DES-3200-18EOL EOS
תאור
The DES-3200 switches is a line of managed switches D-Link 2-level, intended for networks Metro Ethernet (ETTX and FTTX) and corporate networks. Switches in this series are equipped with 8/16/24/48 ports 10/100 Mbit / s Fast Ethernet, and a combo port 1/2/4 Gigabit Ethernet / SFP. Switches DES-3200-10 / 18 made in the case of 9/11 inches wide and equipped with a passive cooling system, suitable for desktop use and for use in telecommunication and control cabinets. Switches DES-3200-26,28,28 / ME, 28F, 52 1U height designed for installation in 19-inch rack and provides a connection for copper or optics (24/48 port) at a speed of 100 Mbit / c. All devices have a series of practical design with 1, 2 or 4-port combo Gigabit Ethernet / SFP, which provide bandwidth of up to 4 Gbit / s and allow to use these switches in a ring topology. Switch DES-3200-28 / ME is made specifically for use in telecommunication closets where operators and engineers have access only to the front of the device and need quick troubleshooting. All interfaces are located on the front of the DES-3200-28 / ME, including the connector for the power cable that meets the requirements of large networks. In addition, the switch DES-3200-28 / ME is equipped with a connector "dry contacts" for event detection and alarm. DES-3200-28F is the ideal solution for network deployment FTTX, allowing you to bring fiber line directly to the subscriber unit. By using the switch DES-3200-28F fiber-optic lines to connect subscribers greatly increased transmission distance (20 km) and excludes the impact of crosstalk inherent in copper cable. Switches DES-3200-28P / 52P meet the standards of PoE (Power over Ethernet-cable) IEEE 802.3af and IEEE 802.3at and provide power up to 15.4 watts per port and up to 30 watts on the first four / eight ports. Supports PoE / PoE + devices such as video / IP-phones, wireless access points and IP-cameras, allowing them to supply power directly from a switch on the Ethernet-cable, which greatly simplifies network deployment. All switches DES-3200 series are equipped with 2 or 4 ports of Gigabit SFP, which provides the ability to select the type of network topology, "ring", "tree" or mixed type.
Safety and reliability
Switches DES-3200 series supports access control 802.1x port-based / host, the ability to create a guest VLAN, and authentication and RADIUS / TACACS / XTACACS / TACACS + when connected to a switch. Function IP-MAC-Port Binding allows administrators to bind IP-addresses and MAC addresses of the user to determine the port number on the switch, thereby prohibiting the user to change the network settings. Moreover, thanks to the DHCP Snooping, the switch automatically detects pairs of IP / MAC-addresses issued by the server, DHCP-tracking packages and storing them in a "white list" IMPB. These features play a significant role in keeping the network secure. Built-in D-Link Safeguard Engine identifies and prioritization of packets to be processed directly by the CPU of the switch, in order to prevent malicious attacks and neutralize the effects of spurious traffic on the CPU switch. In addition, DES-3200 supports List for access control (ACL). This functionality enables administrators to restrict access to network services and does not affect the performance of the switch.
Resilience / performance
Switches DES-3200 series supports protocols 802.1D-2004 edition, 802.1w and 802.1s Multiple Spanning Tree (MSTP). STP allows you to organize data backup route used in the event of failure of any switch on the main route of the network traffic. The switches also support link aggregation, standards-based 802.3ad (LACP) and 802.1AX, which allows you to combine multiple ports into groups, increasing the bandwidth and increasing the resilience of connections between network devices. The switches support 802.1p for Quality of Service (QoS). In addition, the traffic can be prioritized on the basis of marks TOS, DSCP, MAC-addresses or IP-address of the client, Vlan number, port number, TCP / UDP, protocol type, or based on the contents of the package defined by the user. This functionality is especially important in the provision of IPTV. Also, The DES-3200 series supports the functionality of Voice VLAN, is a separate vlan, which is automatically placed in the voice traffic, with a view to its subsequent processing with a higher priority level than the rest of the traffic.
Traffic Control and Bandwidth
Bandwidth control allows network administrators to define bandwidth per port increments up to 8 kbit / s for incoming and outgoing traffic. The switches also support the functional protection from the storm (Storm Control), which allows you to get rid of unnecessary broadcast / multicast traffic. Port Mirroring facilitate traffic diagnostics and helps administrators to monitor the network performance. Switches DES-3200 series supports markers "Two speed, three-colored marking" and "One speed three color labeling" (trTCM / srTCM), allowing flow splitting by prioritizing to ensure maximum throughput of important traffic.
