חיפוש מהיר
תכונות המוצר:
מתג מנוהל עם 20 פורטים במהירות ג'יגהביט, ארבע יציאות משולבות ג'יגהביט/אופטי (SFP) ושתי יציאות 10G SFP
מאפיינים כללים:
Ports
• 20 ports of 10/100 / 1000BASE-T
• 4 Combo 10/100 / 1000BASE-T / SFP
• 2-port 10G SFP +
Reserve power supply
• DPS-200 3
Console port
• RJ-45
Performance
• Switching Matrix: 88 Gbit / s
• Speed ​​forwarding 64-byte packets: 65,48 Mpps
• MAC-address table: 16K entries
• DRAM to CPU: 128 MB
• Packet Buffer: 1.5 MB
• Flash-Memory: 32 MB
• Jumbo-frame: 12.288 Bytes
Software features
• Virtual Stacking:
  - Technology D-Link Single IP Management (SIM)
  - Up to 32 devices in a virtual stack
L2 Features
• Flow control:
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo-frame up to 12 Kbytes
• Spanning Tree Protocols:
  - 802.1D STP
  - 802.1w RSTP
  - 802.1w MSTP
  - BPDU Filtering
  - Root Restriction
• The Loopback Detection
• Link Aggregation:
  - Supports standards 802.1AX and 802.3ad: Max. Number of groups - 13, 8 ports per group
• Port mirroring:
  - Supports 1 Mirroring group
  - One-to-One, Many-to-One, through flow (ACL)
• Ethernet Ring Protection Switching (ERPS)
• Layer 2 Tunneling Protocol (L2PT)
Multicast Layer 2
• IGMP Snooping:
  - IGMP v1 / v2 / v3 Snooping
  - Support for 1024 IGMP-groups
  - Fast Leave port-based / node
  - Function Report Suppression
• IGMP Authentication
• IGMP / MLD Proxy Reporting
• Limit multicast on IP-addresses (IGMP-filtering)
• MLD Snooping:
  - MLD v1 / v2 Snooping
  - Supports up to 1024 groups
  - Fast Leave-based site
VLAN
• Group VLAN:
  - Max. 4094 VLAN groups
  - VLAN-based port
  - VLAN MAC-based address (MAC-Based)
• GVRP
  - Supports up to 255 dynamic VLAN groups
• 802.1v Protocol VLAN
• 802.1Q Tagged VLAN
• Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
  - Selective Q-in-Q
• ISM VLAN
• VLAN Translation
• Voice VLAN
• VLAN Trunking
• Asymmetric VLAN
Function level 3
• Support for 1024 ARP entries
• Gratuitous ARP
• The default route
Quality of service (QoS)
• 8 queues per port
• DSCP
• 802.1p
• Bandwidth management:
  - Based on the port (incoming / outgoing, min. Step up to 64 kbit / s)
  - On the basis of the flow (incoming / outgoing, min. Step up to 64 kbit / s)
  - For the output queue (min. Step up to 64 kbit / s)
• Mechanisms for queuing:
  - Strict Priority Queue (SPQ)
  - Weighted Round Robin (WRR)
  - Deficit Round Robin (DRR)
  - Strict + WRR
• Support for the following streams:
  - Tagging 802.1p priority
  - Tagging priority TOS / DSCP
• QoS based on time
• Three-color marking
  - TrTCM
  - SrTCM
• CoS based on:
  - 802.1p Priority Queues
  - VLAN ID
  - MAC-address
  - Ether type
  - IPv4 / v6-address
  - Class IPv6 traffic
  - IPv6 flow label
  - DSCP
  - The type of protocol
  - TCP / UDP-port
  - Contents of the package, user-defined
Access Control Lists (ACL)
• ACL on the basis of:
  - Port Switch
  - 802.1p priority
  - VLAN ID
  - MAC-address
  - Ether Type
  - IPv4 / v6-address
  - IPv6 flow label
  - DSCP
  - Non-TCP / UDP-port
• Support for up to 1,024 access rules
• ACL on the basis of the time
• ACL statistics
• CPU Interface Filtering
Security
• SSH v1 / v2
• SSL v1 / v2 / v3
• Port Security
  - Up to 64 MAC-addresses per port
• Protection against broadcast / multi-address / unicast storm
• IP-MAC-Port Binding (IMPB):
  - Checking the ARP-packets
  - Check the IP-packet
  - DHCP Snooping
• Traffic Segmentation
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• Filtering NetBIOS / NetBEUI
• DHCP Server Screening
• Filtering DHCP-enabled clients
