DES-1016R+EOL EOS
מתג לארון 16 פורטים 10/100
היכן לקנות
תאור
Main features
  • Layer 2 switch
  • Full/half-duplex support for each port
  • No need to use uplink ports - DES-1016R+ supports auto-polarity
  • Config port for configuration setup
  • 19" standard rack-mount width
For Workgroups
Built with advanced functions, these switches are designed for the workgroups with advanced requirements. Powerful yet easy to use, they allow users to simply plug any port to either a 10Mbps or 100Mbps node to multiply bandwidth, boost response time and satisfy heavy load demand.
Flow Control
In the full-duplex mode, the switches's embedded flow control provides a means to protect users against possible data loss during transmission on the network. When connected to a LAN adapter (in a server PC) that supports flow control, the switch sends signals to the PC regarding buffer overrun during peak usage periods. The PC then delays transmission until the switch is ready again to accept new data.
Optional 100Mbps Fibre Ports - DES-102F
An open slot is provided on the front panel to allow installation of an optional Fast Ethernet fibre module. This module provides 2 100Mbps-fibre ports for 2 server connections or switch-to-switch cascading over fibre cables, which can be up to 2km long.
מאפיינים כללים
Features
• Layer 2 switch
• 16 ports per switch
• Dynamic buffer allocation for each port
• Wire-speed filtering/forwarding rates
• Auto-correction of reverse twisted-pair polarity
• Internal universal power supply
• FCC Class A, CE Mark, VCCI Class A, C-Tick, BSMI Class A
• UL, CSA, TUV/GS
Performance
• Store-and-forward switching method
• Filtering address table: 1K per device
• Automatic learning of network configuration
• Packet filtering/forwarding rates:
     14,880 pps per port (Ethernet)
     148,800 pps per port (Fast Ethernet)
• RAM buffer: 2MB per device
נתונים פיזיים
תקנים
הורדות
איורים
DES-1016R+
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