Multicasting
Switches DES-3200 series supports a full feature set for L2 multicast, including IGMP Snooping, IGMP filtering, Fast Leave. With the support of the functional Switch The DES-3200 provides an opportunity to work with IPTV-services, enjoys a growing demand in the market.
IGMP / MLD Snooping allows host-based connection of multiple customer multicast group to a single network interface. When you use the ISM VLAN multicast traffic for efficient bandwidth consumption is transmitted in a separate Vlan. ISM VLAN profiles allow users to quickly and easily assign / change the preset settings on ports multicast subscribers.
OAM
Switches DES-3200 series supports a cable diagnostic function to check the status of network cables and identify the causes of malfunction of the cable. Function 802.1ag Connectivity Fault Management (CFM) provides tools for surveillance, as well as for troubleshooting in complex Ethernet-networks, allowing service providers to perform the test compound, and quickly locate network problems, identify users, faced with these problems. Options 802.3ah Ethernet OAM, Dying Gasp, and D-Link Unidirectional Link Detection (DULD) can improve network manageability and enhance stability of the compound, as well as to detect the fault.
Control Features
Switches DES-3200 series supports standard management protocols such as SNMP, RMON, Telnet, SSH / SSL. The user-friendly web interface provides easy operation. Automatic, DHCP is an enhanced management feature that allows administrators to pre-configure the settings and save them to a TFTP-server and automatically applied to the switches in the process of obtaining IP-address from the server that makes network configuration easier and faster. Support of LLDP and LLDP-MED can detect used in an Ethernet network equipment. In accordance with the result of the search, the administrator can easily apply the settings to the device discovery and obtain a graphic representation of the topology using the Network Management System (NMS).
Function D-Link Single IP Management (SIM) simplifies and improves the efficiency of management tasks, allowing multiple switches simultaneously setting, surveillance and maintenance from any location using a Web-browser. Moreover, the switch DES-3200 series supports software D-View 6.0. D-View 6.0 is a Network Management System that allows you to improve the most important for the network characteristics such as availability, reliability, fault tolerance and security. D-View 6.0 provides network administrators with a set of useful tools for effective configuration management, performance and security, as well as error detection.
Support for IPv6
Switches DES-3200 series has successfully passed the certification IPv6 Ready Logo Phase 2, which guarantees the operation of the switch in networks IPv6. In addition, this series supports both protocol stacks IPv4 / v6, allowing the switches to act as a bridge between IPv4 and IPv6. With the constant expansion of the network security problem is most acute. To solve a series of DES-3200 supports features such as IPv6 ACL, IMPBv6 and L3 Control Packet Filtering, designed to protect against network attacks in IPv6 networks.
מאפיינים כללים
Flexible Hardware Design
• 8, 16, 24, or 48 10/100BASE-TX ports
• 1 or 2 Combo 1000BASE-T/SFP ports
