DES-1228PEOL EOS
מתג מנוהל WEB עם 24 פורטים 10/100 PoE ו- 2 פורטים ג'יגהביט +2 יציאות משולבות ג'יגהביט/אופטי (SFP). (מתאים גם לניהול Access points "רזים" מדגם DWL-3140P
תאור
The DES-1228P Web Smart Switch is a cost-effective solution for small and medium businesses that require basic management features, showcased in a low cost, easy to configure, and GUI managed 'smart' business solution. The DES-1228P comes with 24 10/100BASE-TX Fast Ethernet ports, 4 1000BASE-T copper interfaces for uplinking to Storage Area Network (SAN) devices, servers, or core switching solutions, and 2 combo SFP fiber slots for long haul uplinking via optional 100BASE-FX or 1000BASE-X transceivers. The DES-1228P is more versatile than ever with integrated wireless switching features. Whether the end nodes are a wired PC workstation or a wireless client, such as the Web Smart DWL-3140AP, the entire network can be managed via a single unified wired/wireless platform.
Watch episode on how the DES-1228P can help SMB which requires advanced features like VLANs, QoS, LAG, and secure authentication.
Security
The DES-1228P incorporates advanced mechanisms to detect attacks against the central processing unit of the switch and to take corrective action on the attacking interface. When a Denial of Service attack is waged against the DES-1228P, the D-Link Safeguard Engine prevents overload of the central processor, thus insuring network integrity and maintaining open network bandwidth channels. The DES-1228P also supports 802.1x Authentication, which provides a secure means to allow users to log onto your network. When used in conjunction with a RADIUS server, 802.1x requires each user workstation attached to the DES-1228P to provide a username and password before gaining access to the local area network.
Vertical Segment Overview: First All-In-One Wireless and Wired Smart Switch
Unified Wireless and Wired*
Without additional costs or licensing, the administrator of the switch can monitor wired or wireless end nodes via a central web interface. Supporting WEP, WPA, WPA2 authentication, DES-1228P can manage up to 24 access points and up to 200 clients. The unified web smart switch facilitates access point deployment by allowing a set of templates to be created, then distributing the same template to multiple access points via a simple click of a button. With no additional license purchase necessary, the Web Smart Switch supports the 802.11g Web Smart Access Point DWL-3140AP, which has a discrete smoke detector (ceiling-mount) form factor that facilitates deployment. All DWL-3140AP and additional D-Link Web Smart switches can be automatically discovered, allowing network topology and layout to be generated in seconds.
Click here to learn more topics about Smart Switches from D-Link
Link Aggregation
The DES-1228P supports static port trunking of up to 6 groups of 8 ports per device. Ports can be combined together to create a fat pipe to a server or a network backbone. To expand the network, you can also make use of link aggregation eliminating bottlenecks between cascaded switches.
802.1Q VLANs
The DES-1228P provides support for 802.1Q VLANs improving security and bandwidth utilization. VLANs work by segmenting broadcast domains, thus reducing network congestion due to constant network broadcasting. In addition, VLANs provide a means of securing each broadcast domain from all others. This in turn prevents users on one VLAN from gaining access to resources on another VLAN.
802.1p Priority Tagging
For mission critical packets, the DES-1228P supports 802.1p priority tagging to ensure expedited delivery. This feature differs from Port-Based QoS in that 802.1priority tagging allows the administrator to assign and designate the priority of traffic. 802.1p support is ideal for applications such as voice or video traffic so that it is delivered clean and jitter free.
SNMP Management & 802.1D Spanning Tree
The DES-1228P supports SNMPv1. SNMP is a useful tool in managing and controlling SNMP supported network devices. SNMP enables the DES-1228P to be polled to provide valuable information about the status of the unit and send traps on abnormal events. This sharing of vital management information saves time and money. Furthermore, the DES-1228P supports Spanning Tree Protocol, which provides protection from unintentional cabling loops forming within a network infrastructure. Loops are dangerous in that they create an unending circle where broadcast and multicast traffic propagate across the network in an endless loop. This creates a storm of traffic that overwhelms the network and brings traffic to a crawl. 802.1D Spanning Tree detects and breaks these loops ensuring network uptime.
