חיפוש מהיר
תכונות המוצר:
8-Port Gigabit Unmanaged Desktop PoE Switch
מאפיינים כללים:
Interfaces
• 8 x 10/100/1000Base-T (ports 1 to 4 support PoE)
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3x Flow Control
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3af Power over Ethernet
• IEEE 802.3at Power over Ethernet
• Auto-MDI/MDI-X adjustment on all ports
Switching Capacity
• 16 Gbps switching fabric
Transmission Method
• Store-and-forward
Packet Filtering / Forwarding Rates
• 11.90 Mpps
MAC Address Table
• 4K entries per device
Jumbo Frame Size
• 9,720 bytes
Flash Memory Size
• 512 Kbit
Diagnostic LEDs
• Power
• Link/Activity/Speed (per port)
• PoE (per PoE port)
• PoE Max.
PoE Power Budget
• 68 W (30 W max. per PoE port)
Physical Parameters
Weight
• 0.59 kg
Dimensions
• 190 x 120 x 38 mm
DC Input
• External 54 V / 1.67 A power adapter
Maximum Power Consumption
• 82.3 W (PoE on)
• 7.6 W maximum (PoE off)
MTBF
• 631,894 hours
Heat Dissipation
• 253.022 BTU/hr
Temperature
• Operating: 0В° to 50В°C
• Storage: -40В° to 70В°C
Humidity
• Operating: 0 to 95% non-condensing
• Storage: 0% to 95% non-condensing
EMI/EMC
• CE Class B
• BSMI
• FCC Class B
• VCCI Class B
• RCM
• KCC
Safety
• UL
• BSMI
• LVD
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
