חיפוש מהיר
תכונות המוצר:
מתג מנוהל 8 פורטים Layer3 במהירות 10/100/1000, בנוסף 4 פורטים Combo 1000Base-T/Mini GBIC SFP
EOL EOS
מאפיינים כללים:
DGS-3612
Managed Layer 2/3/4 Switch with (12) 1000BASE-X SFP Ports and (4) Combo 1000BASE-T Ports
Packet Buffer
2MB
MAC address Table
16K
IP Routing
256 Static/ 16k Dynamic Total
Aggregated Bandwidth
24Gbps
Throughput
17.86Mpps
Transmission Method
Store-and-Forward
Forwarding Rate
14,880pps (10M)
148,800pps (100M)
1,488,000pps (1000M)
VLANs
Support up to 4K Static, 255 Dynamic 802.1p VLAN Groups
Priority Queues 8 Queues - Strict Priority or Weight Round Robin Queue Scheduling
Classification ACLs
Switch Port, VLAN ID, IEEE802.1p, MAC Address, DSCP, Protocol Type, IPv6 Traffic Class, IPv6 Flow Label, TCP/UDP Port, User Defined Packet Content, Time Based ACL, CPU Interface Filtering
Classification QoS
Switch Port, VLAN ID, IEEE802.1p Priority, MAC Address, IP Address, DSCP, Protocol Type, IPv6 Traffic Class, IPv6 Flow Label, TCP/UDP Port, User Defined Packet Content
Multicast Support
IGMP v1/2/3*, IGMP Snooping
Jumbo Frames
Up to 9216Bytes
Interface Options
RJ-45
10BASE-T, 100BASE-TX & 1000BASE-T
LC
With Optional Standard Small Form-Factor Pluggable (SFP) Gigabit Transceivers
RPS
Redundant Power Option Via Optional DPS-500
Network Management
In Band & Out of Band
Telnet, CLI/Console, RMON, Web-based HTTP, SNMPv1/v2/v3, Syslog, Port Mirroring, TFTP Client, BootP Client, DHCP Client, BootP/DHCP Client
IEEE
802.3 Ethernet, 802.3u Fast Ethernet, 802.3ab Gigabit Ethernet, 802.3z Gigabit Ethernet, 802.1d Spanning Tree, 802.1w Rapid Spanning Tree, 802.1p Priority Tags, 802.1q VLANs (4K static/255 dynamic), 802.3ad Link Aggregation (32 Groups/8 ports), 802.3x Flow Control, 802.1x Port-based/MAC Based Authentication, 802.1s (Multiple Spanning Tree)
IETF
RFC 1157 SNMP, RFC 1112/2236 IGMPv1/2 IGMPv3*, RFC 1757/2021/2819 RMON (4 Groups), RFC 1493 Bridge MIB, RFC 1213 MIB II, RFC 793 TCP, RFC 826 ARP, RFC 854 Telnet, and DiffServ, RFC 1724 RIP v1/2, RFC 1850 OSPF*, DVMRP, RFC 2934 PIM DM, PIM-SM*, RFC 2932 Multicast Routing, RFC 2787 VRRP, RFC 2096 IP Forwarding Table MIB (CIDR), RFC 2787 VRRP MIB, RFC 2618/2620 RADIUS Accounting Client, RFC2618 RADIUS Authentication Client MIB, RFC 2863 IF MI B, RFC 2674 802.1p MIB, RFC 2668 802.3 MAU MIB, RFC 2665 Ether-like MIB, SSH2, SSLv3, TACACS+
Electrical & Emissions Summary
Emissions
CE class A, FCC Class A, VCCI Class A, C-Tick Class A
Power Supply
AC Input: 100 - 240 VAC, 50/60 Hz Internal Universal Power Supply
Power Consumption
60 Watts (maximum)
Safety Agency Certifications and Environmental
Safety
CSA International, CB Report
Temperature
Operating: 0° to 40° C (32° to 104° F)
Storage: -40° to 70° C (-40° to 158° F)
Humidity
Operating: 10% to 85% RH, Non-condensing
Storage: 5% to 95% RH, Non-condensing
Physical Specifications
Dimensions (W x D x H)
441mm(W) x 310mm(D) x 44mm(H) 19-inch, 1U Rack-mount size
Weight
9.35lbs
Warranty and Support Information
Warranty
lifetime Warranty
Ordering Information
Part Number
Description
DGS-3612
Standalone Managed Layer 2/3/4 Switch with (12) SFP Ports, (4) Combo Gigabit Copper Ports
DEM-310GT
Mini-GBIC/SFP 1000BASE-LX (up to 10Km)
DEM-311GT
Mini-GBIC/SFP 1000BASE-SX (up to 550m)
DEM-210
Mini-GBIC/SFP 100BASE-FX SMF (up to 15Km)
DEM-211
Mini-GBIC/SFP 100BASE-FX MMF (up to 2Km)
DPS-500
Redundant Power Supply
DPS-800
2 slot Redundant Power Supply Unit Chassis
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
