DGS-3627GEOL EOS
מתג מנוהל 24 פורטים (Layer3 Mini GBIC (SFP, בנוסף 4 פורטים Combo 1000Base-T/Mini GBIC SFP ו-3 סלוטים להרחבות
תאור
The latest generation of D-Link® xStack™ Switches supports IPv6 routing and has more advanced features than ever to address today's security, QoS, and management concerns. The DGS-3627G switch is the fiber version of the DGS-3627 equipped with 4 combo 10/100/1000 Base-T ports and 3 optional 10Gigabit uplinks.
Learn more. Download the D-Link End Point Security Strategy Whitepaper
The D-Link DGS-3627G switch is equipped with robust features that fulfill the most demanding network's needs for voice and video streaming. Stackable up to 12 units under a single IP, the switch is able to provide a total of up to 576Gbps aggregated bandwidth fixed-in. To help secure your network, the D-Link Safeguard Engine™ helps prevent Denial-of-Service (DoS) attacks while the Access Control List (ACL) enhances network security. The DGS-3627G switch is equipped with industry standard management features including easy-to-use CLI and web-based administrator interfaces. D-Link provides these features on a scalable platform, increasing your company's productivity while protecting your investment.
IPv6 and IPv4 Routing
The xStack DGS-3627G switch provides current IPv4 networks with a simple migration path to IPv6 and protects your investment for future network upgrades when greater security and larger addressing are required. Basic static routing such as RIP and RIP2 are supported for small network routing applications. Advanced routing protocols such as OSPF and equal cost routing are supported for load balancing and building a scalable network.
Stackable Up to 12 Units
The DGS-3627G switch has two optional ports to install stacking modules that provide up to 40Gbps in data stacking backplane, full-duplex. This enhances your overall network performance for switches transmitting large files such as graphics or pictures. Under stacking mode, the switches are hot-swappable. This means that in a stack configuration, any of the switches can be replaced or removed without affecting the network. There is no need to reconfigure a replacement switch; just give the new switch the same stack number ID as the old switch and the network will carry the same configuration as before. This minimizes network downtime and maximizes the productivity of your business. Also, to facilitate network administration, cross stack port mirroring and port trunking are supported.
The D-Link Safeguard Engine and Security
The DGS-3627G switch incorporates advanced mechanisms to detect an attack against the central processing unit of the switch and to take corrective action on the attacking interface. When a DoS attack is waged against DGS-3627G switch, the D-Link Safeguard Engine detects the threat and prevents overload of the CPU, thus ensuring network integrity and helping to maintain open network bandwidth channels.
In addition, the D-Link xStack DGS-3627G switch offers a variety of authentication methods, including those without the requirement of a RADIUS server. It supports MAC based Access Control, which authenticates the user based on the MAC address of the client so that authentication is transparent to the client. It also supports Web-based Access Control, which prompts for username and password before allowing access to TCP traffic. Lastly, the xStack DGS-3627G switch supports Network Access Protection (NAP). This feature works in conjunction with Microsoft® software platforms such as Vista® to reinforce network health and security policies including policy validation, network restriction, remediation, and ongoing compliance.
Voice and Video Applications
For today's businesses, having voice, data, and video on the same network is common practice. This challenge is met by the D-Link xStack DGS-3627G switch, which supports 802.1p with eight queues. The administrator can designate traffic priority based on a variety of means including IP and MAC address, so that voice data is clear and jitter-free. Video traffic can also be assigned with the same priority. In addition, the D-Link xStack DGS-3627G switch provides IGMP Snooping, which allows the forwarding of multicast packets such as streaming audio and video without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations that have joined the multicast group is created. This list then allows the switch to intelligently forward packets to only the appropriate member workstations. For IPv6 traffic, the DGS-3627G switch supports MLD snooping. Multicast routing is supported under independent multicast protocol, including PIM-SM and PIM-DM. DVMRP is also supported to interconnect two multicast-enabled networks across non-multicast networks. In conjunction with support for 802.1Q VLANs, Quality of Service (QoS) and security can be achieved on a network infused with data traffic.
Ease of Management
The DGS-3627G switch supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize network productivity. Other standard management features also supported include RMON and IEEE 802.1d Spanning Tree. User interfaces include an intuitive web-based GUI or standard CLI, with administration traffic protected through SSL or SSH encryptions.
