DES-3052EOL EOS
תאור
The DES-3052 is a managed 48-port 10/100 Layer 2 stackable switch with 4 Gigabit ports and 2 Combo SFP slots. This switch allows SMBs to set up a secure and effective network at an affordable cost. With additional features such as enhanced network security, bandwidth control, and advanced management, the DES-3052 is a cost-effective switch that delivers proven results.
Learn more. Download the D-Link End Point Security Strategy Whitepaper
Enhanced Security
The DES-3052 supports many security functions including Access Control List (ACL), 802.1x Port-Based/MAC-Based Access Control, 802.1x Guest VLAN, and RADIUS/TACACS+ authentication.
The D-Link Safeguard Engine incorporates advanced mechanisms to detect an attack against the central processing unit of the switch and to take corrective measures on the attacking interface. When a Denial of Service attack is waged against any of the switches, the D-Link Safeguard Engine detects the threat and prevents the overload of the central processor, thus insuring network integrity and helping to maintain open network bandwidth channels.
802.1Q VLANs
The DES-3052 provides support for 802.1Q VLANs for improved security and bandwidth utilization. VLANs provide a means of securing each broadcast domain, segregating them from each other. This in turn prevents users on one VLAN from gaining access to resources on other network segments. VLANs can be configured to segment departmental resources. For example, VLANs can be implemented on an SMB network to prevent the Marketing department from gaining access to secure resources in the Accounting department.
QoS
802.1p Priority Tagging helps streamline networks by placing a priority tag in a specified frame. When this frame is received by the switch, it is placed in a priority queue, enabling it to be prioritized ahead of other frames. 802.1p enables administrators to assign and designate traffic priority. This process helps applications such as VoIP and video conferencing to be delivered clear and jitter-free. DES-3052 supports a variety of different ways to prioritize the packets to ensure QoS in a busy network.
IGMP Snooping
By passively snooping IGMP packets that are transferred between the DES-3052 and the IP multicast host, registration information is recorded and sorted into multicast groups. The switch can then intelligently forward traffic to only those ports that request multicast traffic. Adversely, without IGMP snooping, multicast traffic is treated like broadcast traffic, with packets forwarded to all ports causing network inefficiencies.
Management
The DES-3052 supports a plethora of standards-based management protocols including SNMP, RMON, Telnet, web-based GUI, SSH/SSL protocols, and DHCP Relay Option 82. D-Link also simplifies management by featuring Single IP Management (SIM); a useful tool that allows multiple switches to be configured, monitored, and maintained from any workstation using a single IP Address. D-Link SIM stacking enables administrators to manage a virtual stack of up to 32 switches under a single IP address. D-Link SIM stacking is ideal for networks where switches may span across different buildings, but still require a shared IP address.
מאפיינים כללים
Interface | |||||||||||||||||||||||||||||||||||||
10/100BASE-TX Ports |
10/100/1000BASE-T Ports |
Combo SFP |
RS-232 Console Port |
Performance | |||||||||||||||||||||||||||||||||||||
Switch Capacity |
64-Byte Packet Fowarding Rate |
MAC Address Table Size |
Packet Buffer |
Flash Memory |
Mini-Jumbo Frame |
Diagnostic LED Indicators | |||||||||||||||||||||||||||||||||||||
Power (Per Device) |
Console (Per Device) |
Link/Activity (Per Port) |
Speed Indicator (Per Port) |
Physical & Environmental | |||||||||||||||||||||||||||||||||||||
Power Consumption |
Power Input |
Dimensions (W x D x H) |
Size |
Weight |
Ventilation |
Heat Dissipation |
MTBF |
Temperature |
Operating Humidity |
EMI/EMC |
Safety |
Interface Options | |||||||||||||||||||||||||||||||||||||
RJ-45 |
LC |
Software Specifications | |||||||||||||||||||||||||||||||||||||
L2 Features |
VLAN |
Quality of Service (QoS) |
Access Control List (Maximum 256 Profiles/Rules) |
Network Access/Security |
Bandwidth Control |
Management |
MIB Support |
Warranty Information | |||||||||||||||||||||||||||||||||||||
Warranty |
Ordering Information | |||||||||||||||||||||||||||||||||||||
Part Number |
DES-3052 |
DES-3052P |
DES-3028 |
DES-3028P |
DEM-310GT |
DEM-311GT |
DEM-211 |
