![]() דגם ישן |
תכונות המוצר:
מתג שולחני 8 פורטים 10/100/1000 |
תאור:
The first of the Green Ethernet products the DGS-1008D provides 3 key benefits to end users through its cutting edge innovative eco-friendly technology
Power Savings by Number of Connected Ports and Link Status
Power Savings by Cable Length
Overall Power Savings Per Day
Note: Switch uses switching power adapter. The cable length which PCs are connected to switch is 20m cables. Get the blazing speed of Gigabit Ethernet with the D-Link DGS-1008, an 8-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. Power-Packed Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1008 10/100/1000 Mbps Gigabit Switch protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds. Easy to use It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network.
ראה גם