מאפיינים כללים
Interface
Ports
24 (SFP)
Combo Ports
4 (10/100/1000 BASE-T)
Open Slot for 10-Gigabit Uplink Modules
3
RS-232 Console Port
1
Physical Stacking
Optional Module for Stacking
Single-Port DEM-410CX or DEM-410X
Maximum Number of Stacking Ports Optional
2 CX4 or XFP Ports
Stacking Speed (Per Port)
20Gbps (Full-Duplex)
No. of Units Per Stack
12
Optional 10-Gigabit Uplink (Transceivers sold separately)
Single XFP Slot Module (DEM-410X)
Yes
Single CX4 Port Module (DEM-410CX)
Yes
10GBASE-SR (300 m Multi-Mode Fiber) Support
Yes
10GBASE-LR (10 km Single-Mode Fiber) Support
Yes
Maximum Number of 10-Gigabit Uplinks Installable
3
Performance
Switch Fabric
108Gbps
Packet Forwarding Rate
80.36Mpps
Packet Buffer
2MB
MAC Address Table
16K Entries
IP v4 Routing Table
12K Entries
IP v6 Routing Table
6K Entries
IP v4 Host Table
8K Entries
IP v6 Host Table
4K Entries
Jumbo Frame Size
9,216 Bytes
Power
Power Supply
100 to 120VAC, 200 to 240VAC, 50/60Hz, Internal Power Supply
Power Consumption (Maximum)
77 Watts
Optional Redundant Power Supply
DPS-500
Physical/Environmental
Heat Dissipation
262.74 BTU/Hr
Dimensions (W x D x H)
17.4in x 15.3in x 1.7in (441mm x 389mm x 44mm)
Size
19-Inch Rack-Mount Width, 1U Height
Weight (Without Optional Module)
12.1 lbs (5.5 kg)
Temperature
Operating: 32°F to 104°F (0ºC to 40ºC)
Storage: 14°F to 158°F (-10ºC to 70ºC)
Humidity
Operating: 10% ~ 90% RH
Storage: 5% ~ 90% RH
Emissions
FCC Class A, CE, C-Tick,VCCI
Safety
cUL, CB
Software Functions
L2 Features
IGMP snooping v1, v2
1K IGMP Snooping Groups
64 Static Multicast Address
Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
STP Loopback Detection
BPDU Filtering per Port and per Device
Trunking Across Stack
MLD Snooping
1K MLD Snooping Groups
64 Static Multicast Addresses
802.3ad Link Aggregation
Up to 32 Groups per Device
Up to 8 Gigabit Ports or 2 10-Gigabit Ports per Group
Port Mirroring
One-to-One Mode
Many-to-One Mode
Per Flow (ACL) Mode
VLAN
802.1Q
Total 4K VLAN Groups
Maximum 255 Dynamic VLAN Groups
GVRP
802.1v
Maximum 4K Static VLAN Groups
Configurable VLAN ID from 1 to 4094
Double VLAN
L3 Features
L3 Routing
Up to 12K entries (all route entries combined)
Up to 256 IPv4 static route entries
Up to 128 IPv6 static route entries
Up to 12K IPv4 dynamic route entries
Up to 6K IPv6 dynamic route entries
Floating Static Route
IPv4 Floating Static Route
IPv6 Floating Static Route
Policy Based Route
RIPng (IPv6)*
Multiple IP Interfaces per VLAN (Up to 5)
Multi Path Routing Supporting Equal Cost (EC) and Weighted Cost (WC)
VRRP
IPv6 Ready Phase 1
IGMP v1, v2, v3
DVMRP v3
Per Port Limit IP Multicast Address Range for Control Packet
L3 Forwarding
Up to 8K IPv4 Forwarding Entries
Up to 4K IPv6 Forwarding Entries
Up to 8K Entries (all L3 Hardware Forwarding Entries Combined)
OSPF v2
OSPF Passive Interface
OSPF NSSA (Not So Stubby Area)
OSPF Equal Cost Route
RIP v1, v2
Up to 64 IP Interfaces
Multicast
Up to 64 Static Multicast Groups
Up to 1K Dynamic Multicast Groups
Up to 1K Multicast Groups (Static and Dynamic D-Link Safeguard Engine Multicast Groups Combined)
Multicast Duplication (Up to 32 VLAN per Port)
