חיפוש מהיר
תכונות המוצר:
24-Port 10/100/1000 Mbps + 2-Port Combo 1000BASE-T/SFP PoE switch
EOL EOS
מאפיינים כללים:
Hardware Version
B1
Size
19-inch Desktop/Rackmount Size, 1U Height
Number of Ports
 24 10/100/1000 Mbps PoE
2 Combo 1000 Mbps
Port Functions
IEEE 802.3 compliant
IEEE 802.3u compliant
IEEE 802.3ab compliant
IEEE 802.3af/802.3at compliant
IEEE 802.3bt draft/UPoE (DGS-1100-10MPP/26MPP only)
IEEE 802.3x Flow Control supports full-duplex mode
Supports manual/auto MDI/MDIX configuration
Auto-negotiation
Supports half/full-duplex operation
IEEE 802.3az compliant
Up to 6 kV surge protection per port
Switching Capacity
 52 Gbps
Maximum Forwarding Rate
38.69 Mpps
MAC Address Table Size
16K Entries
Packet Buffer
1.5 MBytes
Flash Memory
16 MBytes
PoE Standard
PoE Capable Ports
Ports 1 to 24
PoE Power Budget
 370 watts (30 watts max. per PoE port)
Standby Mode Power Consumption
15.2 watts
Maximum Power Consumption
387 watts (PoE on)
20.8 watts (PoE off)
Power Input
100 to 240 V AC
50 to 60 Hz Internal Power Supply
MTBF
269, 291 hours
Acoustics
 56 dB(A)
Heat Dissipation
 1470.46 BTU/hr
Weight
 3.81 kg
Dimensions
 440 x 290 x 44 mm
Ventilation
 2 x Fan
Operating Temperature
-5 to 50 °C
Storage Temperature
-40 to 70 °C
Operating Humidity
0% to 95% non-condensing
Storage Humidity
EMI
FCC/IC, CE, VCCI, BSMI, CCC
Safety
cUL, UL, LVD, CB, CCC, BSMI
VLAN
Port-based VLAN
802.1Q tagged VLAN
Auto Surveillance VLAN
Voice VLAN
Management VLAN
Asymmetric VLAN
VLAN Group
Supports 128 static VLAN groups
Max. 4094 VIDs
L2 Features
Flow Control
802.3x Flow Control
HOL Blocking Prevention
Jumbo Frames up to 9216 Bytes
IGMP Snooping
IGMP v1/v2/v3 awareness Snooping
Supports 64 Groups
IGMP Snooping Querier
802.3ad Link Aggregation:
DGS-1100-10MP: Support 5 groups per device and 8 ports per group
Ethernet Ring Protection Switching
G.8032 ERPS
Loopback Detection
Cable Diagnostics
LLDP
Port Mirroring
One-to-One
Many-to-One
Statistics
Tx Ok
Tx Error
Rx Ok
Rx Error
Spanning Tree Protocol
802.1D STP
802.1w RSTP
L2 Multicast
MLD Snooping
Quality of Service (QoS)
802.1p Quality of Service
4 queues per port
Queue Handling
Strict
Weighted Round Robin (WRR)
Port-based Bandwidth Control (Rate Limiting)
Ingress: 8Kbps
Egress: 64Kbps
Security
D-Link Safeguard
Traffic Segmentation
Broadcast/Multicast/Unknown Unicast Storm Control
DoS Attack Prevention
SSL
Management
Web-based GUI (Supports IPv4/IPv6)
Client-based Utility (D-Link Network Assistant Utility)
Green Technology
Power Saving by
Link Status
LED Shut-Off
Port Shut-Off
System Hibernation
Compliant with IEEE 802.3az Energy Efficient Ethernet
MIB/RFC Standards
RFC768 UDP
RFC791 IP
RFC792 ICMP
RFC793 TCP
RFC826 ARP
RFC1213 MIB II
RFC1493 Bridage MIB
RFC1907 SNMPv2 MIB
RFC1215 MIB Traps Convention
RFC2233 Interface Group MIB
RFC2665 Ether-like MIB
RFC4363 IEEE 802.1p MIB
ZoneDefense MIB
Private MIB
RFC951 BootP client
RFC1542 BootP/DHCP client
RFC2236 IGMP Snooping
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
