חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 16 פורטים 10/100 (מתוכם 8 פורטים PoE)
דגם לא מיוצר יותר
מאפיינים כללים:
Standards and responsibilities
·         IEEE 802.3af Power over Ethernet (PoE)
·         IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
·         IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
·         ANSI / IEEE 802.3 NWay autodetect speed mode
·         IEEE 802.3x Flow control is
·         Port mirroring
Number of Ports
·         16 Port 10BASE-T/100BASE-TX (8 ports support PoE, 8 ports without PoE)
Arrangement of the ports PoE
·         Wires 1, 2, 3 and 6 in the cable category 5
Minutes
·         CSMA / CD
Data Transfer Rate
·         Ethernet:
·         10M bps (Half)
·         20 Mbps (full duplex)
·         Fast Ethernet:
·         100 Mbit / s (Half)
·         200 Mbps (full duplex)
Topology
·         Star
·         Network Cables
·         UTP categories. 5, 5e (100 m max.)
·         EIA/TIA-568 100 ohm STP (100 m max.)
Interface medium
·         Auto-polarity of MDI / MDI-X on all ports for twisted pair
Indicators
·         Power (per device)
·         CPU (per device)
·         Link / Act, Speed (per port)
·         100 Mbps (per port)
·         PoE (per port PoE)
PoE
·         Ports PoE
·         Ports 1 to 8
Feeds
·         Up to 15.4 watts per port
Autodetection
·         Automatic identification of connected devices and PoE automatic sheet feeding
Auto
·         Automatic disconnection of the port in case of
·         exceeding the maximum load current 350mA
·         Active protection
·         Automatic disconnection of the port in case of short circuit
Software
VLAN
·         Default: VLAN 802.1Q
·         Maximum number of VLAN *: 16 per device
·         Range VLAN (VID) restricted values 1-511
Quality of service QoS
·         Maximum number of rounds: 2
·         Based on the port
·         Channel Aggregation
·         Standard: IEEE 802.3ad
·         Max. 4 ports per channel
·         1 composite channel device
Controls and settings
·         Web-management interface
·         Web-Management Utility to update the software for Windows
·         Resetting the configuration settings through the
·         software or hardware (the button Reset)
The management and configuration
·         Adjusting the speed / half / full duplex mode
·         Setting power at port
·         Auto-connected devices
Productivity
·         Productivity internal line
3.2 Gb / s
The method of switching
·         Store-and-forward
The amount of MAC-address table
·         4 K entries per device
Study of MAC-addresses
·         Automatic Updates
The speed of filtering / packet (Half)
·         Maximum 1488095 packets / sec. at port
Buffer RAM
·         512 KB per device
Physical parameters
Dining
·         100-240V AC, 50/60Hz, internal universal power supply
·         Power consumption
·         Maximum 9 watts to the device (without connected devices PoE)
·         Maximum 130 watts to the device (if you connect all the devices 8 PoE)
Dimensions
·         440 (width) x 140 (depth) x 44 (H) mm
·         For installation in standard 19-inch rack, 1U height
·         Weight
2.15 kg
·         Operating temperature
0o to 55o C
·         Storage Temperature
-10o to 70o C
Working humidity
·         From 10% to 90% without condensation
Humidity in storage
·         From 5% to 90% without condensation
EMI Certifications
·         FCC Class A
·         CE Class A
·         VCCI Class A
Safety
·         UL
·         CUL
·         TUV
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