PIM DM for IPv4
PIM SM for IPv4
IPv6 Tunneling
QoS (Quality of Service)
Per Port Bandwidth Control (Granularity of 64Kbits per Second)
Per Flow Bandwidth Control (Granularity of 64Kbits per Second)
802.1p Priority Queues (8 Queues)
Queue Handling Mode Support: WRR and Strict Modes
CoS Based On:
Switch Port
IPv4/v6 Address
Protocol Type
IPv6 Flow Label
User-Defined Packet Content
VLAN ID
MAC Address
DSCP
IPv6 Traffic Class
TCP/UDP Port
ACL (Access Control List)
Up to 8 Profiles
Up to 1792 Global Rules, Each Rule Can Set Its Own Port Range
ACL Based On:
Switch Port
IPv4/v6 Address
Protocol Type
IPv6 Flow Label
Time (Time-Based ACL)
VLAN ID
MAC Address
DSCP
IPv6 Traffic Class
TCP/UDP Port
Security
RADIUS Authentication for Management Access (RFC 2138, 2139)
SSH v2
SSL v3
MAC-based Access Control
Traffic Segmentation
Support Microsoft® Network Access Protection
TACACS+ Authentication for Management Access (RFC 1492)
Port Security (Up to 16 MAC Addresses per Port)
802.1x Port-based/MAC-based Access Control
Guest VLAN
Broadcast/Multicast Storm Control (Minimum Granularity of 1 Packet per Second)
IP-MAC-Port Binding (Up to 500 Entries per Device) Supporting ARP and ACL Modes
Management
Single IP Management v1.6
CLI
Telnet Server
Telnet Client*
SNMP v1, v2c, v3
SNMP Trap on MAC Notification
BootP/DHCP Client
System Log
Trap/Alarm/Log Severity Control
Flash File System
CPU Monitoring via Web, CLI, SNMP
Virtual Interface*
Web-based GUI
Web GUI Traffic Monitoring
Web MAC Address Browsing
TFTP Client
RMON v1, v2
sFlow
DHCP Auto-Configuration
DHCP Relay Option 82
DHCP Server
Dual Image
Dual Configuration
MIBs
MIB-II (RFC 1213)
SNMP v2 MIB (RFC 1907)
RMON v2 MIB (RFC 2021)
802.3 MAU MIB (RFC 2668)
IF MIB (RFC2233, 2863)
IGMP v3 MIB
OSPF v2 MIB (RFC 1850)
VRRP MIB (RFC 2787)
PIM MIB for IPv4 (RFC 2934)
Ping MIB*
L2 Specific MIB
Private MIB
Bridge MIB (RFC 1493)
RMON MIB (RFC 1757, 2819)
Ether-like MIB (RFC 1643, 2358, 2665)
802.1p MIB (RFC 2674)
RADIUS Authentication Client MIB (RFC 2618)
RIP v2 MIB (RFC 1724)
IP Forwarding Table MIB (CIDR) (RFC 2096)
IPv4 Multicast Routing MIB (RFC 2932)
RADIUS Accounting Client MIB (RFC 2620)
Trace Out MIB*
L3 Specific MIB
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3627
xStack Managed 24-Port Gigabit Stackable L3 Switch, 4 Combo SFP Slots, 2 Slots for Optional 10Gig Uplinks
DGS-3627G
xStack Managed 24-Port SFP Stackable L3 Switch, 4 Combo 10/100/1000 BASE-T Ports, 3 Slots for Optional 10Gig Uplinks
DGS-3650
xStack Managed 48-Port Gigabit Stackable L3 Switch, 4 Combo SFP Slots, 2 Slots for Optional 10Gig Uplinks
DEM-310GT
1000BASE-LX SFP LC Transceiver, Up to 10Km
DEM-311GT
1000BASE-SX SFP LC Transceiver, Up to 500m
DEM-410CX
1-Port 10Gigabit CX-4 Module (Includes 1 Meter CX-4 Cable)
DEM-410X
1-Port 10Gigabit XFP Module (XFP Transceiver Sold Separately)
DEM-421XT
10Gigabit XFP 10GBASE-SR Transceiver, up to 300m
DEM-422XT
10Gigabit XFP 10GBASE-LR Transceiver, up to 10km
DPS-500
DPS-800
Redundant Power Supply Rack (Holds Two Units of DPS-500)
תקנים
הורדות
איורים
DGS-3627G
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
