DES-1024DEOL EOS
מתג שולחני / לארון - 24 פורט 10/100Mbps
היכן לקנות
תאור
 Main Features
  • 24 x 10/100Mbps RJ-45 Auto-sensing ports
  • Superior Performance
  • Non-Blocking Wire-Speed Architecture
  • 4.8Gbps Switching Capacity
  • Supplied with 19"
  • Rack-mount kit
 Product description
  • The 24-port D-Link DES-1024D unmanaged switch is the latest addition to D-Link’s popular line of Express EtherNetwork™ products. Like other products in the line, the DES-1024D combines ease of use with unsurpassed performance resulting in an exceptional value for any cost-conscious network administrator who wants the best possible solution at the best possible price.
    The DES-1024D is truly Plug-&-Play with features like: Auto Speed Sensing — allowing it to automatically sense whether a network device is running at 10Mbps or 100Mbps then automatically adjusting itself for optimal performance; Auto-Negotiation (Full or Half Duplex) — negotiating and running the highest supported transmission rate whether at Half- or Full-Duplex; and Auto MDI/MDIX Crossover—offering auto-negotiating MDI/MDIX detection on every port to eliminate the need for crossover cables or uplink ports.
    The DES-1024D features a non-blocking wire-speed architecture with a 4.8Gbps switching capacity, for maximum data throughput. It also features an integrated universal power supply, and per port diagnostics LEDs that make it easy to “spot check” for problems. With wire-speed filtering and Store-and-Forward switching, the DES-1024D also maximizes network performance while minimizing the propagation of bad network packets.
    This easy-to-use 10/100BASE-T swich will enhance and compliment any existing network infrastructure and deliver the performance that IT managers and other SMB network administrators demand.
  • מאפיינים כללים
     Ports
    • 24-10/100Mbps RJ-45 Auto-sensing ports
      Standards
    • IEEE 802.3 Ethernet
    • IEEE 802.3u Fast Ethernet
    • IEEE 802.3x Flow Control
    • IEEE 802.1p QoS Support (2 Queues)
      Network Interface
    • RJ-45: 100ohm, UTP/STP cable
    • 10/100Base – EIA/TIA Categories 3 or 5 cable
      Switching Method
    • Store – and – forward
      Switch Fabric
    • 4.8Gbps
      MAC Address Table
    • 8,000 entries
               Filtering/      Forwarding/LearningRates
    • Full line rate/full wire speed
      Physical Specifications
    • Dimensions: 280 x 180 x 44 mm
    • Weight: 1.9 kg.
    • Metal Housing
    • Side Air Vents with Fanless Air-Cooling Design
      LEDs
    • 100Mbps – one per port
    • 10Mbps – one per port
    • Power
    • Link/Act (activity)
      Temperature
    • Operating: 32°-104°F (0-40°C)
    • Storage: 14°-158°F (-10°-70°C)
    Humidity, non-  condensing
    • Operating: 5% to 90% RH
    • Storage: 5% to 90% RH
      Power
    • Internal Universal Power Supply
    EMC/ Safety Compliances
         Emissions
    • CE Mark Class A
    • FCC Class A
    • VCCI-A
         Safety
    • UL
      Warranty
    • 2 Year limited
    Ordering Information
     Part Number:
          DES-1024D
     Description
    Unmanaged Layer 2 Switch with (24)  10/100BASE-T Ports
    נתונים פיזיים
    תקנים
    הורדות
    איורים
    DES-1024D
    מראה מאחורה
    מראה מקדימה
    דף מידע
    ראה גם
