DGS-3426PEOL EOS
מתג מנוהל 24 פורטים Layer2+ PoE במהירות 10/100/1000 + בנוסף 4 פורטים Combo 1000Base-T/Mini GBIC SFP ו-2 סלוטים להרחבות
תאור
The xStack® DGS-3426P by D-Link is a high-performance, managed, stackable Layer 2+ switch that provides ideal network solutions for workgroups and edge deployments. D-Link® Single IP Management (SIM) allows network administrators to cluster a virtual stack of up to 32 DGS-3426P dispersed switches through a single IP address. The clustering environment spans buildings, making it perfect for businesses that require multiple building deployment. The DGS-3426P also supports physical stacking of up to 12 units in a stack, so that the entire stack can act as a single logical unit with up to 40Gbps of stacking backplane. Furthermore, the xStack switch provides comprehensive security for edge access such as Access Control List, DHCP server screening and DoS attack prevention.
Non-Blocking Switching
The xStack DGS-3426P provides non-blocking switching solutions for gigabit connection and supports 24 Gigabit IEEE 802.3af Power Over Ethernet ports with 2 optional 10Gigabit uplinks. The switch also supports four combo SFP ports, which means that when these ports are enabled, four of the copper gigabit ports will be disabled. When stacked, the xStack DGS-3426P has a stacking backplane of 40Gbps.
Advanced Network Security
For edge network security, the DGS-3426P supports features such as IP-MAC-Port Binding to prevent security breaches such as rogue DHCP server, man-in-the-middle attacks or IP spoofing. For clients with XP SP3, Vista, or servers with Microsoft’s Server 2008, the xStack DGS-3426P works in conjunction with Microsoft’s Network Access Protection (NAP) as part of an ecosystem that enforces compliance with network health policies. The xStack switch grants network hosts access only when compliant with IT security policies, such as up-to-date anti-virus signatures and operating system patches. This prevents a virus-infested client or server from gaining access and furthering contamination.
The xStack switch also supports loopback detection, which detects a loop in the network even though the end device causing the loop is without spanning tree. When the switch detects a loop is in the connected node, the xStack DGS-3426P shuts down the port with the loop so that the entire system will continue to function normally. This feature can also be VLAN based.
The DGS-3426P incorporates advanced mechanisms to detect an attack against a switch’s central processing unit and to take corrective action on an attacking interface. When a Denial of Service attack is waged against the xStack switch, the D-Link Safeguard Engine™ detects the threat and prevents overload of the central processor, insuring network integrity and helping to maintain open network bandwidth channels.
In addition, this D-Link switch supports 802.1x authentication, which allows users to securely log on to your network. When used in conjunction with a RADIUS server, 802.1x requires each user workstation attached to the xStack switch to provide a username and password before gaining access to the network. Other security features include Access Control List, allowing an administrator to restrict network access through a variety of means including MAC address, IP, UDP/TCP, and even VLAN ID.
IP Clustering Stackable
The xStack DGS-3426P provides Single IP Management Technology (SIM), which allows a set of switches to be managed a single IP, regardless of geographical locations. Your stack can be comprised of units that are located anywhere on the network, minimizing the impact of any single point of failure. Furthermore, multiple xStack switches can be configured, monitored and maintained from any workstation running a web browser through one unique IP address. The stack is managed as a single object, with all units identified by a single IP address. Using Tree View, you can obtain an overview of the members of the stack and a network topology showing the locations of the units and their link information. This simple yet powerful web-based management eliminates the need for you to install expensive SNMP network management software. You can add units to up to 32 switches per stack not limited to any specific D-Link SIM models.
Voice and Video Applications
For today’s business, having voice, data and video on the same network is common practice. This challenge is met by the DGS-3426P, which supports 802.1p with 8 queues. The administrator can designate the priority of the traffic based on a variety of means including IP or MAC address, so that voice data is always clear and jitter free. Video traffic can also be assigned with the same priority. In addition, the xStack switch provides IGMP Snooping or MLD snooping, which allows the forwarding of multicast packets such as streaming audio and video, without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations who have joined the multicast group is created. This list allows a switch to intelligently forward packets to only the appropriate member workstations. In conjunction with the 802.1Q VLANs the switch supports, Quality of Service and security can be achieved on a network infused with data traffic.
