חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 8 פורטים במהירות 10/100Mbps, תמיכה ב PoE ושתי יציאות משולבות ג'יגהביט/אופטי (SFP)
מאפיינים כללים:
Interfaces
• 8-port 10 / 100Base-TX PoE
• 2 combo port 100 / 1000Base-T / SFP
Indicators
• Power (per device)
• Link / Activity / PoE (per port)
• Budget Power PoE: 25% / 50% / 75% / Full
Button
• Power on / off indicator
• Reset
Switching matrix
• 5,6 Gbit / s
MAC-address table
• 4K entries
Packet buffer
• 2,75 MB
Flash-memory
• 2 MB
PoE standards
• 802.3af
• 802.3at
Ports PoE
• Ports 1-8: up to 30 watts per port
PoE power budget
• 90 W
Standards and functions
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
• IEEE802.3af / 802.3at (Ports 1-8)
• Supports half / full-duplex (for half-duplex 10/100 Mbit / s for full duplex 1000 Mbit / s)
• Auto-negotiation
• Auto MDI / MDIX
• IEEE 802.3x flow control in full duplex mode
Data rate
• Ethernet:
• 10 Mbit / s (half duplex)
• 20 Mbit / s (full duplex)
• Fast Ethernet:
• 100 Mbit / s (half duplex)
• 200 Mbit / s (full duplex)
• Gigabit Ethernet:
• 2000 Mbit / s (full duplex)
VLAN
• VLAN-based port
• 802.1Q Tagged VLAN
• Max. the number of VID: 4094
• VLAN-based port
• Supports 8 groups based VLAN
Features 2 levels
• Flow Control
• 802.3x
• IGMP Snooping
• IGMP v1 / v2 Snooping
• 802.3ad Link Aggregation:
• Max. 3 groups device 4 ports per group
• The Loopback Detection
• Port Mirroring
• One-to-One
• Many-to-One
• Statistics
• Packets Tx / Rx
• Collisions
• Dropped packets
• CRC errors
• Spanning Tree Protocol
• 802.1D STP
• 802.1w RSTP
• DHCP Relay
• Support Option 82
Quality of service (QoS)
• 802.1p
• 2 queues per port
• Bandwidth Management
• Based on the port (with a minimum of a 32 kbit / s)
Security
• Filtering MAC-based
• Protection against broadcast storms
Management
• Web-interface
Technology D-Link Green
• Reduce energy consumption by:
• Turn off the indicator
נתונים פיזיים
Dimensions
• 210 x 160 x 44 mm
Weight
• 638 g
Power
• External power adapter:
• Input supply: from 100 to 240 VAC, 50 Hz ~ 60
• Power output: 54 / 2,23 A
Power consumption
• 14,2 W
MTBF
• 7 years or more
Ventilation system
• Passive
Temperature
• Operating: 0 to 50 ° C
• Storage: -20 to 70 ° C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 10% to 90% non-condensing
Certifications
• CE
• EAC
Security
• CB
ROHS
• Compliance with the directive ROHS
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
