288 Gigabit ports ) and get bandwidth at an affordable price . Furthermore, in the same stack can use any switch DGS- 1510 series in order to ease of configuration , management, and troubleshooting .
Versatility and Scalability
DGS- 1510 Series supports the Single IP Management (SIM), which allows you to manage a virtual stack of 32 devices through one IP- address . This feature greatly simplifies the management of both small workgroups and telecommunications centers , while allowing the network to scale and increase capacity if necessary. The SIM allows you to use only one IP- address and provides stacking switches over Ethernet instead of using the ports for stacking or uplink- physical connection. In this case there is no dependence on special cables or territorial location , which may limit the functionality of the topology using other stacking technology .
Advanced Layer 2 features
Series Switches DGS- 1510 series supports Layer 2 features including IGMP Snooping, Port Mirroring, Spanning Tree and Link Layer Discovery Protocol (LLDP). IEEE 802.3x Flow Control allows you to directly connect servers to the switch for fast , reliable data transfer . Maintaining at 2000 Mbit / s in full duplex mode , the switches provide high-speed transmission for connecting jobs with minimal data loss . Switches support function and Cable Diagnostics function Loopback Detection. Loopback Detection is used to determine the loop and automatically disable the port or VLAN, in which a loop was detected . Cable Diagnostics is designed to determine the quality of the copper cables and the type of cable error .
QoS, bandwidth management
Switches DGS- 1510 Series supports Auto Surveillance VLAN (ASV) , and Auto Voice VLAN, and are the ideal solution for deploying VoIP and video surveillance. Auto Surveillance VLAN - this is a new , industry-leading technology built into the switches Smart D-Link. This technology combines data and video transmission through a single switch SmartPro, reducing thus the cost of equipment and facilities . ASV also ensures high-quality video in real time and control without compromising the transmission of conventional network data . Auto-sensing equipment connected VoIP allows you to put " voice " traffic to a dedicated VLAN. Thanks to the highest priority and individual VLAN, this feature provides high-quality and secure transmission of VoIP- traffic. In addition , DSCP marks packets with Ethernet- purpose network traffic of different services . In addition , bandwidth management feature allows network administrators to reserve bandwidth for a variety of applications that require high bandwidth or highest priority .
Network Security
Function D-Link Safeguard Engine protects the switches against traffic flooding caused by virus . Authentication based on 802.1X port allows you to use an external RADIUS server to authenticate users . In addition, the Access Control List (ACL) enhances network security and helps to protect your network by filtering traffic from unauthorized MAC- address or IP- addresses. Switches DGS- 1510 series support the prevention of attacks ARP Spoofing, protects against network attacks Ethernet, which can cause a change in traffic or delay by sending false ARP- posts . To prevent ARP Spoofing attacks switch uses the Packet Control ACLs to block packets containing false ARP- posts. To improve security, use the function DHCP Server Screening, prohibiting unauthorized access DHCP- servers.
Support for IPv6
In DGS- 1510 series supports functional IPv6, including MLD Snooping, IPv6 ACL / QoS and IMPBv6, which promotes easy equipment integration in next-generation networks . In addition , this series supports both protocol stacks IPv4/v6, allowing switches to act as a bridge between IPv4 and IPv6. All models DGS- 1510 successfully passed the certification IPv6 Logo Phase 2 , which proves their full conformance and interoperability when using IPv6- networks.
Management Flexibility
Using Web-based switch management DGS- 1510 series and utility D-Link Network Assistant allows administrators to remotely manage the network port level . Utility D-Link Network Assistant supports automatic detection and display switches the D-Link Web Smart, belonging to the same network segment L2. Web-based interface provides access to the switch from anywhere on the network without the need to enter IP- address or subnet mask that allows you to configure the basic setup and found devices , including password changes and software updates . Switches DGS- 1510 series also support the program D-View 6.0 and Command Line Interface (CLI) via the console port . D-View 6.0 is a network management system that lets you control the most important parameters such as performance, reliability , flexibility and security . Management command-line interface (CLI) via the console port and Telnet. This makes it easy to configure basic settings , passwords , configuration files and software.
Routing Support
Switches DGS- 1510 Series supports static routing , which creates an opportunity for communication between different groups of users in different segments of the VLAN network. Since switches can control the routing within the local network , handling external traffic routing only can instruct a network router .
Saving Energy
Switches DGS- 1510 series support JavaScript D-Link Green 3.0, which provides energy savings without sacrificing performance or functionality . Support standard 802.3az Energy Efficient Ethernet allows you to automatically reduce power consumption with a small amount of traffic. The power saving feature automatically powers down ports , indicators and off the system from hibernation on a schedule. Schedule can also be applied to a switch that supports PoE, allowing you to avoid unnecessary energy consumption during the downturn .