• 1 or 2 SFP ports
• 9”, 11”, or 19” Rack-mount
• Support 802.3at (PoE+) and 802.3af (PoE) for PoE models
Surge Protection
• All Ethernet ports have 6 KV surge protection
L2 Features
• 802.1D STP, 802.1w RSTP, and 802.1s MSTP
• Loopback Detection
• 802.1AX and 802.3ad Link Aggregation
• Voice VLAN1
Security
• SSH/SSL
• Port Security
• Access Control List (ACL)
• 802.1X / Web-Based (WAC)1/MAC-Based (MAC) Access Control
• Guest VLAN
• IP-MAC-Port Binding (IMPB)
• Traffic Monitoring and Bandwidth Control
• Port Mirroring/Bandwidth Control
• Broadcast/Multicast/Unicast Storm Control
• srTCM, trTCM, & policing
Number of 10/100BASE-TX ports
• DES-3200-10 - 8 ports
• DES-3200-18 - 16 ports
• DES-3200-28 - 24 ports
• DES-3200-28P - 24 ports
• DES-3200-52 - 48 ports
• DES-3200-52P - 48 ports
Number of Combo 1000Base-T/SFP ports
• DES-3200-10 - 1 ports
• DES-3200-18 - 1 ports
• DES-3200-28 - 2 ports
• DES-3200-28P - 2 ports
• DES-3200-52 - 2 ports
• DES-3200-52P - 2 ports
Number of SFP ports
Number of 10/100/1000BASE-T ports
PoE Supported Models (Standard(s)/Number of Ports/Maximum Power Budget)
• DES-3200-28P (802.3af/at/24 ports/188W)
• DES-3200-52P (802.3af/at/48 ports/370W)
RS-232 Console Port
• Yes
Switch Capacity
• DES-3200-10 - 5.6 Gbps
• DES-3200-18 - 7.2 Gbps
• DES-3200-28 - 12.8 Gbps
• DES-3200-28P - 12.8 Gbps
• DES-3200-52 - 17.6 Gbps
• DES-3200-52P - 17.6 Gbps
64-Byte Packet Forwarding Rate
• DES-3200-10 - 4.2 Mpps
• DES-3200-18 - 5.4 Mpps
• DES-3200-28 - 9.5 Mpps
• DES-3200-28P - 9.5 Mpps
• DES-3200-52 - 13.1 Mpps
• DES-3200-52P - 13.1 Mpps
MAC Address Table Size
• 16K
Packet Buffer
• 1.5 MB
Flash Memory
• 32MB
Stackability
• Virtual Stacking D-Link Single IP Management
• Up to 32 units per Virtual Stack
• MAC address table: 16K
• Flow Control
802.3x Flow Control
HOL Blocking Prevention
Jumbo Frame up to 12K bytes
Spanning Tree Protocols
802.1D STP
802.1w RSTP
802.1s MSTP
BPDU Filtering
Root Restriction
Loopback Detection
Link Aggregation
Complies with 802.1AX and 802.3ad
DES-3200-10: Max. 5 groups, 8 ports per group
DES-3200-18: Max. 9 groups, 8 ports per group
DES-3200-28/28P: Max. 14 groups, 8 ports per group
DES-3200-52/52P: Max. 26 groups, 8 ports per group
Port Mirroring:
Supports 1 Mirroring group
Supports One-to-One, Many-to-One, Flow-based (ACL) mirroring
Ethernet Ring Protection Switching (ERPS)
L2 Protocol Tunneling (L2PT)
L2 Multicasting
IGMP Snooping:
IGMP v1/v2 snooping, v3 awareness
Supports 1024 Groups
Port/Host-based IGMP snooping Fast Leave
Report Suppression
MLD Snooping
MLD v1, MLD v2 awareness
Support 1 K groups
Host-based MLD snooping
Fast Leave
IGMP Authentication
IGMP/MLD Proxy Reporting1
VLAN
802.1Q Tagged VLAN
VLAN Group
Max. 4K VLAN
Port-based VLAN
MAC-based VLAN
GVRP
802.1v Protocol VLAN
VLAN Trunking
Double VLAN (Q-in-Q)
Port-based Q-in-Q
Selective Q-in-Q
ISM VLAN
VLAN Translation
Voice VLAN1
L3 Features
IPv6 Neighbor Discovery (ND)
Bandwidth Control
Port-based (Ingress/Egress, Min. Granularity 8 Kbps)
Flow-based (Ingress/Egress, Min. Granularity 8 Kbps)
Per egress queue bandwidth control (Min.Granularity 8 Kbps
8 Queues per Port
DSCP
802.1p
Queue Handling
Strict Priority
Weighted Round Robin (WRR)
Strict + WRR
Three Color Marker
trTCM
srTCM
CoS Based on:
Switch port
802.1p Priority Queues
VLAN ID
MAC Address
Ether type
TOS
DSCP Protocol Type
