חיפוש מהיר
תכונות המוצר:
מתג Metro מנוהל עם 5 פורטים במהירות ג'יגהביט ויציאה אחת ג'יגהביט/אופטי (SFP)
מאפיינים כללים:
Number of Ports
• Five ports 10/100 / 1000BASE-TX
• One port 100/1000 SFP
Performance
• Switching Matrix: 12 Gbit / s
• Speed ​​forwarding 64-byte packets: 8,9 Mpps
• Size of MAC address table: 4 K
• SDRAM for CPU: 128 MB
• packet buffer: 128 KB
• Flash-Memory: 16 MB
• Jumbo-frames: 9216 bytes
Indicators
• Power (per device)
• Link / Activity / Speed ​​(per port)
Power consumption
• Mode Standby: 3,62 Watts
• Maximum power consumption: 7.08 W
Features 2 levels
• MAC-address table: 4K
• 802.3x Flow Control
   o HOL Blocking Prevention
• Loopback Detection
• Port Mirroring
   o Support for one group
   o One-to-One
   o Many-to-One
Multicast Layer 2
• IGMP Snooping
   o IGMP v1 / v2 Snooping, v3 Awareness
   o Support 32 groups
   o IGMP Snooping Fast Leave-based port
• Authentication IGMP
   o Limited IP Multicast (Limit multicast on IP-addresses)
• MLD Snooping
   o MLD Snooping v1, v2
   o Support groups of 32 MLD Snooping
   o MLD Snooping Fast Leave-based port
VLAN
• 802.1Q Tagged VLAN
• VLAN Groups
   o Support for 32 static VLAN groups
• Managing VLAN
• VLAN-based port
• ISM VLAN
• Double VLAN (Q-in-Q)
   o Q-in-Q based on the port (Port-Based)
Quality of service (QoS)
• 4 queues per port
• Processing Queue
   o Strict Priority
   o Weighted Round Robin (WRR)
• Bandwidth Management
   o On the basis of a port (incoming / outgoing, with a minimum of 64 kbit / s)
• CoS based on:
   o 802.1p
   o DSCP
   o IPv6 traffic class
Access Control Lists (ACL)
• ACL based
   o Port Switch
   o 802.1p priority
   o VLAN ID
   o MAC-address
   o Ether type - TOS
   o IPv4 / v6-address
   o DSCP
   o The type of protocol
   o Non-TCP / UDP port
Security
• Port Security
   o Up to 64 MAC addresses per port
• Traffic Segmentation
• Protection from the broadcast / multicast / unicast storm
• D-Link Safeguard Engine
AAA
• 802.1X
   o Access Control based on port
   o Based Access Control host
• Guest VLAN
• Support local database / RADIUS-server
• Support for RADIUS Accounting
• 4 levels of user access rights
OAM
• Diagnostic cable
• 802.3ah
Management
• Web-interface
• Command Line Interface (CLI)
• Telnet-server
• TFTP-client
• SNMP v1 / v2c / v3
• SNMP Traps
• System Log
• RMON v1
• Support groups 1,2,3,9
• LLDP
• BootP / DHCP-Client
• Automatic configuration via DHCP
• DHCP Relay for IPv4 / IPv6
• DHCP Relay Option 82
• DHCPv6 Relay Option 37
• Tagging PPPoE Circult-ID
• SNTP
• View CPU utilization
• Encrypt passwords
MIB
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2233, 2863 IF MIB
• Private MIB
Standard IETF
• RFC768 UDP
• RFC791 IP
• RFC792,2463, 4443 ICMPv4
• RFC793 TCP
• RFC826 ARP
• RFC 2474, 3260 Determination of the DS field in the IPv4 header and IPv6
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
• RFC1981, RFC2460, RFC2461,4861, RFC2462,4862, RFC2464, RFC3513,4291, RFC2893,4213
נתונים פיזיים
Size
• 190 x 120 x 38 mm
Power supply
• External power adapter that works from the network 100-240V, 50-60 Hz with an output of 12V / 1A
MTBF
• 459.420 hours
Noise level
• 0 dB
Heat release
• 24,16 BTU / hr
Dimensions
• 190 x 120 x 38 mm
Weight
• 0.42 kg
Ventilation system
• passive
Operating Temperature
• From 0 to 40 C
Storage temperature
• -40 To 70 C
Humidity
• From 10% to 90%
EMI
• CE Class A
Security
• CE LVD, UL / cUL
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