מאפיינים כללים
Interfaces
• IEEE 802.3 10BASE-T Ethernet, IEEE 802.3u 100BASE-TX Fast Ethernet, IEEE 802.3ab 1000BASE-T Gigabit Ethernet, 802.3ae 10 GbE, IEEE 802.3x flow control for full-duplex mode , Auto Detect
Number of ports
• 48-port 10/100/1000 Mbit / s ,
• 2-Port Gigabit SFP,
• 2-port 10G SFP +
Network cables
• UTP Cat. 5 , Cat. 5e (max. 100 m)
• EIA/TIA-568 100th STP ( max. 100 m)
Polu-/polny duplex
• Full / half duplex for 10/100 Mbit / s
Auto detect cable polarity
• Automatically or manually configurable MDI / MDIX
Performance
• Switching matrix: 140 Gbit / s
Transmission method
• Store-and-forward
MAC- address table
• 16 000 entries per device
Updating MAC- address
• Up to 512 static MAC- address records
• Enable / disable auto-learning of MAC- addresses
Speed forwarding 64- byte packets
• 104,16 Mpps
Packet buffer
• 3 MB on device
Software Functions
• Virtual Stacking
• D-Link Single IP Management
• Up to 32 devices in a virtual stack
• Bandwidth: up to 20 GB
• Physical Stacking
• Linear or ring topology
• The bandwidth in full duplex mode : up to 40 GB
• Up to 6 devices in the stack
Function L2
• Table MAC- addresses : 16K
• Flow Control
• 802.3x Flow Control
• HOL Blocking Prevention
• Jumbo- frames up to 9000 bytes
• IGMP Snooping
• IGMP v1/v2 Snooping
• IGMP v3 awareness
• Supports up to 512 IGMP- groups
• Supports up to 128 static multicast groups
• IGMP on VLAN
• Supports IGMP Snooping Querier
• IGMP Snooping Fast Leave on the basis of unit
• MLD Snooping
• Supports MLD v1/v2 awareness
• Support groups 512
• Support 128 static multicast groups
• MLD Snooping VLAN-based
• MLD Fast Leave on the basis of unit
• MLD Snooping Querier
• Spanning Tree Protocol
• 802.1D STP
• 802.1w RSTP
• 802.1s MSTP
• Loopback Detection
• 802.3ad Link Aggregation
• Max . 32 groups per device / 8 ports per group
• Port Mirroring
• Support 4 groups mirroring
• One-to-One, Many-to-One
• Mirroring support for inbound / outbound / traffic in both directions
• Multicast Filtering
• Forward all unregistered groups
• Filters all unregistered groups
• LLDP, LLDP-MED
VLAN
• 802.1Q Tagged VLAN
• Group VLAN: 4K
• Custom VID: 0 ~ 4094
• Asymmetric VLAN
• Auto Voice VLAN
• Auto Surveillance VLAN
Quality of Service (QoS)
• 802.1p Quality of Service
• Processing Queues
• Strict priority
• Weighted priority (WRR)
• 8 queues per port
• Bandwidth Management
• Port-based (Ingress / Egress , with a minimum value of 64 kbit / s for 10/100/1000 BASE-T)
• CoS based on:
• 802.1p Priority Queues
• VLAN
• MAC- address
• Ether type
• IP- address
• DSCP
• Protocol Type
• Non TCP / UDP port
• DSCP for IPv6 traffic class
• IPv6 flow label
L3 functions
• ARP
• 256 static ARP
• Supports Gratuitous ARP
• IPv6 Neighbour Discovery (ND)
• Default Route
• Static Routing
• Max . count of records static routes IPv4: 64
• Max . count of records static routes IPv6: 32
Access Control Lists (ACL)
• ACL based on:
• VLAN
• MAC- address
• Ether type
• IP- address
• DSCP
• Protocol Type
• IPv6 flow label
• Actions ACL
• Allow
• Reject
• Max . count of ACLs : 256
• Max . Number of rules : 768
• One or more ports ( each rule )
• ACL schedule
• ACL Statistics
Security
• Port Security
• Supports up to 128 MAC- addresses per port
• Protection from the broadcast / multicast / unicast storm
• Dynamic ARP Inspection
• Static MAC- address
• D-Link Safeguard Engine
• DHCP Server Screening
• Prevent ARP Spoofing Attacks
• Max . Number of records: 64
• SSH
• Support v2
• Support IPv4/IPv6
• SSL
• Support v1/v2/v3
• Support IPv4/IPv6
• Traffic Segmentation
• IP-MAC-Port Binding
• DHCP snooping
• IP Source Guard
• Dynamic ARP inspection
• DHCPv6 Guard
• RA Guard
• IPv6 Snooping
• IPv6 Source Guard
• Prevent DoS attacks
AAA
• Mixed Authentication
• 802.1X and MAC- address
• Supports local database / RADIUS- server
• Support for EAP, OTP, TLS, TTLS, PEAP
• Based Access Control Web (WAC)
• Access control based on port
• Based Access Control node
• Dynamic VLAN Assignment
• Access control based on MAC- address (MAC)
• Access control based on the Japanese Web- interface (JWAC)
OAM
• Diagnostic cable
• Restore the factory default settings
Management
• CLI
• Telnet- server
• TFTP- client
• IPv6 Neighbor Discovery
• Configurable MDI / MDIX
• SNMP
• Supports v1, v2c, v3
• SNMP Trap
• System Log
• Max . count of log entries : 10,000
• DHCP- client
• Support Utility D-Link Network Assistant
• SNTP
• ICMPv6
• Support protocol stack IPv4/v6
• Automatic configuration via DHCP
• RMON v1
Technology D-Link Green 3.0
• Energy savings
• Depending on the status of the connection
• Turn off the indicators or ports
• Sleep mode
• PoE on the basis of time (only for models with PoE)
