DES-3526DCEOL EOS
מתג מנוהל 24 פורטים +Layer2 במהירות 10/100 + 2 פורטים ג'יגהביט + 2 פורטים Combo SFP (הזנת 48V DC)
תאור
The D-Link® xStack™ DES-3526 is a high-performance, managed, stackable Layer 2 switch that provides an ideal solution for workgroups and departments. D-Link Single IP Management (SIM) allows to cluster up a virtual stack of up to 32 DES-3526 switches dispersed switches with fewer distance limitation through a single IP address. The clustering environment spans buildings, making it perfect for businesses that require multiple building deployment. The xStack switch also provides comprehensive security for edge access such as Access Control List, DHCP server screening, and DoS attack prevention.
Learn more. Download the D-Link End Point Security Strategy Whitepaper
Non-Blocking Switching
The D-Link xStack DES-3526 provides non-blocking switching solution for a 10/100 fast Ethernet connection. The DES-3526 supports 24 10/100Mbps ports, with 2 gigabit 10/100/1000BASE-T ports. These gigabit copper ports will be disabled if the two 1000BASE-X SFP are used - known as dual personality or combo ports. The DES-3526 has a non-blocking bandwidth of 8.8Gbps and has a redundant power option for mission critical apps.
D-Link Safeguard Engine and Security
The DES-3526 incorporates advanced mechanisms to detect an attack against the central processing unit of the switch and to take corrective action on the attacking interface. When a Denial of Service (DoS) attack is waged against the xStack switches, the D-Link Safeguard Engine detects the threat and prevents overload of the central processor thus insuring network integrity and helping to maintain open network bandwidth channels.
In addition, the DES-3526 supports 802.1x authentication, which is a secure means to allow users to log onto your network. When used in conjunction with a RADIUS server, 802.1x requires each user workstation attached to the xStack switches to provide a username and password before gaining access to the local area network. Other security features include access control list, which an administrator can restrict the access of a network through a variety of means including MAC address, IP, UDP/TCP, and even VLAN ID.
For edge network security, the DES-3526 supports features such as DHCP server screening, client filtering, and IP-MAC-Port Binding to prevent security breaches such as rogue DHCP server, man-in-the-middle attacks or IP spoofing. For clients with Windows® XP SP3, Windows Vista®, or servers with Microsoft® Windows Server 2008, the DES-3526 works in conjunction with the Microsoft® Network Access Protection (NAP) as part of an ecosystem that enforces compliance with network health policies. xStack switches will grant network host access only if it complies with IT security policies such as up-to-date anti-virus signatures and operating system patches. This prevents an infected client or server from gaining access and further contaminating the network.
Ease of Management
DES-3526 supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize the productivity of the network. Other standard management features are also supported including RMON, intuitive Web-based graphic interface, and industry-standard Command Line Interface (CLI).
IP Clustering Stackable
The xStack DES-3526 includes D-Link Single IP Management Technology (SIM), which allows a set of switches to be managed by a single IP, regardless of geographical locations. Traffic running across units in this virtual stack utilize full-duplex interfaces and network wires, eliminating costly and cumbersome cables. Without any stacking cables, cable distance barriers, and physical stacking limitations, your stack can be comprised of units that are located anywhere on the network, minimizing the impact of any single point of failure. Furthermore, multiple xStack switches can be configured, monitored, and maintained from any workstation running a Web browser through one unique IP address. The stack is managed as a single object, with all units identified by a single IP address. You can see a Tree View of the members of the stack and a network topology showing the locations of the units and their link information. This simple yet powerful Web-based management eliminates the need for you to install expensive SNMP network management software. Add up to 32 switches per stack, not limited to any specific D-Link models. With embedded SIM, you can expand your Ethernet stack to include L3 core Gigabit and chassis based switches to accommodate your network growth.
Voice and Video Applications
For today’s business, having voice, data and video on the same network is common practice. This challenge is met by the D-Link DES-3526, which supports 802.1p with 4 queues. The administrator can designate the priority of the traffic based on a variety of means including IP or MAC address, so that voice data always is always clear and jitter free. Video traffic can also be assigned with the same priority. In addition, the D-Link DES-3526 provides IGMP Snooping, which allows the forwarding of multicast packets such as streaming audio, video, without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations who have joined the multicast group is created. This list then allows the switch to intelligently forward packets to only the appropriate member workstations. In conjunction with 802.1Q VLANs, Quality of Service and security can be achieved on a network infused with data traffic.
For other multimedia-on-demand applications, such as IPTV deployments, the xStack DES-3526 provides advanced features for easy video streaming management. For example, this xStack supports per port multicast stream control, which allows a service provider to assign limited multicast addresses per port. This means it can act as a security control pre-configured channels for each subscriber on a port level to prevent unauthorized multicast access. DES-3526 also supports IGMP multicast VLAN, which eliminates duplicate multicast traffic being sent to clients in different VLANs and thus removing bottlenecks in the uplink port.
