DGS-3100-24PEOL EOS
מתג מנוהל 24 פורטים Layer2 PoE ג'יגהביט + 4 פורטים Combo SFP (שרשור של 20 ג'יגה)
היכן לקנות
תאור
Introducing the D-Link DGS-3100-24P gigabit stackable switch is designed for growing companies looking for scalability and robust security features. The D-Link DGS-3100-24P is equipped with robust features that fulfill the most demanding network needs in today’s multimedia-intensive world. Stackable up to 6 units under a single IP, the DGS-3100-24P provides a total of 20Gbps full-duplex of fixed stacking bandwidth. Designed with efficient QoS features, the DGS-3100-24P facilitates smooth videos and jitter-free VoIP deployments. To help secure your network, D-Link implements both the Safeguard Engine to prevent Denial-of-Service attacks, and Access Control Lists to enhance security to your network. The DGS-3100-24P is equipped with industry standard management features such as an easy-to-use web-based administrator interface and CLI interface. D-Link provides features on a cost-effective platform that will increase your company’s productivity and protect your investment.
Stackable up to 6 Units
The DGS-3100-24P includes two built-in stacking ports that can provide up to 20Gbps in stacking backplane. This will enhance your overall network performance for those switches transmitting large files. Under stacking mode, the switch is hot-swappable meaning that in a stack configuration, any of the switches can be replaced or removed without affecting the network. There is no need to reconfigure a replacement switch; simply give the new switch the same stack number ID as the old switch and the new switch will carry the same configuration as before. This minimizes the downtime of a network and maximizes the productivity of your business. Also, cross stack port mirroring and port trunking are supported to facilitate network administration.
The D-Link Safeguard Engine and Security
The DGS-3100-24P incorporates advanced mechanisms to detect an attack against the central processing unit of the switch and to take corrective action on the attacking interface. When a Denial of Service attack is waged against the DGS-3100-24P, the D-Link Safeguard Engine detects the threat and prevents an overload of the central processor, ensuring network integrity and helping to maintain open network bandwidth channels.
In addition, D-Link switches support 802.1x authentication, which is a secure implementation that allows users to log onto your network. When used in conjunction with a RADIUS server, 802.1x requires each workstation attached to the DGS-3100-24P to provide a username and password before gaining access to the local area network. D-Link also utilizes security features such as the Access Control List, allowing an administrator to restrict the access of a network through a variety of means including MAC address, IP, UDP/TCP, and even VLAN ID. Time-based ACL* is especially useful for K-12 or college environments when access can be limited based on time.
Voice and Video Applications
For today’s business, having voice, data, and video on the same network is common practice. This challenge is met by the D-Link DGS-3100-24P, which supports 802.1p Quality of Service (Qos) with 4 queues. The administrator can designate the priority of the traffic based on a variety of means including IP and MAC address, so that voice data is always clear and jitter-free. Video traffic can also be assigned with the same priority. In addition, the DGS-3100-24P provides IGMP Snooping, which allows the forwarding of multicast packets without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations who have joined the multicast group is created. This list then allows the switch to intelligently forward packets to only the appropriate member workstations. For IPv6 traffic, the DGS-3100-24P supports MLD snooping*. The DGS-3100-24P also supports 802.1Q VLANs, allowing QoS and security to be achieved on a data laden network.
Power over Ethernet
To facilitate and expedite deployments, Power Over Ethernet (PoE) 802.3af may be required for a network. For access points, IP cameras, and even IP phones, each port on the DGS-3100-24P provides up to 15.4 Watts of power, providing a total of 370 Watts of PoE budget on each switch. The DGS-3100-24P provides a generous supply of PoE budget for those devices that may require higher power consumption or for devices that are further away from the switch (the further away a device is, the more power draw is required). IEEE 802.3af compliant, the DGS-3100-24P will provide power to devices that support the IEEE 802.3af standard.
Ease of Management
The DGS-3100-24P supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize the productivity of the network. Other standard management features also supported include RMON and IEEE 802.1d spanning tree. Users can interface using either an intuitive web-based browser graphic interface or a standard Command Line Interface (CLI), both of which are protected through SSL or SSH encryptions.
* Features available in future free firmware upgrade.
מאפיינים כללים
Interface
10/100/1000BASE-T Ports
24
Combo SFP Slots
4
RS-232 Console Port
Yes
Optional Redundant Power Supply
DPS-600
Stacking
HDMI Stacking Ports
2
Number of Unit Per Stack (Max)
6
Up to 10Gbps with Linear, Topology Up to 20Gbps with Bi-Directional Redundant Ring Topology
Power Over Ethernet
802.3af PoE Support
Per 10/100/1000BASE-T Port
Power Provision Per Port (Max.)
