מאפיינים כללים:
Technical Specifications |
DES-3828 |
xStack Managed 24 Port 10/100 Stackable L3 Switch, 4 Gigabit Copper Ports, 2 Combo SFP | |
Packet Buffer |
MAC Address Table |
IP Address Table |
IP Routing |
128 Static/ 2K Total Hardware Routing Table | |
Aggregated Bandwidth |
Transmission Method |
Forwarding Rate |
14,880pps (10M), 148,800pps (100M), 1,488,000pps (1000M) | |
VLANs Support |
Up to 4K Static, 255 Dynamic 802.1p VLAN Groups | |
Priority Queues |
8 Queues - Strict Priority or Weight Round Robin Queue Scheduling | |
Classification ACLs |
MAC Address, IP Address, TCP/UDP Port Number & Payload, Physical Port, DSCP, 802.1p,VLAN, Protocol Type | |
Classification QoS |
MAC Address, IP Address, TCP/UDP Port Number, Physical Port, DSCP, ToS | |
Multicast Support |
IGMP v1/2/3, IGMP Snooping, PIM-SM, PIM-DM, DVMRP | |
Jumbo Frames |
Number of IP Interfaces per VLAN |
Multicast Duplication |
Hardware Packet Replication on 8 VLANs on FE Ports and 32 VLANs on GE Ports | |
Port Security |
Supports 16 MAC Addresses per Port | |
Broadcast Storm Bandwidth Control |
Minimum Granularity: 1pps per Port | |
IP-MAC-Port Binding |
Supports 500 Entries per Device | |
D-Link Safeguard Engine |
Protect CPU from Broadcast/Multicast/Unicast Flooding | |
CPU Monitoring |
Utilization via Web/CLI/SNMP. Trap /Logging Notification When Configurable Threshold Reached | |
Interface Options |
RJ-45 |
10BASE-T, 100BASE-TX, 1000BASE-T | |
LC |
With Optional Standard Small Form-Factor Pluggable (SFP) Gigabit Transceivers | |
RPS |
Redundant Power Option Via Optional (DPS-200) | |
Network Management |
In Band & Out of Band |
Telnet, CLI/Console, RMON, Web-based HTTP, SNMPv1/v2/v3, Syslog, Port Mirroring, TFTP Client, BootP Client, DHCP Client, BootP/DHCP Client, IEEE 802.3 Ethernet, 802.3u Fast Ethernet, 802.3ab Gigabit Ethernet, 802.3z Gigabit Ethernet, 802.1d Spanning Tree, 802.1w Rapid Spanning Tree, 802.1p Priority Tags, 802.1q VLANs (4K static/ 255 dynamic), 802.3ad Link Aggregation (32 Groups/8 ports), 802.3x Flow Control, 802.1x Port-based /MAC based control, 802.1s (Multiple Spanning Tree), WRED congestion control, STP loopback detection, GVRP, Guest VLAN, Per port limit IP multicast address range, Web GUI Traffic Monitoring, Web MAC address Browsing, SNMP Trap on MAC Notification, DHCP Relay Option, DHCP Auto-configuration, Trap/Alarm/Log Severity Control, Dual Image, Dual Configuration, Port Description, Editable Login Banner, Editable System prompt, Virtual Interface/Loopback Interface* | |
IETF |
RFC 1157 SNMP, RFC 1112/2236 IGMPv1/2 IGMPv3, RFC 1757/2021/2819 RMON (4 Groups), RFC 1493 Bridge MIB, RFC 1213 MIB II, RFC 793 TCP, RFC 826 ARP, RFC 854 Telnet, and DiffServ, RFC 1724 RIP v1/2, RFC 1850 OSPF, DVMRP, RFC 2934 PIM-DM, PIM-SM, RFC 2932 Multicast Routing, RFC 2787 VRRP, RFC 2096 IP Forwarding Table, RFC 2618/2620 RADIUS Client, RFC 2863 IF MIB, RFC 2674 802.1p MIB, RFC 2665 Ether-like MIB, SSH, SSL, TACACS+, IGMPv3 MIB, RFC 2620 RADIUS Accounting Client MIB | |
Electrical & Emissions Summary |
Emissions |
CE Class A, FCC Class A, VCCI Class A, C-Tick Class A | |
Power Supply |
AC Input: 100 - 240 VAC, 50/60 Hz Internal Universal Power Supply | |
Power Consumption |
Safety Agency Certifications and Environmental |
Safety |
CSA International, CB Report | |
Temperature |
Operating: 32° to 104° F (0° to 40° C) |
Storage: -40° to 158° F (-40° to 70° C) | |
Humidity |
Operating: 10% to 85% RH, Non-Condensing |
Storage: 5% to 95% RH, Non-Condensing | |
Physical Specifications |
Dimensions (W x D x H) |
12.16in x 17.36in x 1.73in (339mm x 441mm x 44mm) 1U Rack-mount size | |
Weight |
Accoustic Value |
Warranty Information |
Warranty |
Ordering Information |
Part Number |
DES-3828 |
xStack Managed 24-Port 10/100 Stackable L3 Switch, 4 Gigabit Copper Ports, 2 Combo SFP | |
DEM-310GT |
1000BASE-LX SFP Module up to 10Km | |
DEM-311GT |
1000BASE-SX SFP Module up to 550m | |
DPS-200 |
Redundant Power Supply Unit, 60 Watt RPSU | |
DPS-800 |
2 Slot Redundant Power Supply Unit Chassis, for DPS-200 | | נתונים פיזיים
