תאור
The DES-6500 is a Layer 3 backbone chassis-based Gigabit switch that provides everything a business needs for a switched network. This 9-slot chassis offers a high switch fabric capacity of 160Gbps supporting wire speed L2/L3 packet switching in dynamic or static environments. Some of the features include a high port density, with L2/L3/L4 Class of Service (CoS) and Access Control Lists (ACL), Multiple link aggregation, fault tolerance, a hot-swappable CPU module/line card and redundant power supply, and traffic monitoring. Designed for performance and flexibility, this chassis offers you the price/performance ratio necessary to deploy a cost-effective enterprise backbone network.
High Scalability, Availability, & Security
With 8 line card slots and a wide range of user-selectable port types and speeds, the switch provides easy scalable expansion as your network needs grow. This switch provides redundancy of power, link aggregation, STP, and VRRP, which prevents single point of failure, minimizes possible network downtime, and increases the network’s availability. Line card hot-swappable capability makes it easy to swap defective line cards, shorten the network restoration time, and simplify troubleshooting. Increase security by taking advantage of 802.1x, RADIUS authentication, TACACS+, SSL, and SSH network security features. The hardware and software features of the DES-6500 all work together to allow customers to build affordable, high performance, high availability, and highly secure networks.
Up to 16 10Gigabit ports, 96 Gigabit Ports, 192 Fast Ethernet Ports, 142 Mpps Forwarding Rate
You can configure the switch with up to 96 Gigabit ports, 192 twisted-pair Fast Ethernet ports or a combination of both. Copper and fiber Gigabit are supported. Built-in wire-speed switch fabric provides hardware-based packet filtering and forwarding, while packet routing is performed by on-board ASICs, which are many times faster than traditional CPU-based routers.
Network Management
The DES-6500 supports a variety of network management options including: console CLI, Telnet configuration, Web-based and SNMP v1, v2, v3 management, RMON monitoring, TFTP firmware upgrade, TFTP configuration download/upload, Port Mirroring for troubleshooting, and BootP/DHCP IP assignment. It also supports advanced traffic management options including: 802.3x, Bandwidth Control, Broadcast Storm Control, Traffic Segmentation and IGMP snooping. Live CPU utilization monitoring and port descriptions are available to help troubleshoot when a performance degradation occurs.
Advanced Enterprise Features
The DES-6500 supports IP (RIP, OSPF) and IGMP, DVMRP, and PIM multicasting for logical network segmentation and traffic control. It also supports a complete set of Spanning Tree Protocols (STP), Rapid Spanning Tree Protocol (RSTP), and Multiple Spanning Tree Protocol for Layer 2 redundancy.
מאפיינים כללים
Hardware | |||||||||||||||||||||||||
Port Standard/Funtion Support |
DES-6500 Chassis System |
DES-6502 CPU/Fabric Switching Module (Shipped with DES-6500) |
DES-6504 12 port 100BASE-FX MMF LC Module |
DES-6506 24-port RJ-21 to RJ-45 Patch Panel |
DES-6507 12-port 10/100/1000Base-T + 2SFP Combo Module |
DES-6508 16-port 10BASE-T/100BASE-TX RJ-45 Fast Ethernet Switch module |
DES-6509 12-port 1000Base-X SFP Fiber Module |
DES-6510 24 Port 10/100Mbps RJ-21 Telco 50 Module |
DES-6511 Power Supply |
DES-6512 2 Port 10G XFP module for DES-6500 chassis |
Network Cable |
Software | |||||||||||||||||||||||||
VLAN (Layer 2) |
Spanning Tree (Layer 2) |
IP Routing (Layer 3) |
Traffic Classification (CoS) |
Access Control/Security |
Access Control List (ACL) |
Link Aggregation |
Configuration |
Management Support |
MIB |
Port Configuration & Monitoring |
Electrical & Emissions Summary | |||||||||||||||||||||||||
EMI Certification |
Power Input |
Power Output (per power supply unit) |
Physical Specifications | |||||||||||||||||||||||||
Dimensions |
Weight |
Operating Temperature |
Storage Temperature |
Humidity |
Warranty and Support Information | |||||||||||||||||||||||||
Warranty |
Support |
Ordering Information | |||||||||||||||||||||||||
Part Number |
DES-6500 |
DES-6504 |
DES-6506 |
DES-6507 |
DES-6508 |
DES-6509 |
DES-6510 |
DES-6511 |
DES-6512 |
DEM-310GT |
DEM-311GT |
DEM-312GT2 |
DEM-314GT |
DEM-315GT |
DS-510P |