IGMP Snooping
IGMP Snooping enables the forwarding of multicast packets such as streaming audio and video without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations that have joined the multicast group is created. This list then allows the switch to intelligently forward packets to only the appropriate member workstations.
Smart Utility
Included with every DES-1228P is a D-Link exclusive software utility that allows all D-Link smart switches and DWL-3140AP to be discovered automatically with one click of the button.
Managing the DES-1228P has never been easier. Using its built-in browser-based management interface, configuring the switch takes only minutes. With full color graphic pictures, diagrams and easy to understand navigation menus, configuring the DES-1228P with the features you require is as easy as surfing the net. The DES-1228P supports many of today’s most sought after features like 802.1P Priority Queuing, 802.1Q VLANs, Port Trunking, 802.1x Authentication, Port Mirroring, SNMP, 802.1d Spanning Tree, Link Aggregation, IGMP Snooping, Broadcast Storm Control, and more.
* Firmware v.1.20.08 and later.
מאפיינים כללים
Product/Performance
Switching Capacity
12.8Gbps
Number of PoE Ports
24
Forwarding Mode
Store and Forward
Packet Buffer memory
1MB
SDRAM for CPU
8MB
Flash Memory
Prom 2Mb
MAC Address
8K MAC Address Table
IGMP snooping
Supports 64 multicast groups. Support default flooding for non-joined multicast traffic
Supports per device STP & BPDU forwarding
Static Port Trunk
Supports max 6 groups per device and 8 ports per group
Flow Control
Enabled and disabled
Port Mirroring
Supports one-to-one or many-to-one port mirroring
802.1Q
Supports 256 static VLAN groups
VLAN Group
Be able to configure VID from 1-4094
802.1p support
4 Queues
802.1x Port-based Access Control
Default 802.1x forwarding
Allow specifying the per device threshold in terms of 8Kb ~ 4096Kb per second
Static MAC
Support 256 Static MAC entries
Protect CPU from Broadcast/Multicast/Unicast flooding
Web-based GUI
Compatible with IE, Netscape, Mozilla, Firefox, Opera, Safari browsers
SNMP v1
Configurable Community setting, SNMP Trap
DHCP client
Supports DCHP IP Adress for System Interface
802.1ab LLDP
Switch Discovery
Up to 256 agents/switches
Port Setting
Can set Speed, Duplex mode, Flow Control
Configuration Backup/Restore
Via Web GUI
Reboot
Via Web GUI
Wireless Switching Features
Central AP Management
Monitor AP status and wired ports in the same graphic interface
AP Group Management
Maintain a set of setting templates that simplify the task to assign the same settings to multiple APs
Log
System log; Operator action log; SNMP trap log of AP and switch
Syslog Alert
BSD syslog client; adjust send syslog frequency and syslog condition
Central Firmware Upgrade
Select multiple APs and upgrade their firmware at the same time
Alert
Summarize abnormal status in the alert window
AP Topology Monitor
List monitored devices; periodic update on device status
Zero Configuration
One-click technology to restore broken AP’s setting onto its replacement AP
AP Life Check
Real time tracking monitors APs status
AP User Statistics
Maintain all wireless clients connection history and depict statistics in diagrams
AP Traffic Statistics
Maintain all APs traffic history and depict statistics in diagrams
AP Load Balance
Allow to set a group of managed APs to share their loading
WLAN Partition
If enabled, WLAN clients are not allowed to exchange data through the DWL-3140AP
Interface Options
RJ-45 (24 x 10/100BaseT ports & 4 1000Base-T ports)
IEEE 802.3 compliance
IEEE 802.3u compliance
IEEE 802.3x Flow Control support for Full-Duplex mode, Back Pressure when Half-Duplex mode
SFP LC
IEEE 802.3z compliance
Network Management
In & Out of Band
HTTP, SNMP v1
תקנים
הורדות
איורים
DES-1228P/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
