DGS-1100-08
מתג מנוהל WEB עם 8 פורטים במהירות ג'יגהביט
היכן לקנות
תאור
Switch DGS-1100 series is an affordable solution for small and medium business (SMB) and organizations in the state that are not IT-specialists. DGS-1100 is a suitable solution for enterprise networks, such as branch offices and meeting rooms, where a simple operation. Each model comes in a compact desktop metal case and is equipped with 8, 16 or 24 Gigabit Ethernet ports.
Energy saving technology D-Link Green
The DGS-1100 to meet the standard IEEE802.3az Energy Efficient Ethernet, consuming less power with a small amount of traffic. Installation of devices EEE provides small and medium-sized businesses save money by reducing costs associated with the purchase of equipment for cooling. Switch DGS-1100 series support the technology D-Link Green, which provides an automatic reduction in power consumption. If the automatically determined by the length of the attached cable is less than 20 meters, the switch reduces power consumption. In addition, the switch determines the connection status of each port, and provides automatic power-off of inactive ports.
Flexible management
EasySmart switches provide a simple and easy network management utility SmartConsole or via web-interface. SmartConsole Utility allows users to locate the family of switches, D-Link Smart in the same network segment L2. Using this tool eliminates the need to change the IP-address of the computer and provides easy initial setup switches Smart. Switches within the same network segment and connected to a local computer user, are displayed on the screen for instant access. In this configuration, advanced settings are available and the basic configuration of discovered devices, such as password changes. Easy to use graphical web-based interface allows network administrators to remotely manage the network at the port level.
Technology Surveillance VLAN and bandwidth control
Switch DGS-1100 series support the technology Surveillance VLAN, which is an ideal solution for video surveillance. Surveillance VLAN - is the latest technology for video surveillance systems work, and a centralized data transfer via a switch DGS-1100, thereby reducing, the costs associated with the acquisition of additional equipment. In addition, the bandwidth management allows network administrators to reserve bandwidth for a variety of applications requiring high bandwidth, or to provide them with the highest priority.
Troubleshooting
The functions include network maintenance and diagnostics Loopback Detection cable that allows network administrators to quickly and easily find and fix network problems. Loopback Detection is used to determine the loop and automatically disable the port on which a loop was detected. Cable diagnostic feature designed to determine the types of copper cables, as well as the type of cable faults.
Advanced Features
Series Switches DGS-1100 supports advanced security features such as Static MAC, Storm Control and IGMP Snooping. Static MAC function allows you to disable auto-learning for selected ports and put the static MAC-address on the ports, allowing administrators allow network access only to authorized devices. Storm control function limits the number of multicast, broadcast and unknown unicast frames that receives and forwards the IGMP Snooping ustroystvo.Funktsiya reduces multicast traffic and increases network performance.
מאפיינים כללים
Size
• Table size
Number of Ports
• 8-port 10/100/1000BaseT
Functions of the Port
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
• Supports full / half duplex (for half-duplex 10/100 Mbit / s, full duplex 1000 Mbit / s)
• Auto-negotiation
• Auto MDI / MDIX
• IEEE 802.3x Flow Control in full duplex mode
• IEEE 802.3az
• Blocking Prevention Head-of-line
Performance
• Capacity of the switch 16 Gbit / c
• The maximum speed of advance packets: 11.9 Mpps
• MAC-Address Table: 8K entries per device
• Buffer RAM: 256 KB
• Flash-memory: 2 MB
Indicators
• Power (per device)
• Link / Activity / Speed ​​(per port)
Functions of level 2
• MAC Address Table: 8K
• Flow Control
  - 802.3x Flow Control
  - HOL blocking prevention
• IGMP Snooping
  - IGMP v1/v2 Snooping
  - Supports up to 32 IGMP-group
• The Loopback Detection
• Filtering of multicast
  - Redirect all non-registered groups
  - Filtering of unregistered groups
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
• Static Trunk: 2 groups, 2-4 ports per group
• The Cable Diagnostics
• Port Mirroring
  - One-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
VLAN
• Based on the port
• 802.1Q tagged VLAN
• Surveillance VLAN
• Management VLAN
• Group VLAN
  - Max. 32 static VLAN
  - Max. 4094 VIDs
Quality of Service (QoS)
• 802.1p
• Max. 4 queues per port
• Processing Queue
  - Strict
  - Weighted Round Robin (WRR)
• Bandwidth Management
  - Based on the port (inbound / outbound, selected from the list with a minimum of 8 kbit / s)
Security
• Static MAC-address up to 32 entries
• Protection from the broadcast / multicast / unicast storm
Management
• Web-interface GUI (Support for IPv4)
• Utility SmartConsole
• BootP / DHCP-client
Technology D-Link Green
• Reduce energy consumption according to:
  - Status of the connection
  - The cable length
• RoHS 6
Compliance with RFC
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP-client
• RFC 1542 BootP / DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
נתונים פיזיים
Power consumption
• Mode Standby: 0,62 Tues
• Maximum: 4,58 Tues
Input Power
• External universal power supply from 100 to 240 VAC, 50/60 Hz
MTBF (in hours)
• 503.585 h
Noise level
• 0 dB
Heat release
• 2,936 BTU / hour
Weight
• 0.42 kg
Dimensions
• 171 x 98 x 28 mm
Fans
• No
Operating temperature
• From 0 to 40 ° C
Storage temperature
• From -10 to 70 C
Operating Humidity
• 10 to 95% (no condensation)
Eelectromagnetic compatibility
• FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Security
• cUL, CE LVD
תקנים
הורדות
איורים
DGS-1100-08/B
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
