חיפוש מהיר
תכונות המוצר:
מתג מנוהל עם 44 פורטים במהירות ג'יגהביט, ארבע יציאות משולבות ג'יגהביט/אופטי (SFP) ושתי יציאות 10GBase-CX4
מאפיינים כללים:
Interfaces
Ports
• 44 port 10/100 / 1000BASE-T
• 4 Combo 10/100 / 1000BASE-T / SFP
• 2-port 10G c CX4 connector
Reserve power supply
• DPS-500 / DPS-500DC
Console port
• RJ-45
Slot for SD-cards
• 1
Performance
• Switching Matrix: 88 Gbit / s
• Speed ​​forwarding 64-byte packets: 101.19 Mbit / s
• Packet Buffer: 2 MB
• Flash-Memory: 32 MB
Software version Routed Image (RI)
L2 Features
• MAC-address table: 16K entries
• Flow Control
  o 802.3x Flow Control
  o HOL Blocking Prevention
• Jumbo-frame up to 13 Kbytes
• 802.3ad Link Aggregation
  o Max. 32 device group, 8 gigabit ports per group
• Spanning Tree Protocols
  o 802.1D STP
  o 802.1w RSTP
  o 802.1s MSTP
  o BPDU Filtering
  o Root Restriction
• The Loopback Detection
• Ethernet Ring Protection Switching (ERPS)
• Port Mirroring
  o One-to-One
  o Many-to-One
  o On the basis of the flow
  o RSPAN
Multicast Layer 2
• IGMP Snooping
  o IGMP v1 / v2 / v3 Snooping
  o Support for IGMP-1024 groups
  o Fast Leave on the basis o port / unit
  o Report Suppression
• Limit multicast on IP-addresses
  o up to 24 profiles filtering IGMP, 32 address range to the profile
• MLD Snooping
  o MLD v1 / v2 Snooping
  o Support for up to 1024 groups
  o Fast Leave port-based / flow
Function level 3
• Max. IP-number of interfaces 16
• ARP Proxy
• IPv6 Neighbour Discovery (ND)
VLAN
• VLAN Groups
  o Max. 4K VLAN groups
• GVRP
  o Support for up to 255 dynamic VLAN groups
• 802.1Q Tagged VLAN
• VLAN-based port
• 802.1v Protocol VLAN
• Voice VLAN
• VLAN MAC-based address
• ISM VLAN
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
Quality of service (QoS)
• 802.1p
• 8 queues per port
• Queue Management
  o Strict Priority
  o Weighted Round Robin (WRR)
  o Strict + WRR
• Support for the following streams
  o Adding 802.1p priority tag
  o Priority Tagging TOS / DSCP
  o Bandwidth Management
• CoS-based
  o Port Switch
  o VLAN ID
  o 802.1p priority queues
  o MAC-address
  o IPv4-address
  o DSCP
  o The type of protocol
  o TCP / UDP-port
  o contents of the package, user-defined
  o IPv6-addresses
  Class o IPv6-traffic
  o IPv6 flow label
• Bandwidth Management
  o On the basis of a port (incoming / outgoing, min.shag up to 64 kbit / s)
  o On the basis of the flow (incoming / outgoing, min. Step up to 64 kbit / s)
Access Control Lists (ACL)
• Support for up to 1.5 K Access Rules
• ACL on the basis of:
  o 802.1p priority
  o VLAN ID
  o MAC-address
  o Ether Type
  o IPv4-address
  o DSCP
  o Non-TCP / UDP-port
  o IPv6-addresses
  o IPv6 flow label
• ACL on the basis of the time
• CPU Interface Filtering
• ACL for outbound traffic
Security
• SSH v2
• SSL v1 / v2 / v3
• Port Security
  o Up to 64 MAC-addresses per port / VLAN
• Control broadcast / multicast / unicast storms
• Traffic Segmentation
• D-Link Safeguard Engine
• DHCP Server Screening
• Prevention of ARP Spoofing Attacks
• Protection against attacks BPDU
• IP-MAC-Port Binding
AAA
• 802.1X:
  o Access Control based on port
  o Based Access Control Node
  o Identity-driven policy
  o (VLAN, ACL or QoS)
  o Authentication Database
  o Failover
