חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 8 פורטים במהירות 10/100Mbps, תמיכה ב PoE ושתי יציאות משולבות ג'יגהביט/אופטי (SFP)
תאור:
Switch DES-1100-10P is an effective solution with advanced features and a passive cooling system. The Switch is equipped with 8-port 10 / 100Base-TX with PoE and 2 combo port 100 / 1000Base-T / SFP. DES-1100-10P allows you to connect and supply power to network devices with PoE, such as wireless access points (APs) and IP-cameras.
Switch DES-1100-10P supports IEEE802.3at and provides power up to 30 Watts per port at a maximum PoE power budget of 90 watts.
Resilience / Performance Enhancement
The switch supports a number of functions Level 2, including IGMP Snooping, and port mirroring. This switch also supports Loopback Detection. Loopback Detection is used to determine the loops and automatic shut-off port that detected the loop. Switch DES-1100-10P supports 802.1p (QoS), which enables traffic classification in real time on 8 levels of priority and 2 line.
Network Security
DES-1100-10P switch supports 802.1Q VLAN and port-based VLAN. The bandwidth control feature allows network administrators to define the level of bandwidth for each port. This function allows you to set the restriction of incoming / outgoing traffic with a minimum of 32 kbit / s. The function of protection against the storm needed to limit broadcast traffic in case of exceeding a predetermined threshold. The switch blocks or drops packets, a large number of which can lead to network congestion. Port Mirroring helps administrators facilitate traffic diagnostics or track switch performance and alter if necessary.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
