תאור
מאפיינים כללים
2.4GHz Wireless LAN 802.11g Indoor Wireless Access Point The AirPlus G DWL-G700AP is an 802.11g standard high-speed wireless access point designed for cost-effective home and small office wireless connection. This device features the latest advanced wireless silicon chip technology with enhanced security to shield and protect your wireless communication from intruders. It provides high network speeds of up to 54Mbps when used with other 802.11g standard wireless products, delivering throughput speeds capable of handling heavy data payloads. Up to 54Mbps Wireless Speed Easy Migration to Higher Bandwidth The DWL-G700AP access point provides speeds of up to 54Mbps when used with other 802.11g equipment. This enhanced speed and adoption of 2.4GHz frequency, now available for public use in most countries, plus the mobility and convenience inherent in a wireless LAN, make this device an ideal solution for bandwidth intensive wireless applications at home and office. The DWL-G700AP access point is backward compatible with 802.11b standard wireless devices, providing seamless interoperability with the earlier standard equipment. By maintaining compatibility with your existing wireless network equipment, this device lets you upgrade to a higher speed while protecting your past investments in networking. Advanced Network Security The DWL-G700AP provides maximum security by supporting standard WEP 64/128-bit data encryption and Wi-Fi Protected Access (WPA), which includes support for TKIP (Temporal Key Integrity Protocol), Pre Shared Key (PSK) and 802.1x user authentication (used in conjunction with a RADIUS server). In addition, this AP also supports the latest-standard WPA2 that features AES (Advanced Encryption Standard) with backward compatibility with WPA. The access point includes an embedded DHCP server that can automatically assign IP addresses to wireless network clients for network access. MAC Address Filtering and Disable SSID Broadcast are some other highlights of this wireless AP, designed to give everything a network administrator needs to set up a robust wireless network security. 802.11g 2.4GHz standard Up to 54Mbps wireless data transfer rates 10/100BASE-TX port for connection to Ethernet or DSL/cable modem Compatible with existing 802.11b wireless devices Built-in DHCP server for multiple user access 64/128-bit WEP data encryption WPA and the latest standard WPA2 security support Web-based configuration & management * Maximum wireless signal rate based on standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors may lower actual data throughput rate.
