תאור
The DES-1316K 16-port Smart Switch combines 10/100Mbps Ethernet switching with 802.3af standard remote power on network cabling of up to 100 meters. This switch presents a cost-effective solution for the small and medium business, delivering the perfect combination of functionality, ease of use and affordable pricing. With integral power sourcing capability and inherent support including VLAN, Priority Queues, port trunks and simplified management, this switch is the ideal PoE choice that offers security, Quality of Service, low infrastructure cost and easy deployment.
16 Ethernet Ports, 8 With PoE Designed for Business and Hot Spots Centralized Power Provision, Easy Deployment Port Trunks for Aggregated Bandwidths VLANs for Enhanced Security & Performance Quality of Service Support Port Mirroring Easy Management
The DES-1316K Smart Switch provides 16 10/100Mbps Ethernet ports, of which 8 ports supporting PoE for device connection, and the other 8 ports without PoE for workstation/server attachment. Complying with industry standard 802.3af Power over Ethernet (PoE), the PoE ports provide power over the normally unused pairs of the Ethernet cables, which makes it very valuable for deployment of VoIP phones, remote surveillance cameras and wireless access points. In addition to PoE, the DES-1316K auto-senses Ethernet speeds and negotiates for full/half duplex transmission while supporting auto MDI/MDIX for easy, plug-and-play network connection.
Suitable for installation at offices, factories, hospitals and schools, the DES-1316K can also be used for public Wi-Fi deployments requiring multiple access points, such as in hotels, airports, and marinas. For offices with VoIP, each phone must be individually powered, and a power failure in a building can leave phone service disrupted without an uninterruptible power supply (UPS) on each phone. For surveillance and wireless networks, cameras and access points typically need to be located in out-of-the-way locations such as on the ceilings or rooftops for maximum coverage, where wall AC outlets are inaccessible and providing power to these locations is difficult and expensive.
By transmitting remote power through the standard network cabling, the DES-1316K provides a centralized power source for IP phones, cameras and wireless AP, eliminating the need for individual power sources for these devices.
In addition to eliminating the need for additional, separate wiring to power devices, the DES-1316K is also more costeffective than deploying an Ethernet switch and multiple single-port PoE injectors. Add a central UPS to the DES-1316K, and you can maximize uptime for all connected devices. This switch can simplify your installation while minimizing costs by eliminating UPS for each individual device. It has a rugged metal case, comes with an internal universal power supply, and can be mounted in a standard size equipment rack along with a centralized UPS.
Up to 4 non-PoE ports on the DES-1316K can be combined together to create a multi-link load-sharing aggregated bandwidth to a server or a network backbone. You can also make use of the port trunk to eliminate bottlenecks between 2 cascaded switches.
The DES-1316 supports Virtual LANs (VLAN) to let you implement security and improve bandwidth utilization. VLANs limit broadcast domains and confine intra-group traffic within their segments. To segment up the network, you can group devices, workstations and servers on the network into different VLANs, using 802.1Q standard VLAN tagging.
The DES-1316K provides Layer 2 802.1p control for prioritized network packet transmission. Classification of network data priorities can be based on Priority Queues. This QoS support allows you to run bandwidth-intensive and delay-sensitive applications, and is of particular importance to IP phone and Internet server cameras attached to your network.
The DES-1316K supports port mirroring to assist network traffic monitoring. Your network administrator can use this function as a diagnostic tool or debugging feature, especially when fending off an attack. It enables you to keep close track of switch performance and alter it, if necessary. Port mirroring can be managed locally or remotely. Your administrator places a protocol analyzer on the port receiving the mirrored data to monitor each segment separately. The analyzer captures and evaluates the data without affecting the client on the original port.
The DES-1316K is designed as an affordable solution for business to implement security, QoS and power sourcing without having to go through complex SNMP network management. All functions can be configured for the switch from any network station via an Internet browser, dispensing you of the need to set up consoles and connect console cables.
מאפיינים כללים
Standards and responsibilities
· IEEE 802.3af Power over Ethernet (PoE)
· IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
· IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
· ANSI / IEEE 802.3 NWay autodetect speed mode
· IEEE 802.3x Flow control is
· Port mirroring
Number of Ports
· 16 Port 10BASE-T/100BASE-TX (8 ports support PoE, 8 ports without PoE)
Arrangement of the ports PoE
· Wires 1, 2, 3 and 6 in the cable category 5
Minutes
· CSMA / CD
Data Transfer Rate
· Ethernet:
· 10M bps (Half)
· 20 Mbps (full duplex)
· Fast Ethernet:
· 100 Mbit / s (Half)
· 200 Mbps (full duplex)
Topology
· Star
· Network Cables
· UTP categories. 5, 5e (100 m max.)
· EIA/TIA-568 100 ohm STP (100 m max.)
Interface medium
· Auto-polarity of MDI / MDI-X on all ports for twisted pair
Indicators
· Power (per device)
· CPU (per device)
· Link / Act, Speed (per port)
· 100 Mbps (per port)
· PoE (per port PoE)
PoE
· Ports PoE
· Ports 1 to 8
Feeds
· Up to 15.4 watts per port
Autodetection
· Automatic identification of connected devices and PoE automatic sheet feeding
Auto
· Automatic disconnection of the port in case of
· exceeding the maximum load current 350mA
· Active protection
· Automatic disconnection of the port in case of short circuit
Software
VLAN
· Default: VLAN 802.1Q
· Maximum number of VLAN *: 16 per device
· Range VLAN (VID) restricted values 1-511
Quality of service QoS
· Maximum number of rounds: 2
· Based on the port
· Channel Aggregation
· Standard: IEEE 802.3ad
· Max. 4 ports per channel
· 1 composite channel device
Controls and settings
· Web-management interface
· Web-Management Utility to update the software for Windows
· Resetting the configuration settings through the
· software or hardware (the button Reset)
The management and configuration
· Adjusting the speed / half / full duplex mode
· Setting power at port
· Auto-connected devices
Productivity
· Productivity internal line
3.2 Gb / s
The method of switching
· Store-and-forward
The amount of MAC-address table
· 4 K entries per device
Study of MAC-addresses
· Automatic Updates
The speed of filtering / packet (Half)
· Maximum 1488095 packets / sec. at port
Buffer RAM
· 512 KB per device
Physical parameters
Dining
· 100-240V AC, 50/60Hz, internal universal power supply
· Power consumption
· Maximum 9 watts to the device (without connected devices PoE)
· Maximum 130 watts to the device (if you connect all the devices 8 PoE)
Dimensions
· 440 (width) x 140 (depth) x 44 (H) mm
· For installation in standard 19-inch rack, 1U height
· Weight
2.15 kg
· Operating temperature
0o to 55o C
· Storage Temperature
-10o to 70o C
Working humidity
· From 10% to 90% without condensation
Humidity in storage
· From 5% to 90% without condensation
EMI Certifications
· FCC Class A
· CE Class A
· VCCI Class A
Safety
· UL
· CUL
· TUV