For other multimedia-on-demand applications, such as IPTV deployments, the xStack DGS-3426P provides advanced features for easy video streaming management. For example, the xStack switch supports per port multicast stream control, which allows a service provider to assign limited multicast addresses per port. This means it can act as a security control that pre-configures channels for each subscriber on a port level to prevent unauthorized multicast join. The xStack DGS-3426P also supports IGMP multicast VLAN, which eliminates duplicate multicast traffic being sent to clients in different VLANs and thus removing bottlenecks in the uplink port.
Ease of Management
The xStack DGS-3426P supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize the productivity of the network. Other standard management features also include RMON and IEEE 802.1d/w/s Spanning Tree. The user interface options include an intuitive web-based browser graphic interface or industry-standard CLI, either administration traffic can be protected through SSL or SSH encryptions.
מאפיינים כללים
Interface
Ports
24 10/100/1000BASE-TX Auto-Negotiating, Auto-MDI/MDIXPorts with 802.3x Flow Control
Combo Ports
4 Combo SFP Slots, Media Support Dependent On GBIC Transceiver
Open Slot for 10-Gigabit Uplink Modules
2 Open Slots for 10Gigabit Uplink Modules
Diagnostic LEDs
Per Device: Power, Console, RPS
Per Gigabit Port: Link/Activity, 10/100Mbps or 1000Mbps Speed
Per Ethernet Port: Link/Activity, 10Mbps or 100Mbps Speed
RS-232 Console Port
1
Option 10-Gigabit Uplink (Transceivers sold separately)
Single XFP Slot Module (DEM-410X)
Yes
Single CX4 Port Module (DEM-410CX)
