חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 24 פורטים במהירות ג'יגהביט
מאפיינים כללים:
Number of Ports
• 24
Port Standard & Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliance
• Supports Half/Full-duplex operation at 10/100Mbps
• Supports Full-duplex operation at 1000Mbps
• Supports Auto-Negotiation for each port
• Auto MDI/MDIX
• IEEE 802.3x Flow Control support
• IEEE 802.3az compliant
Performance Switching Capacity
• 48Gbps
Max. Forwarding Rate
• 35.71 Mpps
MAC Address Table Size
• 8K Entries
Packet Buffer
• 512Kbits
Forwarding Mode
• Store and Forward
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Surveillance VLAN
• Voice VLAN
• Management VLAN
• Asymmetric VLAN
• VLAN Group
     • Supports 128 static VLAN groups (DGS-1100-16/124/-24P)
     • Max. 4094 VIDs
L2 Features
• Flow Control
     • 802.3x Flow Control
     • HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
     • IGMP v1/v2 Snooping
     • Supports 64 Groups
• Link Aggregation
     • 12 groups, 8 ports per group
• Loopback Detection
• Cable Diagnostics
• LLDP
• Port Mirroring
     • One-to-One
     • Many-to-One
• Statistics
     • Tx Ok
     • Tx Error
     • Rx Ok
     • Rx Error
• Spanning Tree Protocol
     • 802.1D STP
     • 802.1w RSTP
QoS
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
     • Strict
     • Weighted Round Robin (WRR)
• Bandwidth Control
          • Port Based
          • Ingress: minimum granularity 8 Kbps
          • Egress: minimum granularity 64 Kbps
Security
• Static MAC Address
     • Max. 64 entries
     • Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Web-Based GUI (Supports IPv4)
• D-Link Network Assistant Utility
D-Link Green
• Power Saving by:
     • Link Status
     • LED Shut-off
     • Port Shut-off
     • System hibernation
     • Energy Efficient Ethernet (IEEE 802.3az)
     • RoHS Compliant
RFC Standard List
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC2233 Interface Group MIB
• RFC2665 Ether-like MIB
• 802.1p MIB RFC4363
• ZoneDefense MIB
• Private MIB
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 4363 802.1p
• RFC 2236 IGMP Snooping
נתונים פיזיים
Power
• 100 to 240 VAC, 50 to 60 Hz
• Internal Universal Power Supply
Max. Power Consumption
• 13.94 W
Standy Power Consumption
• 10.37 Watts (DGS-1100-24)
Fan Quantity
• Fanless
Acoustics
• 0 dBA
Heat Dissipation
• 47.57 BTU/hr
Operating Temperature
• 23 to 122 °F (-5 to 50 °C)
Storage Temperature
• -40 to 158 °F (-40 to 70 °C)
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
Dimensions (W x D x H)
• 280mm x 180mm x 44 mm
Weight
• 1.63 kg
Diagnostic LEDs
• Power (Per Device)
• Link/Activity/Speed (Per Port)
Certifications
• FCC Class A
• CE Class A
• VCCI Class A
Safety
• UL/cUL
• CE LVD
MTBF
• 2,406,109 Hours (DGS-1100-24)
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