TCP/UDP Port
IPv6 Traffic Class
IPv6 Flow Label
User-Definited Packet Content
Supports Following Actions for Flows
Remark 802.1p Priority Tag
Remark TOS/DSCP Tag
Bandwidth Control Flow Statistic
Up to 1024 ingress access rules
ACL Based on
Switch Port
802.1p Priority
VLAN ID
Ether Type
IPv4/v6 address
DSCP
Protocol Type
TCP/UDP Port Number
IPv6 Traffic Class
IPv6 Flow Label
User-Defined Packet Content
Time-based ACL
ACL statistics
CPU interface filtering
Security
SSH v1, v2
SSL v1, v2, v3
Port Security
Up to 64 MAC addresses per port
Traffic Segmentation
IP-MAC-Port Binding
ARP Inspection
IP Inspection
DHCP Snooping
DHCP Server Screening
DHCP Client Filtering
ARP Spoofing Prevention
BPDU Attack Protection
NetBIOS/NetBEUI Filtering
DoS Attack Prevention
AAA
802.1X
Port-based Access Control
Host-based Access Control
Dynamic VLAN assignment
Identity-driven Policy (VLAN, ACL, or QoS) Assignment
MAC-based Access Control (MAC)
Web-based Access Control (WAC)1
Microsoft® NAP(IPv4/v61)
Support 802.1X NAP
Support DHCP NAP
Guest VLAN
RADIUS Accounting
RADIUS (IPv4/v61)
TACACS
TACACS+
XTACACS+
Trusted Host
OAM
Cable Diagnostics
802.3ah Ethernet Link OAM
Dying Gasp 802.1ag Connectivity Fault Management (CFM)
802.3ah D-Link extension: D-Link Unidirectional Link Detection (DULD)
Green
D-Link Green 3.0: Power saving function
LED Shut-Off1
Port Shut-Off1
System Hibernation1
Power Saving by Time-based PoE
Management
Web-based GUI (IPv4)
Command Line Interface (CLI)
Telnet Server/ Client (IPv4)
TFTP Client (IPv4)
FTP Client (IPv4)
Zmodem
Command Logging
SNMP v1/v2c/v3
SNMP Traps
System Log
RMON v1
Supports 1,2,3,9 Groups
RMON v2
Supports ProbeConfig Group
LLDP
802.1AB
LLDP-MED1
BootP/DHCP Client
DHCP Auto-Configuration
DHCP Relay (IPv4)
DHCP Relay Option 12
DHCP Relay Option 82
PPPoE Circult-ID Tag Insertion
Flash File System
SNTP
CPU Monitoring
Memory Monitoring
Debug Command
Password Encryption
Password Recovery
Microsoft® NLB (Network Load Balancing) Support
Ping (IPv4/v61)
Traceroute
Multiple IP Interface
MIB
RFC RFC1065, 1066, 1155, 1156, 2578 MIB Structure
RFC 1212 Concise MIB Definitions
RFC1213 MIB II
RFC 1215 MIB Traps Convention
RFC1493, 4188 Bridge MIB
RFC1157, 2571-2576 SNMP MIB
RFC1901-1908, 3418,3636, 1442,2578 SNMPv2 MIB
RFC271,1757, 2819 RMON MIB
RFC 2465 IPv6 MIB
RFC 2466 ICMPv6 MIB
RFC 2737 Entity MIB
RFC 4293 IPv6 SNMP Mgmt Interface MIB
Private MIB
RFC 3289 DIFFSERV MIB
RFC2021 RMONv2 MIB
RFC1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
RFC2668 802.3 MAU MIB
RFC2674,4363 802.1p MIB
RFC 2233, 2863 IF MIB
RFC 2618 RADIUS Authentication Client MIB
RFC4022 MIB for TCP
RFC4113 MIB for UDP
RFC 3298 MIB for Deffserv.
RFC2620 RADIUS Accounting Client MIB
RFC 2925 Ping& Traceroute MIB
Running configuration write and backup
TFTP uploads and downloads
Trap MIB
IETF® Standard
RFC768 UDP
RFC791 IP
RFC792 ICMPv4
RFC2463, 4443 ICMPv6
RFC4884 Extended ICMP to Support Multi-Part Messages
RFC793 TCP RFC 2474, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
RFC2571, RFC2572, RFC2573, RFC2574 SNMP
RFC826 ARP
IPv6
RFC1981 Path MTU Discovery
RFC2460 IPv6
RFC2461, 4861 Neighbor Discovery
RFC2462, 4862 IPv6 Stateless Address Auto-configuration
RFC2464 IPv6 Neighbor over Ethernet and definition
RFC3513, 4291 IPv6 Addressing Architecture
RFC2893, 4213 IPv4/IPv6 dual stack function