15.4W
System PoE Power Budget
370W
Auto Power/Device Discovery
Yes
Over-Current Protection
Yes
Performance
Switch Capacity
68Gbps
64-Byte Packet Fowarding Rate
50.60Mpps
MAC Address Table Size
8K
Packet Buffer
768KB
Jumbo Frame (Max.)
10,240 Bytes
Physical & Environmental
Power Input
100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Power Consumption (Max)
555.50W
Dimensions (W x D x H)
17.3in x 12.2in x 1.7 in (440mm x 310mm x 44mm)
Size
19-inch Rack-Mount Width, 1U Height
Weight
12.31lbs (5.58kg)
Heat Dissipation
1895.48 BTU/hr
MTBF
117,136 hrs
Temperature
Operating: 32° to 104°F (0° to 40°C)
Storage: -14° to 158° F (-10° to 70° C)
Humidity
Operating: 10% to 90% non-condensing
Storage: 5% to 90% non-condensing
EMI/EMC
FCC Class A, ICES-003 Class A, CE, C-Tick, VCCI Class A
Safety
cUL, CB
Software Functions
L2 Features
IGMP snooping v1, v2
Up to 256 IGMP snooping groups
Up to 64 static multicast address
IGMP Per VLAN
IGMP snooping fast leave
MLD snooping*
Spanning Tree
802.1D STP
802.1s MSTP
802.1w RSTP
STP Loopback Detection
BPDU filtering
802.3ad Link Aggregation: max. 32 groups per device, 8 ports per group
Mirroring
One-to-one mode
Many-to-one mode
VLAN
802.1Q
802.1v protocol VLAN*
VLAN Groups:
total 256 VLAN groups, max. 256 static
max. 256 dynamic VLAN groups
GVRP
Double VLAN*
Asymmetric VLAN*
ACL (Access Control List)
Maximum Mask/Profiles: 15 profiles, 240 rules per profile
Time Based ACL*
Content-based ACL according to:
802.1p priority
MAC address
IP address
L4 Protocol type
VID
Ether type
DSCP
TCP/UDP port number
Quality of Service (QoS)
Priority queues number: 4 queues
802.1p standard
Queue handling: WRR/Strict/ST+WRR modes
Bandwidth Control:
Port and Flow based bandwidth control
Granularity: down to 64Kbps
Class of Service based on:
802.1p priority
Ether type
DSCP
TCP/UDP port number
VLAN MAC address
IP address
Protocol type
Security
Traffic Segmentation
SSH v2
SSL v3
Port Security: 16 MACs per port
Broadcast Storm Control
AAA
Port/MAC-Based 802.1X Access Control
Guest VLAN
RADIUS Auth. for Management Access
TACACS+ Auth. for Mgmt Access
Web-based Access Control*
MAC-based Access Control*
Management
Web-based GUI
CLI
Device Locator
Telnet Server
Telnet Client
TFTP Client
SNMP v1, v2c, v3
SNMP Traps
Dual Image Support
System Log
RMON v1
BootP/DHCP Client
DHCP Auto-configuration
SNTP
Port Description
CPU Monitoring
Web GUI Traffic Monitoring
MIB
MIBII (RFC 1213)
Bridge MIB (RFC 1493)
SNMP v2 MIB (RFC 1907)
RMON MIB (RFC 1757, 2819)
Ether-like MIB (RFC 2021)
802.1p MIB (RFC 1643, 2358, 2665)
IF MIB (RFC 2674)
RADIUS Authentication Client MIB (RFC 2233, 2863)
RADIUS Accounting Client MIB (RFC 2618)
Private MIB
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3100-24P
Managed 24-Port Gigabit Stackable PoE Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-48P
Managed 48-Port Gigabit Stackable PoE Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-24
Managed 24-Port Gigabit Stackable Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-48
Managed 48-Port Gigabit Stackable Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DEM-211
100BASE-FX 155Mbps MMF fiber LC SFP Transceiver
DEM-310GT
1000BASE-LX SFP LC Transceiver, up to 10Km
DEM-311GT
1000BASE-SX SFP LC Transceiver, up to 500m
DPS-200
Redundant Power Supply for DGS-3100-24
DPS-500
Redundant Power Supply for DGS-3100-48
DPS-500DC
Redundant Power Supply –48V DC power input
DPS-600
Redundant Power Supply for PoE models DGS-3100-24P, DGS-3100-48P
נתונים פיזיים
תקנים
הורדות
איורים
DGS-3100-24P
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