מאפיינים כללים
Interface
10/100BASE-TX Ports
24
Combo 10/100/1000BASE-T Ports/SFP Slots
2
Auto-Negotiation of Network Speeds (RJ-45 Ports)
Yes
Auto-MDI/MDIX (RJ-45 Ports)
Yes
RS-232 Console Port
Yes
Power
Internal Power Suply
AC to DC
Power Input
100 to 240VAC, 10A, 50 to 60Hz
Power Output
12VDC, 5A Maximum
Power Consumption
23 Watts Maximum
Optional Redundant Power Supply
Yes
Performance
Switching Capacity
8.8Gbps
Maximum 64-Byte System Packet Forwarding Rate
6.6Mpps
MAC Address Table
8K
Packet Buffer Size
16MB
Diagnostic LEDs
10Mbps or 100Mbps Speed (Per Ethernet Port)
Yes
10/100Mbps or 1000Mbps Speed (Per Gigabit Port)
Yes
Link/Activity (Per Port)
Yes
Power, Console, RPS (Per Device)
Yes
Physical & Environmental
Ventillation DC Fans
1 Fan (1.6” x 1.6”)
BTU/Hour
73.8
Dimensions (W x D x H)
17.4” x 8.1” x 1.7” (441mm x 207mm x 44mm)
Size
19-inch Standard Rack-Mount Width, 1U Height
Weight
5.64lbs (2.56kg)
Temperature
Operating: 32° to 104°F (0° to 40°C)
Storage: -40° to 158° F (-40° to 70° C)
Humidity
5% ~ 95% Non-condensing
EMI
FCC Class A, CE, C-Tick
Safety
CSA International
MTBF
53,838 Hours
Acoustic (Refer to ISO-7779)
< 34dB
Software Functions
VLAN
IEEE 802.1Q Tagged VLAN
Port-based VLAN
Maximum Number of VLANs per Device: 255 VLANs (Static and Dynamic Combined)
GARP/GVRP
Priority Queues (CoS)
Standard: IEEE 802.1p
Number of Queues: 4
Traffic Classification (Cos) Can be used on user-definable application types:
TOS
Diffserv (DSCP)
Port-based
MAC Address
IP Address
TCP/UDP Port Number
Security
Port Security (64 MAC Addresses Maximum)
802.1x Port-based Access Control
802.1x MAC-based Access Control
SSH v1, v2
SSL v2
Per Port Traffic Segmentation
IP-MAC-port Binding (512 Entries)
DHCP Client Filtering
DHCP Server Screen
NetBIOS Filtering
TACACS
RADIUS Authentication for Management
Access Control List Multi-layer ACL (100 entries) based on:
Port Number
TOS
Diffserv (DSCP)
MAC Address
IP Address
Packet Prototcol Type
TCP/UDP Port Number (User-definable Application Types)
TCP/UDP Payload (User-definable Packet Content)
Per Port ACL Definition
Spanning Tree Protocol
802.1D Spanning Tree Compatible (802.1D, 2004)
802.1w Rapid Spanning Tree (Ring Protection with Network Recovery Time of Less Than 15 Seconds)
Per Port BPDU Filter
IP Multicast
IGMP v1, v2
IGMP Snooping (128 Groups)
Enable Definite VLAN for Multicast
IGMP Fast Leave
User-definable Per-port IP Multicast Range Limit
Port Trunk
Maximum Number of Ports per Trunk: 8
Maximum Number of Trunks per Device: 6
Operation Mode: Load Sharing
802.3ad compatible Link Aggregation (LACP) Static and Dynamic Modes on Uplink and Downlink Ports for Traffic Load Balance and Redundancy
Performance Enhancement Functions
Bandwidth Control from 1Mbps to the Port’s maximum Rate (in steps of 1Mbps)
Broadcast Storm Control: User-configurable from 1pps (Packet per Second)
CPU Interface Filtering
Firmware Upgrade
TFTP Remote Upgrade
Management Support
Single IP Management (SIM) v1.6
RMON v1 Monitoring
Telnet Client
Telnet Server (Up to 8 Sessions)
SYSLOG
Dual Images
Web GUI Traffice Monitoring
Web-based MAC Address Browsing
RFC 2030 SNTP (Simple Network Time Protocol)
SNMP v1, v2c, v3
Bootp/DHCP Client
DHCP Relay Option 82
Loopback Detection
Password Recovery
Three-level User Account
MIBs
802.1Q Q-BRIDGE-MIB (RFC 2674)
802.1p P-BRIDGE-MIB (RFC 2674)
MIB-II (RFC 1213)
Bridge MIB (RFC 1493)
RMON MIB (RFC 1757) Group 1, 2, 3, 9 (Alarm, Statistics, History, Event)
IGMP MIB (RFC 2933)
IF MIB (RFC 2933)
Ethernet-like MIB (RFC 1643)
PING-MIB and TRACEROUTE-MIB (RFC 2925)
ICMP Ping by MIB
Rate Limiting by MIB
Save Configuration by MIB
802.1w Setting and Read by MIB
Port Interface MIB-II Trap (RFC 1215)
D-Link Enterprise MIB
Optional SFP Transceivers
DEM-310GT
SFP Transceiver for 1000BASE-LX, Single-mode Fiber, Maximum Distance 10km, 3.3v
DEM-311GT
SFP Transceiver for 1000BASE-SX, Multi-mode Fiber, Maximum Distance 550m, 3.3v
DPS-200
60-watt Redundant Power Supply
DPS-800
2-slot Redundant Power Supply Chassis
DPS-900
8-slot Redundant Power Supply Chassis
Management Software
DS-510
D-View® 5.1 SNMP Network Management Program
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DES-3526
xStack 24-Port 10/100BASE-TX Switch with 2 Combo SFP/1000BASE-T Gigabit Ports
DES-3550
xStack 48-Port 10/100BASE-TX Switch with 2 Combo SFP/1000BASE-T Gigabit Ports
DEM-310GT
SFP Transceiver for 1000BASE-LX, Single Mode Fiber, Maximum Distance 10Km
DEM-311GT
SFP Transceiver for 1000BASE-SX, Single Mode Fiber, Maximum Distance 550M
DPS-200
DPS-800
2-Slot Redundant Power Supply Chassis
DPS-900
8-Slot Redundant Power Supply Chassis
DS-510
D-View 5.1 SNMP Network Management Program
תקנים
הורדות
איורים
DES-3526DC/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
