חיפוש מהיר
תכונות המוצר:
מתג שולחני עם 8 פורטים PoE במהירות 10/100Mbps (מארז מתכת)
מאפיינים כללים:
Interfaces
• 8-port 10 / 100Base-TX with PoE
Indicators
• Link / Activity (per port)
• Power (per device)
Standards and Protocols
• IEEE 802.3 10Base-T Ethernet (copper twisted pair)
• IEEE 802.3u 100Base-TX Fast Ethernet (copper twisted pair)
• Auto-ANSI / IEEE 802.3 NWay
• IEEE 802.3x Flow Control
• IEEE 802.3af Power over Ethernet
• IEEE 802.3at Power over Ethernet
Data transfer rate
• Fast Ethernet:
   • 100 Mbit / s (half duplex)
   • 200 Mbit / s (full duplex)
• Ethernet:
   • 10 Mbit / s (half duplex)
   • 20 Mbit / s (full duplex)
Filtration rate / packet
• 148,800 packets per second. the port (for 100Base-TX)
• 14,880 packets per second. the port (for 10Base-T)
Switching matrix
• 1,6 Gbit / s
Network Cables
• 10Base-T:
   • UTP Cat. 3/4/5 / 5e (100 m max.)
   • EIA / TIA-586 100 Ohm STP (100 m max.)
• 100Base-TX:
   • UTP Cat. 5 / 5e (100 m max.)
   • EIA / TIA-568 100 ohm STP (max 100 m).
Interfaces transmission medium
• Auto MDI / MDIX on all ports
Transmission Method
• Store-and-forward
Table MAC-addresses
• 2K entries per device
Study of MAC-addresses
• Automatic updates
Buffer RAM
• 96 KB
• Star topology
Protocol
• CSMA / CD
נתונים פיזיים
Weight
• 1,65 kg
• Dimensions 280 x 125,8 x 44 mm
Power
• Power Adapter
• Input: 100-240 VAC, 50/60 Hz
Power consumption
• Power on. (Standby, PoE off.)
• Input supply: 6.9 W max. (AC)
• Max. (PoE incl., 140 W)
• Power Input: 146 W (AC)
Power budget PoE
• 140 W
Heat release
• Input supply: 22,67 BTU / h (AC)
• Input supply: 486,7 BTU / h (AC)
MTBF
• 64,207 hours
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -40 ° to 70 ° C
Humidity
• Operating: 0% to 95% (non-condensing)
• Storage: 0% to 95% (non-condensing)
Certifications
• FCC
• CE
• CB
• CCC
• UL / cUL
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
