DES-6510EOL EOS
מודול 24 פורטים 10/100base-TX RJ21 למארז DES-6500
תאור
Works With:
9-slot 160Gbps Chassis Switch
DES-6500
24-Port RJ21 to RJ45 Patch Panel For DES-6500 Chassis
DES-6506
The DES-6510 is a 2 port RJ-21 Telco 50 Module for the D-Link DES-6500 Chassis switch. This module supports up to 24 10BASE-T/100BASE-TX ports and is fully compliant with IEEE 802.3, and 802.3u standards. When combined with the DES-6506 24-port RJ-21 to RJ-45 patch panel, an additional 24 RJ-45 10/100 ports are at your disposal. This space saving module is perfect for those who need additional network support without the overhead of adding multiple blades to your chassis.
The DES-6510 features IEEE 802.3x compliant Flow Control support for Full-duplex, back pressure Flow Control support for Half-Duplex, and full auto-negotiation and auto MDI/MDI-X cross over on all ports. The DES-6510 includes LED light indicators that displays power, port speed, link, and activity.
מאפיינים כללים
Technical Specifications
DES-6510
24-Port 10/100Mbps RJ-21 Module
LEDs
Per unit: Power
Per Port: Speed, link/activity
Interface Options
RJ-21
2 RJ-21, each support 12-port 10BASE-T/100BASE-TX ports
Network Protocols and Standards
IEEE
IEEE802.3 10BASE-T, IEEE802.3u 100BASE-TX
Back pressure Flow Control support for Half-duplex mode
Physical and Environmental
Temperature
Operating: 0° to 50° C (32° - 122° F)
Storage: -25° to 55° C (-13° - 131° F)
Humidity
Operating 20% to 80%, non-condensing
Storage: 5% to 95%, non-condensing
Dimensions
330mm x 281mm x 27.5mm (12.9in x 11.06in x 1.08in)
A/C Inputs
90-264vac, 47/63hz
Power Consumption
28watts max
EMI
FCC Class A, CE mark, VCCI, C-Tick
Ordering Information
Part Number
Description
DES-6510
24-Port 10/100Mbps RJ-21/Telco 50 Module
תקנים
הורדות
איורים
DES-6510/A
מראה מקדימה
דף מידע
ראה גם
