DES-3010GEOL EOS
מתג מנוהל 8 פורטים Layer 2 + יציאת ג'יגהביט + יציאת SFP
תאור
D-Link® DES-3010G is a high-performance managed Layer 2 switch that provides an ideal solution for workgroups and departments. The DES-3010G is a great entry level managed switch for the SMB just starting out or the already established business looking to bring a managed solution to the desktop. The fiber uplink can provide connectivity for a small group of users over a larger distance such as on a campus or between indoor classrooms. The DES-3010G has (8) 10/100Mbps Fast Ethernet ports and an SFP port for high seed uplinks to servers and/or backbones. In addition the DES-3010G is also equipped with a copper 1000Base-T port for easy uplinks to standard Gigabit copper switches. With a total 10 ports, The DES-3010G is truly unique in its class.
Watch episode on DES-3010 high performance managed layer 2 switch series.
Advanced Layer 2 Switching
With a 5.6Gbps switch fabric, the DES-3010G is a wire-speed, high performance switch. It includes support for Private VLANs (for isolating ports to protect privacy), and Guest VLANs (for temporary and limited access). Guest VLANs are useful when migrating end users to an 802.1x environment when existing workstations do not yet support the 802.1x protocol, and for delivering limited services such as Internet access to un-authenticated and short-term users. When deployed in a school campus, bookstore, coffee house, or other retail establishment, the DES-3010G can be used in conjunction with wireless Access Points to create a secure Internet Hot Spot. This allows visitors to access special services or surf the Internet, completely isolated from sensitive internal network data.
Investment Protection
By widely supporting IEEE approved specifications, the DES-3010G leverages your existing investment in a multi-vendor environment, while maximizing compatibility of business critical features like, Spanning Tree (802.1D/w/s), QoS (802.1p), Port mirroring, and network management.
D-Link’s DES-3010G has robust support for standards based network management protocols (SNMP/RMON/BOOTP/Telnet/Web and port mirroring) enabling the DES-3010G to be easily integrated into many third-party network management packages.
Advanced Enterprise Features
The DES-3010G brings advanced enterprise functions to a more affordable level while supporting advanced features: QoS/CoS based on (802.1p, Port, DSCP and TOS), rich security and management features such as 802.1x (Port & MAC Based Authentication), bandwidth control, and Guest VLANs. The DES-3010G also supports many of the features you would expect to see on a larger managed solution such as: IGMP snooping, 802.3ad (Link Aggregation), 256 VLANs, Private VLANs, and support for GVRP, traffic monitoring, SSH, SSL, SYSLOG, and more.
מאפיינים כללים
Product Specifications
DES-3010GA
Managed Layer 2 Switch with (8) 10/100Mbps Ports and (1) Gigabit SFP and (1) 1000BASE-T copper port
MAC Address Table Size
8k
Switch Fabric
5.6Gbps
Transmission method
Store-and-Forward
Forwarding Rate
14,880pps (10M), 148,800pps (100M), 1,488,000pps (1000M)
VLANs
Support up to 256 VLAN Groups
Priority Queues
4 Queues
Packet Buffer
128 KB
Multicast Support
IGMP Snooping
Interface Options
RJ-45
10BASE-T, 100BASE-TX & 1000BASE-T
SFP/mini-GBICs
1000BASE-X support based on Type of SFP, LC
Network Management
In Band & Out of Band
Telnet, CLI/Console, RMON, Web-based HTTP, SNMPv1/2/3, Port Mirroring, SSH, SSL
Network Protocol and Standards
IEEE
802.3 Ethernet, 802.3u Fast Ethernet, 802.1D Spanning Tree, 802.1w Rapid Spanning Tree, 802.1s Multiple Spanning Tree, 802.1p Priority Tags (4 queues), 802.3ad Link Aggregation Control (8 ports per group/ 6 groups per device), 802.3x Flow Control, 802.1x (Port & MAC Based Network Access Control), 802.1Q VLANs (up to 256), Private VLANs, Guest VLANs
IETF
RFC1757 RMON (4 Groups), RFC1493 Bridge, RFC1643 Ether-like MIB, RFC2358 ETHER LIKE_MIB, RFC2674
Additional Feature
IGMP Snooping, Telnet, TFTP Client, BootP Client, DHCP Client, SNMP v1/2/3, Rate Limiting down to 64k , QoS classification based on TOS, Traffic Monitoring, MAC address browsing, Port Description, CPU Utilization Monitoring, SNTP, Radius Authentication, TACACS+ Authentication, Auto-Negotiation, Port Mirroring, Broadcast Storm Control, SYSLOG, GVRP
תקנים
הורדות
איורים
DES-3010G/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
