חיפוש מהיר
תכונות המוצר:
מתג מנוהל 48 פורטים Layer2 ג'יגהביט + 4 פורטים Combo SFP (שרשור של 20 ג'יגה)
EOL EOS
מאפיינים כללים:
Interface
10/100/1000BASE-T Ports
48
Combo SFP Slots
4
RS-232 Console Port
Yes
Optional Redundant Power Supply
DPS-500
Stacking
HDMI Stacking Ports
2
Number of Unit Per Stack (Max)
6
Up to 10Gbps with Linear, Topology Up to 20Gbps with Bi-Directional Redundant Ring Topology
Performance
Switch Capacity
116Gbps
64-Byte Packet Fowarding Rate
86.31Mpps
MAC Address Table Size
8K
Packet Buffer
1.5MB
Jumbo Frame (Max.)
10,240 Bytes
Physical & Environmental
Power Input
100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Power Consumption (Max)
102.63W
Dimensions (W x D x H)
17.3in x 12.2in x 1.7 in (440mm x 310mm x 44mm)
Size
19-inch Rack-Mount Width, 1U Height
Weight
12.11lbs (5.50kg)
Heat Dissipation
350.19 BTU/hr
MTBF
103,924 hrs
Temperature
Operating: 32° to 104°F (0° to 40°C)
Storage: -14° to 158° F (-10° to 70° C)
Humidity
Operating: 10% to 90% non-condensing
Storage: 5% to 90% non-condensing
EMI/EMC
FCC Class A, ICES-003 Class A, CE, C-Tick, VCCI Class A
Safety
cUL, CB
Software Functions
L2 Features
IGMP snooping v1, v2
Up to 256 IGMP snooping groups
Up to 64 static multicast address
IGMP Per VLAN
IGMP snooping fast leave
MLD snooping*
Spanning Tree
802.1D STP
802.1s MSTP
802.1w RSTP
STP Loopback Detection
BPDU filtering
802.3ad Link Aggregation: max. 32 groups per device, 8 ports per group
Mirroring
One-to-one mode
Many-to-one mode
VLAN
802.1Q
802.1v protocol VLAN*
VLAN Groups:
total 256 VLAN groups, max. 256 static
max. 256 dynamic VLAN groups
GVRP
Double VLAN*
Asymmetric VLAN*
ACL (Access Control List)
Maximum Mask/Profiles: 15 profiles, 240 rules per profile
Time Based ACL*
Content-based ACL according to:
802.1p priority
MAC address
IP address
L4 Protocol type
VID
Ether type
DSCP
TCP/UDP port number
Quality of Service (QoS)
Priority queues number: 4 queues
802.1p standard
Queue handling: WRR/Strict/ST+WRR modes
Bandwidth Control:
Port and Flow based bandwidth control
Granularity: down to 64Kbps
Class of Service based on:
802.1p priority
Ether type
DSCP
TCP/UDP port number
VLAN MAC address
IP address
Protocol type
Security
Traffic Segmentation
SSH v2
SSL v3
Port Security: 16 MACs per port
Broadcast Storm Control
D-Link Safeguard Engine
AAA
Port/MAC-Based 802.1X Access Control
Guest VLAN
RADIUS Auth. for Management Access
TACACS+ Auth. for Mgmt Access
Web-based Access Control*
MAC-based Access Control*
Management
Web-based GUI
CLI
Device Locator
Telnet Server
Telnet Client
TFTP Client
SNMP v1, v2c, v3
SNMP Traps
Dual Image Support
System Log
RMON v1
BootP/DHCP Client
DHCP Auto-configuration
SNTP
Port Description
CPU Monitoring
Web GUI Traffic Monitoring
MIB
MIBII (RFC 1213)
Bridge MIB (RFC 1493)
SNMP v2 MIB (RFC 1907)
RMON MIB (RFC 1757, 2819)
Ether-like MIB (RFC 2021)
802.1p MIB (RFC 1643, 2358, 2665)
IF MIB (RFC 2674)
RADIUS Authentication Client MIB (RFC 2233, 2863)
RADIUS Accounting Client MIB (RFC 2618)
Private MIB
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3100-48
Managed 48-Port Gigabit Stackable Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-24
Managed 24-Port Gigabit Stackable Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-48P
Managed 48-Port Gigabit Stackable PoE Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DGS-3100-24P
Managed 24-Port Gigabit Stackable PoE Layer 2 Switch, 4 combo SFP, 20 Gig Stacking
DEM-211
100BASE-FX 155Mbps MMF fiber LC SFP Transceiver
DEM-310GT
1000BASE-LX SFP LC Transceiver, up to 10Km
DEM-311GT
1000BASE-SX SFP LC Transceiver, up to 500m
DPS-200
Redundant Power Supply for DGS-3100-24
DPS-500
Redundant Power Supply for DGS-3100-48
DPS-500DC
Redundant Power Supply –48V DC power input
DPS-600
Redundant Power Supply for PoE models DGS-3100-24P, DGS-3100-48P
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
