DES-6508EOL EOS
מודול 16 פורטים 10/100base-TX RJ45 למארז DES-6500
היכן לקנות
תאור
•    Back pressure support for half-duplex mode
•    IEEE 802.3x compliant Flow Control support for full-duplex
•    Auto-sensing and auto-negotiation of 10/100Mbps speeds
•    Fully complies with IEEE 802.3 10BASE-T, 802.3u 100BASE-TX
•    Slide-in card module for DES-6500 chassis switch
•    16 RJ-45 10/100BASE-TX Ethernet ports
The DES-6508 is a 12-Port RJ-45 Module for the D-Link DES-6500 Chassis Switch. This module supports up to 12 10/100BASE-T ports and is fully compliant with the IEEE 802.3ab standard.
The DES-6508 follows all industry standards. It provides auto MD-I/MDI-II crossover on all ports, and also includes a full panel of LED light indicators displaying link established, link down, and link activity. By pressing the hot swap button, the module can be removed without affecting the performance of the xStack DES-6500 Chassis switch.
מאפיינים כללים
Specifications:
Hardware
Standards
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX
ANSI / IEEE 802.3 NWay auto-negotiation
IEEE 802.3x Flow control is
Minutes
CSMA / CD
Topology
Star
Data Transfer Rate
Ethernet:
10 Mbps (half-duplex mode)
20 Mbps (Full mode)
Fast Ethernet:
100 Mbps (half-duplex mode)
200 Mbit / s (Full mode)
Network cable
Ethernet cable 5 th category (maximum length 100 m)
Number of Ports
16 Port 10/100BASE-TX Ethernet
Connectors
16 RJ-45 connectors
Physical parameters:
Input voltage AC
From 90 to 264 V alternating voltage, 47/63 Hz
Through the power adapter modular switch DES-6500
Power consumption
Maximum 27 watts
Operating temperature
From 0 º to 40 º C
Storage Temperature
From -25 º to 55 º C
Humidity
Relative humidity from 5% to 95% without condensation
Dimensions
330 mm x 281 mm x 27,5 mm
Electromagnetic Safety (EMI)
FCC Class A
CE
VCCI
C-Tick
Contents of package
DES-6508 16-port 10/100BASE-TX Module
Quick Install Guide
נתונים פיזיים
תקנים
הורדות
איורים
DES-6508/A
מראה מקדימה
דף מידע
ראה גם
