DES-6504EOL EOS
תאור
The DES-6504 is a 12-port 100BASE-FX Fast Ethernet Module for the DES-6500 Series Switch. Designed for linking core switches, this 100Mbps High-Performance module supports the LC connector for superior performance. With multimode fiber-optic cable connections, this module supports traffic passing at distances up to 2km in full-duplex mode.
The DES-6504 100BASE-FX module is fully compliant with IEEE 802.3u and 802.3x standards, so compatibility is never a concern. With 802.3x compliant support for flow control, your data will arrive with greater dependability and less packet loss. The DES-6504 is a perfect solution for the bandwidth hungry network needing greater flexibility, longer cabling distances, and the reliability of a state of the art, laser driven, fiber optic channel.
מאפיינים כללים
Technical Specifications
DES-6504
LEDs
Interface Options
LC
Network Protocols and Standards
IEEE
Physical and Environmental
Temperature
Humidity
Weight
Dimension
A/C Inputs
Power Consumption
Warranty
EMI
Ordering Information
Part Number
DES-6504