• Prevention of ARP Spoofing Attacks
• Protection against attacks BPDU
• Prevention of DoS attacks
AAA
• 802.1X:
  - Access control based on port
  - Based Access Control Node
  - Dynamic VLAN assignment
• Access Control MAC-based (MAC):
• Access control based on Web (WAC) 2
• Access control based on the Japanese Web-based interface (JWAC)
• Compound Authentication2
• Microsoft® NAP (IPv4 / v6)
  - Support for 802.1x NAP
  - Support for DHCP NAP
• Guest VLAN
• RADIUS (IPv4 / v6)
• TACACS
• TACACS +
• XTACACS +
• Trusted Host
• RADIUS Accounting
• TACACS + Accounting
• Accounts with 4 levels of access rights
OAM
• Diagnosis cable
• 802.3ah Ethernet Link OAM
• 802.3ah D-link Unidirectional Link Detection (DULD)
• Y.1731 OAM2
• sFlow
Green Technology
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Reduced energy consumption:
  - Based on the connection status
  - Depending on the cable length
• Turn off the indicators
• Turning off the power ports
• A port in the standby mode
• Hibernate
Management
• Web-interface (Support IPv4 / v6)
• Command Line Interface (CLI)
• Telnet-server / client (Supports IPv4 / v6)
• TFTP-client (Supports IPv4 / v6) 2
• FTP-client (Supports IPv4 / v6)?
• ZModem
• Record of commands in the log (Command Logging)
• SNMP v1 / v2c / v3
• SNMP Traps
• System Log
• SMTP
• RMON v1:
  - Support groups 1,2,3,9
• RMON v2:
  - Support group ProbeConfig
• 802.1AB LLDP
• LLDP-MED
• BootP / DHCP-Client
• Auto Configuration via DHCP
• DHCP Relay (Supports IPv4)
• DHCP Relay Option 60, 61 and 82
• DHCP Client Option 12
• Add a label PPPoE Circuit-ID
• Support for multiple versions of software
• Flash File System
• CPU Monitoring
• View memory usage
• NTP / SNTP
• Use the debug (Debug Command)
• Restoration of the password
• Password Encryption
• Ping (Supports IPv4 / v6)
• Traceroute
• Microsoft® NLB (Network Load Balancing)
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1213 MIB II
• RFC1493, 4188 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC1901-1908, 3418, 3636, 1442, 2578 SNMPv2 MIB
• RFC271,1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674, 4363 802.1p MIB
• RFC2233, 2863 Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC3298 MIB for Diffserv
• RFC 2925 Ping and Traceroute MIB
• Redundant configuration
• Ability to work via TFTP
• Trap MIB
• RFC 2465 IPv6 MIB
• RFC 2466 ICMPv6 MIB
• RFC 2737 Entity MIB
• Private MIB
• RFC 3289 DIFFSERV MIB
Standards IETF®
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC793 TCP
• RFC826 ARP
• RFC1338, 1519 CIDR
• RFC2474, 3168, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC1321, 2284, 2865, 2716, 1759, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC2464 IPv6 Neighbor over Ethernet and definition
• RFC3513, 4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4 / IPv6 dual stack function
• IPv6 Ready Logo Phase 2
נתונים פיזיים
MTBF (hours)
• 472842.5
Noise level
• 47.8 dB
Heat release
• 100,94 BTU / hr
Input supply
• 100-240 VAC, 50-60 Hz
• Built-in universal power supply
Max. power consumption
• 29.6 W
Dimensions
• 441 x 209,9 x 44 mm
Weight
• 2.01 kg
Fans
• Smart Fan
ESD protection
• All Ethernet ports are equipped with integrated protection against static electricity to 6 kV
Operating temperature
• From 0 to 50 C
Storage temperature
• -40 To 70 C
Working Humidity
• From 10% to 90% non-condensing
Humidity Storage
• From 5% to 90% non-condensing
EMI
• CE, FCC, IC, C-Tick, VCCI, BSMI
Security
• CB, UL / cUL, BSMI
Certifications
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
