מאפיינים כללים:
Product Specifications |
DES-3010GA |
Managed Layer 2 Switch with (8) 10/100Mbps Ports and (1) Gigabit SFP and (1) 1000BASE-T copper port | |
MAC Address Table Size |
Switch Fabric |
Transmission method |
Forwarding Rate |
14,880pps (10M), 148,800pps (100M), 1,488,000pps (1000M) | |
VLANs |
Support up to 256 VLAN Groups | |
Priority Queues |
Packet Buffer |
Multicast Support |
Interface Options |
RJ-45 |
10BASE-T, 100BASE-TX & 1000BASE-T | |
SFP/mini-GBICs |
1000BASE-X support based on Type of SFP, LC | |
Network Management |
In Band & Out of Band |
Telnet, CLI/Console, RMON, Web-based HTTP, SNMPv1/2/3, Port Mirroring, SSH, SSL | |
Network Protocol and Standards |
IEEE |
802.3 Ethernet, 802.3u Fast Ethernet, 802.1D Spanning Tree, 802.1w Rapid Spanning Tree, 802.1s Multiple Spanning Tree, 802.1p Priority Tags (4 queues), 802.3ad Link Aggregation Control (8 ports per group/ 6 groups per device), 802.3x Flow Control, 802.1x (Port & MAC Based Network Access Control), 802.1Q VLANs (up to 256), Private VLANs, Guest VLANs | |
IETF |
RFC1757 RMON (4 Groups), RFC1493 Bridge, RFC1643 Ether-like MIB, RFC2358 ETHER LIKE_MIB, RFC2674 | |
Additional Feature |
IGMP Snooping, Telnet, TFTP Client, BootP Client, DHCP Client, SNMP v1/2/3, Rate Limiting down to 64k , QoS classification based on TOS, Traffic Monitoring, MAC address browsing, Port Description, CPU Utilization Monitoring, SNTP, Radius Authentication, TACACS+ Authentication, Auto-Negotiation, Port Mirroring, Broadcast Storm Control, SYSLOG, GVRP | | נתונים פיזיים
Electrical & Emissions Summary |
Emissions |
CE Class A, FCC Class A, C-Tick, VCCI Class A | |
Power Supply |
AC Input: 100 - 240 VAC, 50-60 Hz | |
Power Consumption |
Heat Dissipation |
Safety Agency Certifications |
Safety |
Physical and Environmental |
Dimensions |
Weight |
Temperature |
Operating: 32° to 104°F (0° to 40° C) |
Storage: -40° to 158°F (-40° to 70°C) | |
Humidity |
Operating: 5% to 95% RH, Non-Condensing | |
Warranty and Support Information |
Warranty* |
Ordering Information |
Part Number |
DES-3010G |
DEM-310GT |
1000BASE-LX SFP/mini-GBIC Up to 500m/10Km (multimode/singlemode) | |
DEM-311GT |
1000BASE-SX SFP/mini-GBIC Up to 220m/550m (multimode) | |