• Access control based on Web (WAC):
  o Failover
• Access Control MAC-based (MAC):
  o Failover
• Access control based on the Japanese Web-based interface (JWAC)
• Guest VLAN
• Microsoft® NAP
  o Support for 802.1X NAP
  o Support for DHCP NAP
• Maintaining RADIUS accounting
• RADIUS and TACACS authentication for access control
• Accounts with 4 levels of access rights
Features D-Link Green
• RoHS compliant
• Energy saving on the status of the connection
• Energy savings along the cable
OAM
• Diagnosis cable
DDM (Digital Diagnostics Monitoring)
Yes
Management
• Manage Web-based interface (Support IPv4)
• Command Line Interface (CLI)
• Telnet-server (Supports IPv4)
• Telnet-client (Supports IPv4)
• TFTP-client (Supports IPv4)
• Tagging PPPoE Circuit-ID
• ZModem
• SNMP v1 / v2c / v3
• SNMP Traps
• System Log
• RMON v1:
  o Support groups 1,2,3,9
• RMON v2:
  o Support group ProbeConfig
• LLDP
• BootP / DHCP-Client
• Auto Configuration via DHCP
• DHCP Relay
• DHCP Client Option 12
• DHCP Relay Option 82
• Flash File System
• Support for multiple versions of software
• Support for multiple versions of configurations
• CPU Monitoring
• Use the debug (Debug Command)
• SNTP
• Restoration of the password
• Password Encryption
• Trusted host
• Microsoft® NLB (Network Load Balancing)
MIB
• RFC 1213 MIB II
• RFC 4188 Bridge MIB
• RFC 1157, 2571-2576 SNMP MIB
• RFC 1907 SNMPv2 MIB
• RFC 1757 RMON MIB 2819
• RFC 2021 RMONv2 MIB
• RFC 1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2674 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 2925 PING and TRACEROUTE MIB
• RFC 2674, 4363 802.1p MIB
Compliance RFC
• RFC 768 UDP
• RFC 791 IP
• RFC 792, 2463, 4443 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 3513, 4291, IPv6 Addressing Architecture
• RFC 2893, 4213 IPv4 / IPv6 dual stack function
• RFC 2463, 4443 ICMPv6
• RFC 2462, 4862 IPv6 Stateless
Address Auto Configuration
• RFC 2464 IPv6 Ethernet and definition
• RFC 1981 Path MTU Discovery for IPv6
• RFC 2460 IPv6
• RFC 2461, 4861 Neighbor Discovery for IPv6
• RFC 783 TFTP
• RFC 854 Telnet
• RFC 951, 1542 BootP
• RFC 2068 HTTP
• RFC 1492 TACACS
• RFC 2866 RADIUS Accounting
• RFC 2474, 3260 DiffServ
• RFC 1321, 2284, 2865, 3580, 3748 Extensible
Authentication Protocol (EAP)
• RFC 2571, 2572, 2573, 2574, SNMP
• IPv6 Ready Logo Phase 2
Functions of the expanded version of the software
L2 Features
• Ethernet Ring Protection Switching (ERSP)
Management
  - SNMP over IPv6
• sFlow • ICMPv6
• Web-interface (Support for IPv6)
• Server Telnet (Support for IPv6)
• Client Telnet (Supports IPv6)
• TFTP-client (Support for IPv6)
נתונים פיזיים
MTBF (hours)
• 292201
Noise level
• Max .: 44.6 dB; Min .: 36.4 dB
Heat release
• 229 BTU / hr
Input supply
• 100-240 VAC, 50-60 Hz, internal universal power supply
Max. power consumption
• 67.1 W
Dimensions
• 440 x 310 x 44 mm
Weight
• 4600 g
Fans
• Smart Fan1 (> 40 ° C: High speed; <35 °: Low speed)
Working temperature
• From 0 to 50 C
Storage temperature
• -40 To 70 C
Working humidity
• From 10% to 90% non-condensing
Humidity storage
• From 5% to 90% non-condensing
EMI
• FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Security
• CB, cUL, LVD
Certifications
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