Yes
10GBASE-SR (300 m Multi-Mode Fiber) Support
Yes
10GBASE-LR (10 km Single-Mode Fiber) Support
Yes
Maximum Number of 10-Gigabit Uplinks Installable
2
Performance
Switch Fabric
88Gbps
Packet Forwarding Rate
65.47Mpps
Packet Buffer
750KB
MAC Address Table
8K Entries
IP v4 Routing Table
128 Entries
IP v6 Routing Table
128 Entries
IP v4 Host Table
2K Entries
IP v6 Host Table
1K Entries
Jumbo Frame Size
9,216 Bytes
Power
Internal Power Supply
100 to 120VAC, 200 to 240VAC, 50/60Hz
Maximum Power Consumption
433 Watts
Optional Redundant Power Supply
DPS-600
Physical/Environmental
Ventilation
2 40x40 mm DC Fans
Heat Dissipation
1477.48 BTU/Hr.
MTBF
98,704 hours
Acoustic
< 52.4dB
Temperature
Operating: 32° to 104°F (0° to 40°C)
Storage: -40° to 158°F (-40° to 70°C)
Humidity
Operating: 10% ~ 90% Non-condensing
Storage: 5% ~ 90% Non-condensing
Dimensions
17.3 x 15.3 x 1.7 inches (441 x 389 x 44 mm)
19-inch Standard Equipment Rack Mount Width, 1U Height
Weight
12.8 lbs (5.82 kg)
Emissions
FCC Class A, CE, C-Tick, VCCI
Safety Compliance
CSA International, CB
Software Functions
L2 Features
IGMP Snooping Supports
IGMP Snooping v1, v2, v3
1K IGMP Snooping Groups
IGMP Fast Leave
Host-based IGMP Fast Leave *
Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
MLD Snooping Supporting 511 MLD Snooping Groups
Loop Back Detection
32 802.3ad Link Aggregation Groups
Back Pressure Flow Control
Trunking Across Stack
Head-of-line Blocking Prevention
Port Mirroring
One-to-One
Multiple-to-One
ACL modes *
VLAN
802.1Q
Double VLAN
Maximum 4K Static VLAN Groups
GVRP
Guest VLAN
802.1v
MAC-based VLAN
L3 Features
128 IP v.4/v.6 Static Routing
QoS (Quality of Service)
Per Flow Bandwidth Control
802.1p Support
8 Queues per Port
Queue Handling
Strict
Weighted Round Robin (WRR)
CoS Based on:
Switch Port
MAC Address
802.1p Priority
VLAN
Protocol Type
TOS
DSCP
IP v.4/v.6 Address
IP v.6 Traffic Class
IP v.6 Flow Label
TCP/UDP Port
User Defined Packet Content *
ACL (Access Control List)
Up to 768 Access Rules:
Switch Port
MAC Address
802.1p Priority
VLAN
Protocol Type
TOS
DSCP
IP Address
IP v.4/v.6 Address
IP v.6 Flow Label
TCP/UDP Port
Time-based ACL
CPU Interface Filtering
ACL Statistic *
Security
RADIUS/TACACS/TACACS+
SSH v.2
SSL v.3
Port Security
802.1x Port-based/MAC-based Access Control
Web-based Access Control *
MAC-based Access Control *
Broadcast Storm Control
Traffic Segmentation
IP-MAC-Port Binding (500 entries per device)
Support Microsoft NAP
Management
D-Link Single IP Management v.1.6
Web-based GUI
CLI
Web GUI Traffic Monitoring
Web MAC Address Browsing
Telnet server
Telnet client *
TFTP client
SNMP v.1, v.2c, v.3
SNMP trap on MAC Notification
RMON v.1
BootP/DHCP client
DHCP auto-configuration
DHCP relay option 82
System log
Trap/alarm/log severity control
vFlash file system
Dual Images
Dual Configuration
CPU Monitoring
LLDP *
MIBs
MIB-II (RFC 1213)
Bridge MIB (RFC 1493)
SNMP v.2 MIB (RFC 1907)
RMON MIB (RFC 1757, 2819)
RMON v.2 MIB (RFC 2021)
Ethernet-like MIB (RFC 1643, 2358, 2665)
802.1p MIB (RFC 2674)
IF MIB (RFC 2233, 2863)
RADIUS Authentication Client MIB (RFC 2618)
RADIUS Accounting Client MIB (RFC 2620)
Ping/Traceroute MIB (RFC 2925) *
D-Link enterprise MIB
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3426P
xStack Layer 2+ 24-Port Gigabit PoE Switch with 4 Combo SFP Ports and 2 10Gigabit Slots
DGS-3427
xStack Layer 2+ 24-Port Gigabit Switch with 4 Combo SFP Ports and 3 10Gigabit Slots
DGS-3450
xStack Layer 2+ 48-Port Gigabit Switch with 4 Combo SFP Ports and 2 10Gigabit Slots
DEM-310GT
SFP Transceiver for 1000BASE-LX, Single Mode Fiber, Maximum Distance 10Km
DEM-311GT
SFP Transceiver for 1000BASE-SX, Muti Mode Fiber, Maximum Distance 550m
DEM-410CX
1-Port CX-4 10Gigabit Module with 1 Meter CX-4 Cable
DEM-410X
1-Port XFP 10Gigabit Module
DEM-421XT
XFP Transceiver for 10GBASE-SR, Multimode Fiber, Maximum Distance 300m
DEM-422XT
XFP Transceiver for 10GBASE-LR, Singlemode Fiber, up to 10Km
DPS-500
Redundant Power Supply (for DGS-3427/DGS-3450)
DPS-600
Redundant Power Supply (for DGS-3426P)
DPS-800
2-Slot Redundant Power Supply Chassis (for DPS-500)
DPS-900
8-Slot Redundant Power Supply Chassis (for DPS-500)
DV-600S
D-View 6.0 SNMP Network Management Software, Standard Version
DV-600P
D-View 6.0 SNMP Network Management Software, Professional Version
תקנים
הורדות
איורים
DGS-3426P
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
